Why is tinkercad simulation showing incorrect header file
This is the code :-
#include <EEPROM.h>
#define LED_PIN 11
#define POTENTIOMETER_PIN A1
byte maxBrightness;
#define EEPROM_ADDRESS_MAX_INTENSITY 10
void setup(){
  Serial.setTimeout(10);
  pinMode(LED_PIN , OUTPUT);
  maxBrightness = EEPROM.read(EEPROM_ADDRESS_MAX_INTENSITY);
   if (maxBrightness == 0){
        maxBrightness = 255;
void loop(){
  if(Serial.available()  > 0){
    int data = Serial.parseInt();
    if((data >=0) && (data <256)){
      EEPROM.write(EEPROM_ADDRESS_MAX_INTENSITY , data);
      maxBrightness = data;
  byte LEDBrightness = annalogRead(POTENTIOMETER_PIN)/4 ;
  if (LEDBrightness > maxBrightness ){
     LEDBrightness = maxBrightness ;
  analogWrite( LED_PIN , LEDBrightness);
This is the header file:
What is wrong with it ?
Welcome to the forum.
Tinkercad is confused. When Tinkercad does not support a certain library, then it shows that message. With your sketch, it sees a bug and gives the wrong error message.
Tinkercad should have said: can not find function annalogRead
ohk makes sense . Thank you so much for helping out . Appreciate it
