Will my PS2 keyboard library work? I don't own an arduino device yet
Hi all,
I'm working on a personal project to use an Arduino Nano V3 (clone) as a PS2 Keyboard driver.
I know there are many libraries available for use, but I'd like to script my own so I can understand what's going on under the hood. That's how I like to learn things...
So I went off to the keyboards/keypads section of the playground
(Arduino Playground - PS2Keyboard)
Where I came across one written by Christian Weichel
Version History
002
Attach:PS2Keyboard002.zip
This library is at a very early stage. If anyone wants to revise/rewrite it, feel free to do so (published under the LGPL).
https://playground.arduino.cc/uploads/Main/PS2Keyboard002/index.zip
It was exactly what I was seeking, something at an early stage and not packed with C++ code which I don't understand, since I only really know BASIC language.
So I added the bits necessary to bring it half way to completion, and its compiled without errors, but I would love to know if it would work or not, currently I don't own any Arduino devices, so if someone could test it for me or look at the code and pinpoint any issues, that would be super...
I guess also that in the method listed above, I need to add code to transmit the asci code out to the host, but I'll have to research into that as i haven't reached that point yet.
My code is attached below, Thanks
The device I aim to use is the Arduino Nano 3 clone
(USB Nano V3.0 ATmega328 16M 5V Micro-controller CH340G board For Arduino)
This is the main program/sketch
  _JD_ASCIKEYCODES_
  Define supported asci keys
#ifndef _JD_ASCIKEYCODES_
  #include "JD_AsciKeyCodes.h"
#endif
  _JD_PS2SCANCODES_
  Define supported PS2 keyboard scancodes
#ifndef _JD_PS2SCANCODES_
  #include "JD_PS2ScanCodes.h"
#endif
  Define KeyTable Array - KeyTbl[x,y]
  This will be our lookup table
  Currently contains 69 key/value items for 69 pairs of keys/values
#define PS2_LUT_Items 69
byte KeyTbl[2][69] = {SC1M_A, KEY_LCA, SC1M_B, KEY_LCB, SC1M_C, KEY_LCC, SC1M_D, KEY_LCD, SC1M_E, KEY_LCE, SC1M_F, KEY_LCF, SC1M_G, KEY_LCG, SC1M_H, KEY_LCH,
SC1M_I, KEY_LCI, SC1M_J, KEY_LCJ, SC1M_K, KEY_LCK, SC1M_l, KEY_LCL, SC1M_M, KEY_LCM, SC1M_N, KEY_LCN, SC1M_O, KEY_LCO, SC1M_P, KEY_LCP, SC1M_Q, KEY_LCQ, SC1M_R,
KEY_LCR, SC1M_S, KEY_LCS, SC1M_T, KEY_LCT, SC1M_U, KEY_LCU, SC1M_V, KEY_LCV, SC1M_W, KEY_LCW, SC1M_X, KEY_LCX, SC1M_Y, KEY_LCY, SC1M_Z, KEY_LCZ, SC1M_0, KEY_0,
SC1M_1, KEY_1, SC1M_2, KEY_2, SC1M_3, KEY_3, SC1M_4, KEY_4, SC1M_5, KEY_5, SC1M_6, KEY_6, SC1M_7, KEY_7, SC1M_8, KEY_8, SC1M_9, KEY_9, SC1M_SPACE, KEY_SPACE,
SC1M_BKSLASH, KEY_BACKSLASH, SC1M_FWDSLASH, KEY_FWDSLASH, SC1M_APOSTROPHE, KEY_APOSTROPHE, SC1M_COMMA, KEY_COMMA, SC1M_PERIOD, KEY_PERIOD, SC1M_SEMICOLON,
KEY_SEMICOLON, SC1M_MINUS, KEY_MINUS, SC1M_EQUALS, KEY_EQUALS, SC1M_OSQRPARENS, KEY_OSQRPAR, SC1M_CSQRPARENS, KEY_CSQRPAR, SC1M_BACKTICK, KEY_BACKTICK,
SC1M_KP0, KEY_0, SC1M_KP1, KEY_1, SC1M_KP2, KEY_2, SC1M_KP3, KEY_3, SC1M_KP4, KEY_4, SC1M_KP5, KEY_5, SC1M_KP6, KEY_6, SC1M_KP7, KEY_7, SC1M_KP8, KEY_8,
SC1M_KP9, KEY_9, SC1M_KPPLUS, KEY_PLUS, SC1M_KPMINUS, KEY_MINUS, SC1M_KPMULTIPLY, KEY_MULTIPLY, SC1M_KPPERIOD, KEY_PERIOD, SC2M_KPDIVIDE, KEY_DIVIDE,
SC2M_KPENTER, KEY_ENTER, SC1M_TAB, KEY_TAB, SC1M_ESCAPE, KEY_ESCAPE, SC1M_ENTER, KEY_ENTER, SC1M_BKSPC, KEY_BACKSPACE, SC2M_DEL, KEY_DELETE};
  This PIN is hardcoded in the init routine later on.
