I am trying to setup the RN171 to receive data from a web client. That is I want to create a web server on the RN171. So that I can load the HTML code from a browser and send data via the browser to the WiFi module.
I can't figure out how to do this. Has anyone done this. I have read through the manual but doesn't offer any help pertaining to this.
No link to the hardware! Although I know what the RN171 is and have worked with it in the past, I don't have the datasheet ready. You have to supply that information.
Have you tried the WiFly family of libraries? Where did you buy the hardware? Didn't they link to a library they suggest? Doesn't that library offer a web server example?
The module datasheet is attached. The code that I found is attached.
Also it key to note that I am not using an Arduino I am try to use code from the libraries provided by the Arduino to write my own driver code. But I am little confused how they setup the web server. I can't find where there sending the specific commands to the RN171 to set it up as a web server.
Also the other thing I want to do is resubmit data from the web client (browser) using a form.
Ok I think I found a code set that was better written. This is much more portable than the one presented below. All i need to do is write a wrapper function for my serial calls and timer.
I don't want to run this on Arduino. I am running this on a Xilinx Spartan 6 running a microblaze. I came to this forum because i know alot person use this in the Arduino community. But the code set I found for arduino was not easily portable. This set of codes are.
Also the I am running this on top an RTOS and the. I'll just create a wrapper function for the serial calls they have. And replace all the memory allocation with RTOS specific memory allocation.
