My FritzBox7490 works well in my home, but it seems to not like either Arduino or ESP32 or the combination of it. The following very simple code demonstrates the problem:
// FritzBox 7490 Wifi connection problems
#include <WiFi.h>
const char* ssid = "mySSID";
const char* password = "myPassword";
delay(2000);
Serial.println("\nConnecting to WIFI");
WiFi.begin(ssid, password); // 1st
delay(500); // 100ms: not ok, 500ms: mostly ok
WiFi.begin(ssid, password); // 2nd
Serial.print(".");
delay(250);
long rssi = WiFi.RSSI(); // RSSI (Received Signal Strength in dBm)
Serial.printf("Successfully connected, getting RSSI: %li \n", rssi);
Serial.print("Looping ");
My ESP32 almost never successfully connects to the FB7490 on the first try; I'd say success is 1 in 100 trials, or even less. And it connects to the FB almost always - more than 99 in 100 trials - on the second try.
It does not seem to be a issue of that specific ESP device, as I tried the ESP32-Dev, ESP32-Pico, and ESP32-Wrover versions, all the same.
It is also not a FritzBox issue per se: I tried an older FritzBox 7272: connections almost always succeeded on first try.
I also configured my Android smartphone as a WiFi router, and again connections were almost always successful on the first try.
I contacted the FritzBox service, but they did not seem to be very interested. If they really looked into this, then they had no answer. They provided a few pre-release firmware versions of their FB7490, but that did not change anything.
As you see in the sketch I found a workaround by programmatically doing the double-barrelled WiFi connections. They can't get too close; a delay of 100ms is too short, a delay of 500ms works most of the time.
I am using this for several months now, and it is very reproducible and at least the work-around is reliable.
But I think this is not acceptable. I am surprised that AVM (the FritzBox company) isn't embarrassed enough to solve this problem.
Anyone with the same or different experience? A solution?