  If you change this make sure you change the interrupt initialization as well.
#define PS2_INT_PIN 3
    Driver System Variables
    The variables below are used for internal management of the driver.
    PLEASE DO NOT REFER TO THESE VARIABLES IN YOUR CODE AS THEY MIGHT VANISH ONE DAY!.
  int JD_PS2DataPin;               // A variable to hold the PS2 comms datapin id (mcu to ps2 device - sda)
  byte JD_PS2Buf[8];               // An 8 byte buffer to store keypresses which have not yet been read by the host
  byte JD_PS2BufHead;              // The current position in the buffer
  byte JD_PS2BufTail;              // The current position in the buffer
  byte JD_PS2BufFull;              // Flag that signifiesbuffer is full
  byte JD_PS2IntPos;               // The current bit position in the interrupt io buffer
  byte JD_PS2IntByte;              // Current byte in intterupt input buffer
  byte JD_PS2Byte2Dcd;             // Byte to be decoded
  byte JD_PS2BreakActive;          // whether the mcu is in break mode or not?
  volatile byte JD_PS2IntBuf;      // The single byte character buffer accessed within the interrupt method
    PS2_IsrOn3()
    The ISR for the external interrupt
  void PS2_IsrOn3() {
    noInterrupts();
    int value = digitalRead(JD_PS2DataPin);    // Current state of PS2 interface sda pin
    if(JD_PS2IntPos > 0 && JD_PS2IntPos < 9) {
      JD_PS2IntBuf |= (value << (JD_PS2IntPos - 1));
    // else
      // this is a start bit, parity bit or stop bit - so we skip it
    JD_PS2IntPos++;
    if(JD_PS2IntPos == 11) {
      if(JD_PS2IntBuf == SC2M_PAUSE){
        JD_PS2BreakActive = true;
      } else if(JD_PS2BreakActive) {
        JD_PS2BreakActive = false;
        JD_PS2IntByte = JD_PS2IntBuf;
        if (!(JD_PS2BufHead == JD_PS2BufTail)) {
          // add key to buffer and advance
          JD_PS2Buf[JD_PS2BufTail] = JD_PS2IntByte;
          JD_PS2BufTail++;
          if (JD_PS2BufTail > 7) {
            JD_PS2BufTail = 0;
          // key buffer is full
          JD_PS2BufFull = true;
      JD_PS2IntBuf = 0;
      JD_PS2IntPos = 0;
      interrupts();
      return;
  Class clsJD_PS2Keyboard
  Complete class for handling PS2 keyboard input
class clsJD_PS2Keyboard {
  private:
      PS2_InitProgVars
      Initialises program variables
    void PS2_InitProgVars(byte pbDataPin) {
      byte tmpRtn;
      JD_PS2DataPin = pbDataPin;        // Assign data io pin-id
      JD_PS2BufHead = 0;                // Set buffer head to first byte position
      JD_PS2BufTail = 0;                // Set buffer tail to first byte position
      JD_PS2BufFull = false;            // Set buffer full flag to false
      JD_PS2IntPos = 0;                 // Set io bit postion in comms frame to first bit
      JD_PS2IntBuf = 0;                 // Clear interrupt byte buffer to zero
      JD_PS2IntByte = 0;                // Clear interrupt final byte value to null
      JD_PS2Byte2Dcd = 0;               // Clear vyte to decode var
      for (tmpRtn = 0; tmpRtn < 8; tmpRtn++) {
        JD_PS2Buf[tmpRtn] = 0;
      PS2_DecodeKey
      Decodes the scancode into an asci key code or 0 on failiure
    byte PS2_DecodeKey() {
      byte tmpRtn;
      byte tmpScId;
      tmpRtn = 0;
      for (tmpScId = 0; tmpScId <= 69; tmpScId++) {
        if (KeyTbl[0][tmpScId] == JD_PS2Byte2Dcd) {
          tmpRtn = KeyTbl[1][tmpScId];
          return tmpRtn;
  public:
      Begin()
      The entry point
    void Begin(byte pbDataPin) {
      PS2_InitProgVars(pbDataPin);
      pinMode(PS2_INT_PIN, INPUT_PULLUP);
      attachInterrupt(digitalPinToInterrupt(PS2_INT_PIN), PS2_IsrOn3, CHANGE);
      PS2_HasKey()
      A function which returns whether a key (press) exists in the keyboard keys buffer.
      it will only advance through keyboard buffer if no key is found.
