I suspect that the empty element simply returns a null pointer.
Here is an example of that code with an extra pattern called rubbish at the end. This is the first pattern that gets called when it is run.
Example developed starting from Toby Oxborrow's sketch
https://github.com/tobyoxborrow/gameoflife-arduino/blob/master/GameOfLife.ino
// adding an extra pattern - Grumpy Mike
#include "Arduino_LED_Matrix.h"
// grid dimensions. should not be larger than 8x8
#define MAX_Y 8
#define MAX_X 12
// time to wait between turns
#define TURN_DELAY 200
// how many turns per game before starting a new game
// you can also use the reset button on the board
#define TURNS_MAX 60
// number of patterns in predefined list
#define MAX_PATTERNS 5
// how many turns to wait if there are no changes before starting a new game
#define NO_CHANGES_RESET 4
int turns = 0; // counter for turns
int noChanges = 0; // counter for turns without changes
// game state. 0 is dead cell, 1 is live cell
uint8_t grid[MAX_Y][MAX_X] = {
{0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
int currentPattern = 4;
String patternNames[] = {
"Glider",
"Light-weight spaceship",
"R-Pentomino",
"Diehard",
"Rubbish"
// custom starting grid patterns
boolean cGrids[][MAX_Y][MAX_X] = {
{ /* Glider */
{0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
{0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0},
{1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0},
{ /* Light-weight spaceship */
{0, 0, 0, 0, 1, 0, 0, 1, 0, 0, 0, 0},
{0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0},
{0, 0, 0, 1, 0, 0, 0, 1, 0, 0, 0, 0},
{0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 0},
{ /* R-Pentomino */
{0, 0, 0, 0, 0, 0, 1, 1, 0, 0, 0, 0},
{0, 0, 0, 0, 0, 1, 1, 0, 0, 0, 0, 0},
{0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0},
{ /* Die hard */
{1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0},
{0, 1, 0, 0, 0, 1, 1, 1, 0, 0, 0, 0},
{ /* Rubbish */
{1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0},
{0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 0, 0},
ArduinoLEDMatrix matrix;
Serial.println("Conway's game of life on Arduino LED Matrix");
matrix.begin();
resetGrid();
displayGrid();
delay(TURN_DELAY);
playGoL();
turns++;
// reset the grid if no changes have occured recently
// for when the game enters a static stable state
if (noChanges > NO_CHANGES_RESET) {
resetGrid();
// reset the grid if the loop has been running a long time
// for when the game cycles between a few stable states
if (turns > TURNS_MAX) {
resetGrid();
displayGrid();
// play game of life
void playGoL() {
1. Any live cell with fewer than two neighbours dies, as if by loneliness.
2. Any live cell with more than three neighbours dies, as if by
overcrowding.
3. Any live cell with two or three neighbours lives, unchanged, to the next
generation.
4. Any dead cell with exactly three neighbours comes to life.
boolean newGrid[MAX_Y][MAX_X] = {
for (int y = 0; y < MAX_Y; y++) {
for (int x = 0; x < MAX_X; x++) {
int neighboughs = countNeighbours(y, x);
if (grid[y][x] == 1) {
if ((neighboughs == 2) || (neighboughs == 3)) {
newGrid[y][x] = 1;
newGrid[y][x] = 0;
if (neighboughs == 3) {
newGrid[y][x] = 1;
newGrid[y][x] = 0;
// update the current grid from the new grid and count how many changes
// occured
int changes = 0;
if (newGrid[y][x] != grid[y][x]) {
changes++;
grid[y][x] = newGrid[y][x];
// update global counter when no changes occured
if (changes == 0) {
noChanges++;
// count the number of neighbour live cells for a given cell
int countNeighbours(int y, int x) {
int count = 0;
// -- Row above us ---
if (y > 0) {
// above left
if (x > 0) {
count += grid[y - 1][x - 1];
// above
count += grid[y - 1][x];
// above right
if ((x + 1) < 8) {
count += grid[y - 1][x + 1];
// -- Same row -------
// left
if (x > 0) {
count += grid[y][x - 1];
// right
if ((x + 1) < 8) {
count += grid[y][x + 1];
// -- Row below us ---
if ((y + 1) < 8) {
// below left
if (x > 0) {
count += grid[y + 1][x - 1];
// below
count += grid[y + 1][x];
// below right
if ((x + 1) < 8) {
count += grid[y + 1][x + 1];
return count;
// reset the grid
void resetGrid() {
Serial.print("Current pattern: ");
Serial.println(patternNames[currentPattern]);
noChanges = 0;
turns = 0;
grid[y][x] = cGrids[currentPattern][y][x];
currentPattern++;
if(currentPattern >= MAX_PATTERNS){
currentPattern = 0;
// display the current grid to the LED matrix
void displayGrid() {
matrix.renderBitmap(grid, 8, 12);
