Continued from
The newly-created WiFiMulti-related examples in WiFiMulti demonstrate how to use the new WiFiMulti_Generic library to connect to the best of multi-WiFi APs, with auto-checking / auto-reconnecting features when WiFi connection is lost.
Releases v1.8.0
- Add WiFiMulti_Generic library support
- Add many WiFiMulti-related examples in WiFiMulti
- Update
Packages' Patches
Releases v1.7.0
- Fix issue with Portenta_H7 core v2.7.2+. Check [Portenta_H7] WiFi WebServer extremely slow from core v2.7.2 - v3.0.1 #441
- Rewrite to avoid
multiple-definitionslinker error for multiple-file project - Add example multiFileProject to demo how to avoid
multiple-definitionslinker error for multiple-file project - Update
Packages' Patches
Debug Terminal Sample
1. AdvancedWebServer_WiFiMulti on Nano RP2040 Connect with WiFiNINA
The following are debug terminal output and screen shot when running example AdvancedWebServer_WiFiMulti on Nano RP2040 Connect with WiFiNINA using WiFiNINA_Generic Library
Starting AdvancedWebServer_WiFiMulti on Nano RP2040 Connect with WiFiNINA using WiFiNINA_Generic Library
WiFiMulti_Generic v1.1.1
WiFiWebServer v1.8.0
Connecting WiFi...
WiFi connected, IP address: 192.168.2.113
You're connected to the network, IP = 192.168.2.113
SSID: HueNet1, Signal strength (RSSI):-20 dBm
HTTP server started @ 192.168.2.113
H