      Returns:  True - a key exists in the buffer
                False - No keys exist in keyboard keys buffer or keyboard keys buffer is empty
    byte PS2_HasKey() {
      return (!(JD_PS2BufHead == JD_PS2BufTail));
      PS2_GetKey()
      A function to return the key at the current position in the keyboard keys buffer.
      Returns:  Key - The key from the buffer (if one exists)
                0   - Returns 0 if keyboard keys buffer is empty
    byte PS2_GetKey() {
      byte tmpRtn;
      tmpRtn = 0;
      if (!(JD_PS2BufHead == JD_PS2BufTail)){
        JD_PS2Byte2Dcd = JD_PS2Buf[JD_PS2BufHead];
        tmpRtn = PS2_DecodeKey();
        JD_PS2BufHead++;
        if (JD_PS2BufHead > 7){
          JD_PS2BufHead = 0;
      return tmpRtn;
      PS2_BufferFull()
      A function which returns whether the buffer is full or not
      Returns:  True - When the buffer is full
                False - When the buffer has free space
    byte PS2_BufferFull() {
      return JD_PS2BufFull;
clsJD_PS2Keyboard JD_PS2;
  JD_PS2.Begin(11);
  if(JD_PS2.PS2_HasKey() == true){
    byte ascikey = JD_PS2.PS2_GetKey();
    // send ascikey out through an output pin to host
    // to be completed
This is the ascii keys definition include file
  JD_PS2Keyboard - PS 2Keyboard Driver
  Copyright (c) 2021 Jaan Doh.  All rights reserved.
  Written by Jaan Doh <jaan.doh.786@gmail.com>
  This code module: Include file containing asci key codes supported by this program
  This code file: JD_AsciKeyCodes.h
  This program/library is a fork from PS2Keyboard_002 originally written by Christian Weichel <info@32leaves.net>.
    PS2Keyboard.h - PS2Keyboard library
    Copyright (c) 2007 Free Software Foundation.  All rights reserved.
    Written by Christian Weichel <info@32leaves.net>
    Url: https://playground.arduino.cc/Main/PS2Keyboard/
    Source Url: https://playground.arduino.cc/uploads/Main/PS2Keyboard002/index.zip
  This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General
  Public License as published by the Free Software Foundation;
  either version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied
  warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
  See the GNU Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public License along with this library;
    If not, write to:
    The Free Software Foundation, Inc.,
    51 Franklin St,
    Fifth Floor,
    Boston,
    MA  02110-1301
    USA
  #define _JD_ASCIKEYCODES_
  // '=> [START] JD ASCI KEY DEFINITIONS
  //'-> [Start] Asci Key Codes - Non Visible Keys [5]
  const byte KEY_BACKSPACE = 8;        // 'Back-Space
  const byte KEY_TAB = 9;              // 'Tab
  const byte KEY_LINEFEED = 10;        // 'Line-Feed
  const byte KEY_ENTER = 13;           // 'Enter
  const byte KEY_ESCAPE = 27;          // 'Escape
  const byte KEY_DELETE = 127;         // 'Delete
  // '-> [Start] Asci Key Codes - Visible Keys [96]
  const byte KEY_SPACE = 32;           // 'Space
  const byte KEY_EXCLAIM = 33;         // '!
  const byte KEY_DBLQUOTE = 34;        // '"
  const byte KEY_HASH = 35;            // '#
  const byte KEY_DOLLAR= 36;           // '$
  const byte KEY_PERCENT = 37;         // '%
  const byte KEY_AMPERSAND = 38;       // '&
  const byte KEY_APOSTROPHE = 39;      // ''
  const byte KEY_OBRACKET = 40;        // '(
  const byte KEY_CBRACKET = 41;        // ')
  const byte KEY_MULTIPLY = 42;        // '*
  const byte KEY_PLUS = 43;            // '+
  const byte KEY_COMMA = 44;           // ',
  const byte KEY_MINUS = 45;           // '-
  const byte KEY_PERIOD = 46;          // '.
