Hello, i have a little 12v dc motor from a drilling machine, an L298N motor driver modul, 9v battery and an arduino uno.
I tried various basic example projects,. but none of it seems like working. Lets talk about this one for now: https://www.instructables.com/id/L298-DC-Motor-Driver-DemosTutorial/. I wire everything as on the site, start the arduino code, connect the battery, and then the motor driver's onboard led lights up, but the motor dont want to rotate, just takes a tiny little step everytime it has to do something (the tiny little step is almost none, but i can feel a little vibration if i hold the motor in my hand)
I don't think the wiring would be the problem. The motor works fine too if i attach it directly to the 9v battery. I have allready triedd an other arduino uno, and other sites' basic example programs too.
What could be the problem? How can i tell if i f***ed something up accidentally on the motor driver modul while wiring?
Here is the code:
//Setup Motor Pins
#define in1 3 //We are not using PWM for this demo.
#define in2 4
// in1 and in2 are the pins on the L298 drive board,
// 3 and 4 are the pins on the Arduino board.
//set the pins for output
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
//set the pins low - this will keep the motor from moving.
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
//Spin Motor in one direction
digitalWrite(in1, HIGH);
delay(10000); //let it spin for about 10 seconds
//Stop the motor
//Spin Motor in the other direction
digitalWrite(in2, HIGH);
delay(1000); //let it spin for about 10 seconds
