Wiegand Library
Hi!
I'm new to programming,
I'm stuck, found this wiegand lib: GitHub - monkeyboard/Wiegand-Protocol-Library-for-Arduino: Wiegand 26 and Wiegand 34 Protocol Library for Arduino
I've installed it, and works fine.
I'm using a WG26 reader with keypad. I know my keypad output 4-bits.
But i don't understand how to modify this lib. to output this 4bit data.
appears this lib is ment for 8bit keypad data.
Reading a rfid tag works perfect.
Thanks for looking
Svein:)
Wiegand.cpp
#include "Wiegand.h"
unsigned long WIEGAND::_cardTempHigh=0;
unsigned long WIEGAND::_cardTemp=0;
unsigned long WIEGAND::_lastWiegand=0;
unsigned long WIEGAND::_sysTick=0;
unsigned long WIEGAND::_code=0;
int WIEGAND::_bitCount=0;
int WIEGAND::_wiegandType=0;
WIEGAND::WIEGAND()
unsigned long WIEGAND::getCode()
return _code;
int WIEGAND::getWiegandType()
return _wiegandType;
bool WIEGAND::available()
return DoWiegandConversion();
void WIEGAND::begin()
_lastWiegand = 0;
_cardTempHigh = 0;
_cardTemp = 0;
_code = 0;
_wiegandType = 0;
_bitCount = 0;
_sysTick=millis();
pinMode(D0Pin, INPUT); // Set D0 pin as input
pinMode(D1Pin, INPUT); // Set D1 pin as input
attachInterrupt(0, ReadD0, FALLING); // Hardware interrupt - high to low pulse
attachInterrupt(1, ReadD1, FALLING); // Hardware interrupt - high to low pulse
void WIEGAND::ReadD0 ()
_bitCount++; // Increament bit count for Interrupt connected to D0
if (_bitCount>31) // If bit count more than 31, process high bits
_cardTempHigh |= ((0x80000000 & _cardTemp)>>31); // shift value to high bits
_cardTempHigh <<= 1;
_cardTemp <<=1;
_cardTemp <<= 1; // D0 represent binary 0, so just left shift card data
_lastWiegand = _sysTick; // Keep track of last wiegand bit received
void WIEGAND::ReadD1()
_bitCount ++; // Increment bit count for Interrupt connected to D1
_cardTemp |= 1;
_cardTemp <<=1;
_cardTemp |= 1; // D1 represent binary 1, so OR card data with 1 then
_cardTemp <<= 1; // left shift card data
unsigned long WIEGAND::GetCardId (unsigned long *codehigh, unsigned long *codelow, char bitlength)
unsigned long cardID=0;
if (bitlength==26) // EM tag
cardID = (*codelow & 0x1FFFFFE) >>1;
if (bitlength==34) // Mifare
*codehigh = *codehigh & 0x03; // only need the 2 LSB of the codehigh
*codehigh <<= 30; // shift 2 LSB to MSB
*codelow >>=1;
cardID = *codehigh | *codelow;
return cardID;
bool WIEGAND::DoWiegandConversion ()
unsigned long cardID;
_sysTick=millis();
if ((_sysTick - _lastWiegand) > 25) // if no more signal coming through after 25ms
if ((_bitCount==26) || (_bitCount==34) || (_bitCount==8)) // bitCount for keypress=8, Wiegand 26=26, Wiegand 34=34
_cardTemp >>= 1; // shift right 1 bit to get back the real value - interrupt done 1 left shift in advance
if (_bitCount>32) // bit count more than 32 bits, shift high bits right to make adjustment
_cardTempHigh >>= 1;
if((_bitCount==26) || (_bitCount==34)) // wiegand 26 or wiegand 34
cardID = GetCardId (&_cardTempHigh, &_cardTemp, _bitCount);
_wiegandType=_bitCount;
_bitCount=0;
_cardTemp=0;
_cardTempHigh=0;
_code=cardID;
return true;
else if (_bitCount==8) // keypress wiegand
// 8-bit Wiegand keyboard data, high nibble is the "NOT" of low nibble
// eg if key 1 pressed, data=E1 in binary 11100001 , high nibble=1110 , low nibble = 0001
char highNibble = (_cardTemp & 0xf0) >>4;
char lowNibble = (_cardTemp & 0x0f);
_bitCount=0;
_cardTemp=0;
_cardTempHigh=0;
if (lowNibble == (~highNibble & 0x0f)) // check if low nibble matches the "NOT" of high nibble.
if (lowNibble==0x0b) // ENT pressed
_code=0x0d;
else if (lowNibble==0x0a) // ESC pressed
_code=0x1b;
_code=(int)lowNibble; // 0 - 9 keys
return true;
// well time over 25 ms and bitCount !=8 , !=26, !=34 , must be noise or nothing then.
_lastWiegand=_sysTick;
_bitCount=0;
_cardTemp=0;
_cardTempHigh=0;
return false;
return false;
Keypad wiegand protocol is very non standard, different manufacturer will use different way.
Someone hacked this code for his 4 bit keypad, try if this is working for you.
WIEGAND::WIEGAND()
	return _code;
	_lastWiegand = 0;
	_cardTempHigh = 0;
	_cardTemp = 0;
	_code = 0;
	_wiegandType = 0;
	_bitCount = 0;
	_sysTick=millis();
		_cardTemp <<=1;
		_cardTemp |= 1;
		_cardTemp <<=1;
		*codelow >>=1;
	return cardID;
	_sysTick=millis();
//		Serial.print("BitCount:");
//		Serial.println(_bitCount);
		if ((_bitCount==26) || (_bitCount==34) || (_bitCount==4)) 	// bitCount for keypress=8, Wiegand 26=26, Wiegand 34=34
			if((_bitCount==26) || (_bitCount==34) )		// wiegand 26 or wiegand 34
				_bitCount=0;
				_cardTemp=0;
				_cardTempHigh=0;
				_code=cardID;
				return true;
			else if (_bitCount==4)		// keypress wiegand
				_bitCount=0;
				_cardTemp=0;
				_cardTempHigh=0;
					//Serial.print("cardTemp:");
					//Serial.print(String(_cardTemp));
					//Serial.print("highNibble:");
					//Serial.print((int)highNibble);
					//Serial.print(" lowNibble:");
					//Serial.println((int)lowNibble);
//				if (lowNibble == (~highNibble & 0x0f))		// check if low nibble matches the "NOT" of high nibble.
//					if (lowNibble==0x0b)					// ENT pressed
//						_code=0x0d;
//					else if (lowNibble==0x0a)				// ESC pressed
//						_code=0x1b;
//					else
					return true;
			_bitCount=0;
			_cardTemp=0;
			_cardTempHigh=0;
			return false;
		return false;