  const byte KEY_DIVIDE = 47;          // '/
  const byte KEY_FWDSLASH = 47;        // '/
  const byte KEY_0 = 48;               // '0
  const byte KEY_1 = 49;               // '1
  const byte KEY_2 = 50;               // '2
  const byte KEY_3 = 51;               // '3
  const byte KEY_4 = 52;               // '4
  const byte KEY_5 = 53;               // '5
  const byte KEY_6 = 54;               // '6
  const byte KEY_7 = 55;               // '7
  const byte KEY_8 = 56;               // '8
  const byte KEY_9 = 57;               // '9
  const byte KEY_COLON = 58;           // ':
  const byte KEY_SEMICOLON = 59;       // ';
  const byte KEY_LESSTHAN = 60;        // '<
  const byte KEY_EQUALS = 61;          // '=
  const byte KEY_MORETHAN = 62;        // '>
  const byte KEY_QUESTION = 63;        // '?
  const byte KEY_ATSYMBOL = 64;        // '@
  const byte KEY_UCA = 65;             // 'A
  const byte KEY_UCB = 66;             // 'B
  const byte KEY_UCC = 67;             // 'C
  const byte KEY_UCD = 68;             // 'D
  const byte KEY_UCE = 69;             // 'E
  const byte KEY_UCF = 70;             // 'F
  const byte KEY_UCG = 71;             // 'G
  const byte KEY_UCH = 72;             // 'H
  const byte KEY_UCI = 73;             // 'I
  const byte KEY_UCJ = 74;             // 'J
  const byte KEY_UCK = 75;             // 'K
  const byte KEY_UCL = 76;             // 'L
  const byte KEY_UCM = 77;             // 'M
  const byte KEY_UCN = 78;             // 'N
  const byte KEY_UCO = 79;             // 'O
  const byte KEY_UCP = 80;             // 'P
  const byte KEY_UCQ = 81;             // 'Q
  const byte KEY_UCR = 82;             // 'R
  const byte KEY_UCS = 83;             // 'S
  const byte KEY_UCT = 84;             // 'T
  const byte KEY_UCU = 85;             // 'U
  const byte KEY_UCV = 86;             // 'V
  const byte KEY_UCW = 87;             // 'W
  const byte KEY_UCX = 88;             // 'X
  const byte KEY_UCY = 89;             // 'Y
  const byte KEY_UCZ = 90;             // 'Z
  const byte KEY_OSQRPAR = 91;         // '[
  const byte KEY_BACKSLASH = 92;       // '\\ had to write backslash twice for some mad reason
  const byte KEY_CSQRPAR = 93;         // ']
  const byte KEY_CARAT = 94;           // '^
  const byte KEY_UNDERSCORE = 95;      // '_
  const byte KEY_BACKTICK = 96;        // '`
  const byte KEY_LCA = 97;             // 'a
  const byte KEY_LCB = 98;             // 'b
  const byte KEY_LCC = 99;             // 'c
  const byte KEY_LCD = 100;            // 'd
  const byte KEY_LCE = 101;            // 'e
  const byte KEY_LCF = 102;            // 'f
  const byte KEY_LCG = 103;            // 'g
  const byte KEY_LCH = 104;            // 'h
  const byte KEY_LCI = 105;            // 'i
  const byte KEY_LCJ = 106;            // 'j
  const byte KEY_LCK = 107;            // 'k
  const byte KEY_LCL = 108;            // 'l
  const byte KEY_LCM = 109;            // 'm
  const byte KEY_LCN = 110;            // 'n
  const byte KEY_LCO = 111;            // 'o
  const byte KEY_LCP = 112;            // 'p
  const byte KEY_LCQ = 113;            // 'q
  const byte KEY_LCR = 114;            // 'r
  const byte KEY_LCS = 115;            // 's
  const byte KEY_LCT = 116;            // 't
  const byte KEY_LCU = 117;            // 'u
  const byte KEY_LCV = 118;            // 'v
