Good Day All,
I was able to get the following sketch to install into this NodeMCU that I am using to on a train set I am 3D printing for my grandson.
I can connect my android phone to it using WIFI but when I use a web browser and type in the ip address of 192.168.4.1 a message comes up saying the server cannot display the page.
I have never owned a Arduino I am just trying to follow directions to get this working for my grandson.
Please review the sketch and let me know what the problem is.
Thanks
Terry N
- Wifi accesspoitn using NodeMCU and ESP8266.
- This software is provided free and you may use, change and distribute as you like.
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include "TimerObject.h"
#define forward 0
#define backward 1
/* Set these to your desired credentials. */
const char *ssid = "OSRHector";
const char *password = "osrailway";
bool highBeamActive = false;
bool motionActive = false;
bool motionDirection = forward;
int target_speed;
int actual_speed;
int acceleration_step = 5;
int LED_BL2 = 15; // Red light on side 2 GPIO15
int LED_BL1 = 13; // Red light on side 1 GPIO13
int LED_HB2 = 14; // High beam side 2 GPIO12
int LED_HB1 = 12; // High beam side 1 GPIO14
int LED_HDL = 2; //PWM for headlights controlled by motor board
int motor_AIN1 = 5; //GPIO5
int motor_AIN2 = 4; //GPIO4
int motor_PWM = 0; //GPIO0
TimerObject *timer1 = new TimerObject(10);
ESP8266WebServer server(80);
- Server IP address is: http://192.168.4.1
- When you have connected your device to the wifi network, open the browser and enter the IP address above.
void handleRoot() {
- This is the web page sent to the connected device. There are lots of memory available so this page can be made much more complex.
- It uses Ajax to send commands which means the page doesn't need to be reloaded each time a button is pressed. In this way,
- the page can be made much more graphically complex without suffering from long reloading delays.
String html =" <style type="text/css"> body { background: #595B82; } #header { height: 30px; margin-left: 2px; margin-right: 2px; background: #d5dfe2; border-top: 1px solid #FFF; border-left: 1px solid #FFF; border-right: 1px solid #333; border-bottom: 1px solid #333; border-radius: 5px; font-family: "arial-verdana", arial; padding-top: 10px; padding-left: 20px; } #speed_setting { float: right; margin-right: 10px; } #control { height: 200px; margin-top: 4px; margin-left: 2px; margin-right: 2px; background: #d5dfe2; border-top: 1px solid #FFF; border-left: 1px solid #FFF; border-right: 1px solid #333; border-bottom: 1px solid #333; border-radius: 5px; font-family: "arial-verdana", arial; } .button { border-top: 1px solid #FFF; border-left: 1px solid #FFF; border-right: 1px solid #333; border-bottom: 1px solid #333; border-radius: 5px; margin: 5px; text-align: center; float: left; padding-top: 20px; height: 50px; background: #FFF} .long { width: 30%; } .short { width: 100px; } #message_box { float: left; margin-bottom: 0px; width: 100%; } #speed_slider {width: 300px;} <script type="text/javascript"> function updateSpeed(speed) { sendData("updateSpeed?speed="+speed); } function runForward(){ var speed = document.getElementById("speed_slider").value; sendData("run?dir=forward&speed="+speed); } function runBackward(){ var speed = document.getElementById("speed_slider").value; sendData("run?dir=backward&speed="+speed); } function sendData(uri){ var messageDiv = document.getElementById("message_box"); messageDiv.innerHTML = "192.168.4.1/"+uri; var xhr = new XMLHttpRequest(); xhr.open('GET', 'http://192.168.4.1/'+uri); xhr.withCredentials = true; xhr.setRequestHeader('Content-Type', 'text/plain'); xhr.send(); } <div id="header"> OS-Railway Wifi Hectorrail 141 <div id="speed_setting"> Speed <input id="speed_slider" type="range" min="0" max="1023" step="10" value="512" onchange="updateSpeed(this.value)"> <div id="control"> <div id="button_backward" class="button long" onclick="runBackward()"> Run backward <div id="button_stop" class="button long" onclick="updateSpeed(0)"> Stop <div id="button_forward" class="button long" onclick="runForward()"> Run forward <div id="button_light_off" class="button long" onclick="sendData('lightoff')"> Headlight off <div id="button_light_on" class="button long" onclick="sendData('lighton')"> Headlight on <div id="button_emergency" class="button long" onclick="sendData('stop')"> Emergency stop <div id="message_box"> ";
server.send(200, "text/html", html);
void motionControl(){
if(motionActive){
if(actual_speed < target_speed){
actual_speed = actual_speed + acceleration_step;
} else if(actual_speed > target_speed){
actual_speed = actual_speed - acceleration_step;
if(actual_speed > 1023){
actual_speed = 1023;
if(actual_speed < 0){
actual_speed = 0;
analogWrite(motor_PWM, actual_speed);
analogWrite(motor_PWM, 0);
- Motor operation
void motorOperation(){
motionActive = true;
String move_dir = server.arg("dir");
String motion_speed = server.arg("speed");
target_speed = motion_speed.toInt();
//Execute change of direction, but only if actual_speed is below 100, otherwise set target speed to 0 and initiate a slowdown.
if(move_dir == "backward"){
if(motionDirection != backward && actual_speed > 100){
target_speed = 0;
motionDirection = backward;
if(motionDirection != forward && actual_speed > 100){
target_speed = 0;
digitalWrite(motor_AIN1, motionDirection);
digitalWrite(motor_AIN2, !motionDirection);
digitalWrite(LED_BL2, motionDirection);
digitalWrite(LED_BL1, !motionDirection);
if(highBeamActive){
digitalWrite(LED_HB2, motionDirection);
digitalWrite(LED_HB1, !motionDirection);
digitalWrite(LED_HB2, 0);
digitalWrite(LED_HB1, 0);
void updateSpeed(){
void switchLightOn(){
highBeamActive = true;
void switchLightOff(){
void motionStop(){
- SETUP
pinMode(LED_BL2, OUTPUT);
pinMode(LED_BL1, OUTPUT);
pinMode(LED_HB2, OUTPUT);
pinMode(LED_HB1, OUTPUT);
pinMode(LED_HDL, OUTPUT);
pinMode(motor_AIN1, OUTPUT);
pinMode(motor_AIN2, OUTPUT);
pinMode(motor_PWM, OUTPUT);
digitalWrite(LED_BL2, 0);
digitalWrite(LED_BL1, 0);
digitalWrite(motor_AIN1, 0);
digitalWrite(motor_AIN2, 1);
analogWrite(LED_HDL, 1023);
timer1->setOnTimer(&motionControl);
timer1->Start();
WiFi.softAP(ssid, password);
IPAddress myIP = WiFi.softAPIP();
- Here you find the functions that are called when the browser sends commands.
server.on("/", handleRoot);
server.on("/run", motorOperation);
server.on("/stop", motionStop);
server.on("/lighton", switchLightOn);
server.on("/lightoff", switchLightOff);
server.on("/updateSpeed", updateSpeed);
server.begin();
server.handleClient();
timer1->Update();
