Running this code, it takes like 11 seconds to run through the led strip (600)
Is this normal performance, is there any easy way i can speed it up, using software?
Otherwise what hardware changes need to be made to get through this cycle in like 1 second?
Code:
#include <FastLED.h> // Include the FastLED library
#define NUM_LEDS 600 // Define the number of LEDs
CRGBArray<NUM_LEDS> leds; // Create an array of CRGB objects
FastLED.addLeds<NEOPIXEL,13>(leds, NUM_LEDS); // Initialize the LED strip
end_turnblack(); // Turn off all LEDs
randomSeed(analogRead(0)); // Initialize random number generator
void loop(){
pattern1_snake(); // Execute pattern 1
void end_turnblack(){
leds.fadeToBlackBy(255); // Fade all LEDs to black
FastLED.delay(1); // Delay to allow the LEDs to update
void pattern1_snake(){
int col = random(0,256); // Generate a random color
for(int i=0;i<NUM_LEDS;i++){
leds[i]=CHSV(col,255,255); // Set each LED to the random color
leds.fadeToBlackBy(10); // Fade the LED to black
Please edit your post, select all code and apply code tags; next save the post.
600 LEDs take 18 milliseconds to update; that is the way the strips work. Your for-loop in pattern1_snake() does 600 updates (I assume fadeToBlackBy does update the strip). So the 11 seconds will be more or less correct.
No, the limiting factor is a duration of your led effects. If you need to lit each led separately, it can't be done quickly any way.
To switch one led you always need to update an entire strip - all 600 leds. Try to modify your plans to use a less time-consuming effects.
I don't think that there are strips that are 10 times as fast but I have never really looked.
I'm aware of the fact that you can do strips in parallel. You need a very fast processor for that (and you don't mention which board you use).
Using a Teensy 3.2-4.1 OctoWS2811 Adaptor with a suitable teensy board might be a solution. I have never used it. I only have a faint idea how it works. There are two examples in the FastLED library how to use it; you will have to rework your code to handle your pattern correctly.
With this, you should be able to speed it up to approx. 1.5 seconds.
Note: the needed Teensy board is a 3.3V board hence the need for the / an adapter.
Hi All,
Using FastLED library
Using these strips, connected two 300 count strips.
BTF-LIGHTING WS2812B RGB ECO LED Strip, Chasing Effects 5050SMD Individually Addressable 16.4FT 60Pixels/m 300Pixels Flexible Dream Color IP30 for Bedroom DIY Projects DC5V(No Adapter or Controller) https://a.co/d/faGfGmS
void loop(){
What is your arduino?
Using some advanced boards - Teensy, Due or STM32 you can split your strip on, say, 8 parts and run them in parallel - so your led could run on strip 8 times faster.
With Uno you also can connect several strips to different pins, but all they will be updated one by one, in series, so it pointless if you need to make it faster
With 600 LEDs, it will take 18mS to update the strip (assuming 800KHz data rate, 24 bits per LED).
In the following code, the for loop executes 600 times, adding an additional 1mS delay per iteration, for a total time of 19mS x 600 = 11.4 seconds.
void pattern1_snake() {
int col = random(0, 256); // Generate a random color
for (int i = 0; i < NUM_LEDS; i++) {
leds[i] = CHSV(col, 255, 255); // Set each LED to the random color
A teensy with an OctoWS2811 board would be able to drive the strips faster, because that drives eight strips in parallel.
For this one particular pattern, you could split the strip into smaller segments, and only update the specific strips that have lit LEDs, but that gets rather complex. ( < edit > not going to work with this pattern, the fade takes too long.)
Alternatively, there are other types of addressable LEDs that have faster bit rates, or that are truly individually addressable, either of which would help.
700 LEDs times 3 bytes per LED times 8 bits per byte = 14,400 bits of data, which is transferred at 800 kHz taking 18 ms to update the whole string.
I don't see a leds.show() command, I thought that's needed to write out the data to the LEDs? Or is that done in the leds.fadeToBlackBy(10) call? That would mean you're doing a total of 600 updates, taking close to 11 seconds.
So there you go. That's 11 seconds of updating the LED string. Not limited by the MCU for sure.