  const byte KEY_LCW = 129;            // 'w
  const byte KEY_LCX = 120;            // 'x
  const byte KEY_LCY = 121;            // 'y
  const byte KEY_LCZ = 122;            // 'z
  const byte KEY_OCLYPAR = 123;        // '{
  const byte KEY_PIPE = 124;           // '|
  const byte KEY_CLYPAR = 125;         // '}
  const byte KEY_TILDE = 126;          // '~
  // '-> [Finish] Asci Key Codes - Total key codes [101]
  // '=> [FINISH] JD ASCI KEY DEFINITIONS
#endif
This is the scancodes include file
  This code module: Include file containing ps2 scancode set 2 keymake/keybreak scancodes
  This code file: JD_PS2ScanCodes.cpp
    If not, write to:
    51 Franklin St,
    Fifth Floor,
    Boston,
    MA  02110-1301
    USA
  #define _JD_PS2SCANCODES_
  // '=> [START] JD SCANCODE MAKE-KEY SCANCODES
  //'-> [Start] Single Byte Make-Key Scan Codes - Aphabetic keys [26]
  const byte SC1M_A = 0x1C;             // 'A
  const byte SC1M_B = 0x32;             // 'B
  const byte SC1M_C = 0x21;             // 'C
  const byte SC1M_D = 0x23;             // 'D
  const byte SC1M_E = 0x24;             // 'E
  const byte SC1M_F = 0x2B;             // 'F
  const byte SC1M_G = 0x34;             // 'G
  const byte SC1M_H = 0x33;             // 'H
  const byte SC1M_I = 0x43;             // 'I
  const byte SC1M_J = 0x3B;             // 'J
  const byte SC1M_K = 0x42;             // 'K
  const byte SC1M_l = 0x4B;             // 'L
  const byte SC1M_M = 0x3A;             // 'M
  const byte SC1M_N = 0x31;             // 'N
  const byte SC1M_O = 0x44;             // 'O
  const byte SC1M_P = 0x4D;             // 'P
  const byte SC1M_Q = 0x15;             // 'Q
  const byte SC1M_R = 0x2D;             // 'R
  const byte SC1M_S = 0x1B;             // 'S
  const byte SC1M_T = 0x2C;             // 'T
  const byte SC1M_U = 0x3C;             // 'U
  const byte SC1M_V = 0x2A;             // 'V
  const byte SC1M_W = 0x1D;             // 'W
  const byte SC1M_X = 0x22;             // 'X
  const byte SC1M_Y = 0x35;             // 'Y
  const byte SC1M_Z = 0x1A;             // 'Z
  // '-> [Start] Single Byte Make-Key Scan Codes - Numeric keys [10]
  const byte SC1M_0 = 0x45;             // '0
  const byte SC1M_1 = 0x16;             // '1
  const byte SC1M_2 = 0x1E;             // '2
  const byte SC1M_3 = 0x26;             // '3
  const byte SC1M_4 = 0x25;             // '4
  const byte SC1M_5 = 0x2E;             // '5
  const byte SC1M_6 = 0x36;             // '6
  const byte SC1M_7 = 0x3D;             // '7
  const byte SC1M_8 = 0x3E;             // '8
  const byte SC1M_9 = 0x46;             // '9
  // '-> [Start] Single Byte Make-Key Scan Codes - Visible Mixed keys [12]
  const byte SC1M_SPACE = 0x29;         // 'Space
  const byte SC1M_BKSLASH = 0x5D;       // 'Backslash
  const byte SC1M_FWDSLASH = 0x4A;      // 'Fwd Slash
  const byte SC1M_APOSTROPHE = 0x52;    // 'Apostrophe
  const byte SC1M_COMMA = 0x41;         // 'Comma
  const byte SC1M_PERIOD = 0x49;        // 'Period
  const byte SC1M_SEMICOLON = 0x4C;     // 'Semicolon
  const byte SC1M_MINUS = 0x4E;         // 'Minus
  const byte SC1M_EQUALS = 0x55;        // 'Equals
  const byte SC1M_OSQRPARENS = 0x54;    // '[
  const byte SC1M_CSQRPARENS = 0x5B;    // ']
  const byte SC1M_BACKTICK = 0x0E;      // 'BackTick
  // '-> [Start] Single Byte Make-Key Scan Codes - Non-Visible Mixed keys [11]
