Wifly and Arduino
Hello!
I am connecting my Arduino Uno with a Wifly shield, but i have a problem.
When I do a request ("URLSERVER/request") this is sended without problem. But only the first request.
Example: 192.168.169.3/Hello
When i do a second request, my program is disconnected from the server.
Example: 192.168.169.3/Hello2
Any idea?
#include "WiFly.h"
#include "Credentials.h"
byte server[] = { 192, 168, 169, 3 };
Client client("192.168.169.3", 80);
// the setup routine runs once when you press reset:
  connectToWiFi();
  startClient();
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  if (!client.connected()) {
    Serial.println("disconnecting...");
    client.stop();
void connectToWiFi() {
    Serial.println("Beginning...");
    WiFly.begin();
    Serial.println("Finished beginning");
   (WiFly.join("Tests"));
void startClient() {
  Serial.println("Connecting...");
  if (client.connect()) {
    Serial.println("Connected");
    Serial.print("IP: ");
    Serial.println(WiFly.ip());
    Serial.println("Connection failed");
EDIT: PROBLEM SOLVED.
