Has anyone ever interfaced this type of reader before?
Yes I have just done this and written a routine to gather the data in in Wiegand format. I used interrupts to the two data lines and gather the data in the interrupt service routine. I will be posting the code later on today, keep your eye on the Exhibition section of the forum.
In the mean time here is the nub of the code:-
* By Mike Cook April 2009
* Three RFID readers outputing 26 bit Wiegand code to pins:-
* Reader A Pins 4 & 5
* Reader B Pins 6 & 7
* Reader C Pins 8 & 9
* Interrupt service routine gathers Wiegand pulses (zero or one) until 26 have been recieved
* Then a sting is sent to processing
#include "pins_arduino.h"
* an extension to the interrupt support for arduino.
* add pin change interrupts to the external interrupts, giving a way
* for users to have interrupts drive off of any pin.
* Refer to avr-gcc header files, arduino source and atmega datasheet.
* Theory: all IO pins on Atmega168 are covered by Pin Change Interrupts.
* The PCINT corresponding to the pin must be enabled and masked, and
* an ISR routine provided. Since PCINTs are per port, not per pin, the ISR
* must use some logic to actually implement a per-pin interrupt service.
/* Pin to interrupt map:
* D0-D7 = PCINT 16-23 = PCIR2 = PD = PCIE2 = pcmsk2
* D8-D13 = PCINT 0-5 = PCIR0 = PB = PCIE0 = pcmsk0
* A0-A5 (D14-D19) = PCINT 8-13 = PCIR1 = PC = PCIE1 = pcmsk1
volatile uint8_t *port_to_pcmask[] = {
&PCMSK0,
&PCMSK1,
&PCMSK2
typedef void (*voidFuncPtr)(void);
volatile static voidFuncPtr PCintFunc[24] = {
NULL };
volatile static uint8_t PCintLast[3];
* attach an interrupt to a specific pin using pin change interrupts.
* First version only supports CHANGE mode.
void PCattachInterrupt(uint8_t pin, void (*userFunc)(void), int mode) {
uint8_t bit = digitalPinToBitMask(pin);
uint8_t port = digitalPinToPort(pin);
uint8_t slot;
volatile uint8_t *pcmask;
if (mode != CHANGE) {
return;
// map pin to PCIR register
if (port == NOT_A_PORT) {
return;
else {
port -= 2;
pcmask = port_to_pcmask[port];
slot = port * 8 + (pin % 8);
PCintFunc[slot] = userFunc;
// set the mask
*pcmask |= bit;
// enable the interrupt
PCICR |= 0x01 << port;
void PCdetachInterrupt(uint8_t pin) {
return;
else {
port -= 2;
// disable the mask.
*pcmask &= ~bit;
// if that's the last one, disable the interrupt.
if (*pcmask == 0) {
PCICR &= ~(0x01 << port);
// common code for isr handler. "port" is the PCINT number.
// there isn't really a good way to back-map ports and masks to pins.
static void PCint(uint8_t port) {
uint8_t bit;
uint8_t curr;
uint8_t mask;
uint8_t pin;
// get the pin states for the indicated port.
curr = *portInputRegister(port+2);
mask = curr ^ PCintLast[port];
PCintLast[port] = curr;
// mask is pins that have changed. screen out non pcint pins.
if ((mask &= *port_to_pcmask[port]) == 0) {
return;
// mask is pcint pins that have changed.
for (uint8_t i=0; i < 8; i++) {
bit = 0x01 << i;
if (bit & mask) {
pin = port * 8 + i;
if (PCintFunc[pin] != NULL) {
PCintFunc[pin]();
SIGNAL(PCINT0_vect) {
PCint(0);
SIGNAL(PCINT1_vect) {
PCint(1);
SIGNAL(PCINT2_vect) {
PCint(2);
// End of interrupts code and start of the reader code
volatile long reader1 = 0,reader2 = 0, reader3 = 0;
volatile int reader1Count = 0, reader2Count = 0, reader3Count = 0;
void reader1One(void) {
if(digitalRead(4) == LOW){
reader1Count++;
reader1 = reader1 << 1;
reader1 |= 1;
void reader1Zero(void) {
if(digitalRead(5) == LOW){
reader1Count++;
void reader2One(void) {
if(digitalRead(6) == LOW){
reader2Count++;
reader2 = reader2 << 1;
reader2 |= 1;
void reader2Zero(void) {
if(digitalRead(7) == LOW){
reader2Count++;
void reader3One(void) {
if(digitalRead(8) == LOW){
reader3Count++;
reader3 = reader3 << 1;
reader3 |= 1;
void reader3Zero(void) {
if(digitalRead(9) == LOW){
reader3Count++;
Serial.begin(57000);
// Attach pin change interrupt service routines from the Wiegand RFID readers
PCattachInterrupt(4, reader1One, CHANGE);
PCattachInterrupt(5, reader1Zero, CHANGE);
PCattachInterrupt(6, reader2One, CHANGE);
PCattachInterrupt(7, reader2Zero, CHANGE);
PCattachInterrupt(8, reader3One, CHANGE);
PCattachInterrupt(9, reader3Zero, CHANGE);
delay(10);
// the interrupt in the Atmel processor mises out the first negitave pulse as the inputs are already high,
// so this gives a pulse to each reader input line to get the interrupts working properly.
// Then clear out the reader variables.
// The readers are open collector sitting normally at a one so this is OK
for(int i = 4; i<10; i++){
pinMode(i, OUTPUT);
digitalWrite(i, HIGH); // enable internal pull up causing a one
digitalWrite(i, LOW); // disable internal pull up causing zero and thus an interrupt
pinMode(i, INPUT);
delay(10);
// put the reader input variables to zero
reader1 = reader2 = reader3 = 0;
reader1Count = reader2Count = reader3Count = 0;
digitalWrite(13, HIGH); // show Arduino has finished initilisation
if(reader1Count >= 26){
// Serial.print(" Reader 1 ");Serial.println(reader1,HEX);
Serial.println("A");Serial.println(reader1 & 0xfffffff);
reader1 = 0;
reader1Count = 0;
if(reader2Count >= 26){
Serial.println("B");Serial.println(reader2 & 0xfffffff);
reader2 = 0;
reader2Count = 0;
if(reader3Count >= 26){
Serial.println("C");Serial.println(reader3 & 0xfffffff);
reader3 = 0;
reader3Count = 0;
If you only have one reader then you can use the normal attach interrupts and use Pins 2 & 3 for the inputs. Also you could trigger on just one edge of the signal and make the ISR a bit simpler.
