Why does this FastLed code run slowly?
Hello all.
I've got a FastLED code running two separate LED strips simultaneously and I've been hit with a SERIOUS slowdown in performance from running either of the single LED strips by itself.
I was running this on an Uno before, and thought that the slowdown was purely a hardware issue, but I'm finding out that isn't the case. I upgraded to a MEGA 2560 and am still having these slowdown issues.
The code changes the speed at which LEDs light up by reading results from an UltraSonic proximity sensor. I tried changing the digitalWrite(); to directly addressing the pins as a C statement, but that doesn't seem to have helped much.
Here's the entirety of the code. Is there anything particularly heavy in here that would slow down a Mega?
#include <FastLED.h>
// this is imporant for the code to run
#define NUM_LEDS 150
#define NUM_SECOND 300
#define DATA_PIN 8
#define DATA_TWO 10
#define BRIGHTNESS 100
#define COLOR_ORDER GRB
// #define COLOR_ORDER_SECOND RGB
#define LED_TYPE WS2812B
// #define LED_TYPE_SECOND WS2811
#define VOLTS 5
#define MAX_MA 3000
// Threshold for the distance in which the color change triggers
#define THRESHOLD 80
// declare array
CRGB leds[NUM_LEDS];
CRGB secondLeds[NUM_SECOND];
// Read/echo pin for US Sensor
const int ECHO_PIN = 2;
// diatance variable
int delayDistance = 1;
// Head variables
int headBlue = -10;
int headRed = -30;
int headGreen = -50;
int headYellow = -100;
int secondHeadBlue = 0;
int secondHeadRed = -35;
int secondHeadGreen = -50;
int secondHeadOrange = -100;
// Color variables (need to be global for them to change consistently)
int pulseColorRed = 250;
int pulseColorBlue = 150;
int pulseColorYellow = 30;
int pulseColorGreen = 100;
    // WE DO NEED THESE
    pinMode(3, OUTPUT);
    pinMode(ECHO_PIN, INPUT);
    // Setup LED strip power
    // FastLED.setMaxPowerInVoltsAndMilliamps(VOLTS, MAX_MA);
    // add specific LEDs to array
    FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS);
    FastLED.addLeds<LED_TYPE, DATA_TWO, COLOR_ORDER>(secondLeds, NUM_SECOND);
    // set LED brightness
    FastLED.setBrightness(BRIGHTNESS);
    // show LEDs
    FastLED.show();
    // starup delay .5 second
    // update pulse distance
    measureDist(delayDistance);
    // call first red pulse
    pulse(leds, NUM_LEDS, pulseColorRed, headRed, 0);
    // call the first blue pulse
    pulse(leds, NUM_LEDS, pulseColorBlue, headBlue, 10);
    // call the first yellow pulse
    pulse(leds, NUM_LEDS, pulseColorYellow, headYellow, 20);
    // call the first green pulse
    pulse(leds, NUM_LEDS, pulseColorGreen, headGreen, 30);
    // call the second red pulse
    pulse(secondLeds, NUM_SECOND, pulseColorRed, secondHeadRed, 20);
    // call the second blue pulse
    pulse(secondLeds, NUM_SECOND, pulseColorBlue, secondHeadBlue, 30);
    // Call the second string Orange pulse
    pulse(secondLeds, NUM_SECOND, pulseColorYellow, secondHeadOrange, 0);
    // call second string green pulse
    pulse(secondLeds, NUM_SECOND, pulseColorGreen, secondHeadGreen, 10);
 * Pulse function. intakes Strip Number(the declaration of the LED Strip as an array)
 * NUmber of LEDs in the strip, the color of the pulse, the head variable you want,
 * and the gap between pulses
void pulse(CRGB strip[], const int &ledNumber, int &color, int &head, int gap)
    // Get the head skip
    int skip = headSkip(delayDistance);
    // Increment until it hits the end
    if (head <= ledNumber)
        head += skip;
    // reset if too high
    if (head > ledNumber)
        head = 0 - gap;
    // writing color to the head
    if (head >= 0)
        // color the LEDs
        strip[head] = CHSV(colorChange(color), 255, 255);
        // backfill for skipped LEDs
        backFill(strip, skip, head, color);
    // Show updated LEDs
    FastLED.show();
    // Fade for size
    tailFade(strip, ledNumber, 250);
 * Fade the tail of the LEDs to determine the visual size of the pulse
 * Needs an input between 254 and 200 (200 being the smallest)
// Fade to determine the size of the pulse
void tailFade(CRGB strip[], int ledNumber, int pulseSize)
    for (int i = 0; i < ledNumber; i++)
        // 255 is standard, 215 is very small
        strip[i].nscale8(pulseSize);
 * Determines the skip distance when interacting with the sensor
 * so that the closer a subject is, the more LEDs the pulse will skip
int headSkip(int &distance)
    // translate Sensor reading into headskip scale
    if (50 <= distance)
        return 1;
    else if (30 <= distance < 50)
        return 2;
        return 3;
void backFill(CRGB strip[], int skipDistance, int head, int color)
    for (int i = skipDistance; i > 0; i--)
        int behind = head - i;
        if (behind >= 0)
            strip[behind] = CHSV(colorChange(color), 255, 255);
// Distance measurement
void measureDist(int &distance)
    // C statement to address Trigger Pin directly. Sets to low
    PORTE |= _BV(PE5);
    delayMicroseconds(2);
    // C Statement to address Trigger Pin directly. Sets to high
    PORTE &= ~_BV(PE5);
    delayMicroseconds(10);
    // C Statement to address Trigger Pin directly. Sets to low
    PORTE |= _BV(PE5);
    // Equation for distance calculation condensed into "return"
    // divided by 4 to eliminate "pulseDistance"
    long readerValue = pulseIn(ECHO_PIN, HIGH);
    // Serial.println(readerValue);
    if (readerValue < 9)
        readerValue = 9;
    distance = readerValue * 0.034 / 2;
int colorChange(int &color)
    // Check if there's something within the area of the sensor
    if (delayDistance < THRESHOLD)
        // Resetr the color variable to 0 when it hits 256 (loop)
        if (color > 255)
            color = 0;
        // increment the color if there's something on the sensor.
        color++;
    // return the updated value
    return color;
My only suggestion is to minimize the calls to FastLED.show() as the whole LED strip is updated every time. For example, instead of updating every time in pulse() do this only once at the bottom of loop() for all the pulse() in loop().
That did it.
I had no idea FastLED.show(); was so time intensive.
I moved it from the pulse function into the loop(); and now everything is working perfectly.
Thanks!
What's time consuming is updating the LEDs. Look up the WS2812B datasheet and study the update protocol. The timing is pretty exact. From that you can figure out how long it takes to update 150 LEDs. Then go back to your original code and figure out how long it takes to do all the updates it specified.
FYI APA102-types LEDs update via a SPI-like protocol. I've clocked them well above 10MHz.
They're a little more expensive for what I'm looking for, but I appreciate the feedback. I didn't comb over the tech specs for the WS2812Bs but now that I know what the issue was, I'll have a much easier time expanding this project.
