WiFi101 Firmware Updater not working with Adafruit Feather M0
I have a new Feather M0 Wifi. I'm following this guide to update the Wifi101 firmware, but when I select the Wifi101 updater in the Arduino IDE, I get a message saying that no supported board is connected. I've followed the guide to the letter up to this point so I'm unsure how to proceed.
This is what I get when I run the WifiFirmwareTest example:
Code: Select all
WiFi101 shield: DETECTED
Firmware version installed: 19.5.4
Latest firmware version available : 19.6.1
Check result: NOT PASSED
 - The firmware version on the shield do not match the
   version required by the library, you may experience
   issues or failures.
The IDE and board libraries are all up to date. Any suggestions?
just use IDE 1. there it works
EDIT: or try to select MKR1000 in Tools menu
Thanks! IDE 1 works. I tried MKR1000 in the Tools menu on IDE 2 and that didn't work.
Using IDE 2.2.1 still does not work (not even MKR1000)