  const byte SC1M_LSHIFT = 0x12;        // 'L-shift
  const byte SC1M_RSHIFT = 0x59;        // 'Rshift
  const byte SC1M_CAPSLOCK = 0x58;      // 'CapsLock
  const byte SC1M_LALT = 0x11;          // 'L-alt
  const byte SC1M_LCTRL = 0x14;         // 'L-Ctrl
  const byte SC1M_ESCAPE = 0x76;        // 'Escape
  const byte SC1M_TAB = 0x0D;           // 'Tab
  const byte SC1M_ENTER = 0x5A;         // 'Enter
  const byte SC1M_BKSPC = 0x66;         // 'Backspace
  const byte SC1M_NUMLOCK = 0x77;       // 'Num Lock
  const byte SC1M_SCRLOCK = 0x7E;       // 'Scroll Lock
  // '-> [Start] Single Byte Make-Key Scan Codes - Keypad keys [14]
  const byte SC1M_KP0 = 0x70;           // 'KP 0
  const byte SC1M_KP1 = 0x69;           // 'KP 1
  const byte SC1M_KP2 = 0x72;           // 'KP 2
  const byte SC1M_KP3 = 0x7A;           // 'KP 3
  const byte SC1M_KP4 = 0x6B;           // 'KP 4
  const byte SC1M_KP5 = 0x73;           // 'KP 5
  const byte SC1M_KP6 = 0x74;           // 'KP 6
  const byte SC1M_KP7 = 0x6C;           // 'KP 7
  const byte SC1M_KP8 = 0x75;           // 'KP 8
  const byte SC1M_KP9 = 0x7D;           // 'KP 9
  const byte SC1M_KPPLUS = 0x79;        // 'KP Plus
  const byte SC1M_KPMINUS = 0x7B;       // 'KP Minus
  const byte SC1M_KPMULTIPLY = 0x7C;    // 'KP Multiply
  const byte SC1M_KPPERIOD = 0x71;      // 'KP Period
  // '-> [Start] Double Byte Make-Key Scan Codes - Supported keys [16] - Note: Leading *0xE0* has been stripped out
  const byte SC2M_HOME = 0x6C;          // 'Home
  const byte SC2M_END = 0x69;           // 'End
  const byte SC2M_INS = 0x70;           // 'Insert
  const byte SC2M_DEL = 0x71;           // 'Delete
  const byte SC2M_PGUP = 0x7D;          // 'Page Up
  const byte SC2M_PGDN = 0x7A;          // 'Page Down
  const byte SC2M_LEFT = 0x6B;          // 'Csr Left
  const byte SC2M_RIGHT = 0x74;         // 'Csr Right
  const byte SC2M_UP = 0x75;            // 'Csr Up
  const byte SC2M_DOWN = 0x72;          // 'Csr Down
  const byte SC2M_KPDIVIDE = 0x4A;      // 'KP Divide
  const byte SC2M_KPENTER = 0x5A;       // 'KP Enter
  const byte SC2M_LGUI = 0x1F;          // 'LGui
  const byte SC2M_RGUI = 0x27;          // 'RGui
  const byte SC2M_RALT = 0x11;          // 'RAlt
  const byte SC2M_RCTRL = 0x14;         // 'RCtrl
  // '-> [Start] Double Byte Make-Key Scan Codes - Multumedia keys [9] - Note: Leading *0xE0* has been stripped out
  // These are currently not supported
  // const byte SC2M_MMPLAY = 0x34;     // 'MM Play/Pause
  // const byte SC2M_MMSTOP = 0x3B;     // 'MM Stop
  // const byte SC2M_MMPRVTRK = 0x15;   // 'MM Prev Track
  // const byte SC2M_MMNXTTRK = 0x4D;   // 'MM Next Track
  // const byte SC2M_MMSELTRK = 0x50;   // 'MM Select
  // const byte SC2M_MMVOLUP = 0x32;    // 'MM Vol Up
  // const byte SC2M_MMVOLDN = 0x21;    // 'MM Vol Down
  // const byte SC2M_MMVOLMUTE = 0x23;  // 'MM Mute
  // const byte SC2M_MMCALC = 0x2B;     // 'MM calculator
  // '-> [Start] Double Byte Make-Key Scan Codes - Web keys [9] - Note: Leading *0xE0* has been stripped out
  // const byte SC2M_WEBHOME = 0x3A;    // 'Web Home
  // const byte SC2M_WEBSEARCH = 0x10;  // 'Web Search
  // const byte SC2M_WEBFAVS = 0x18;    // 'Web Favourites
  // const byte SC2M_WEBREFRESH = 0x20; // 'Web Refresh
  // const byte SC2M_WEBSTOP = 0x28;    // 'Web Stop
  // const byte SC2M_WEBFWD = 0x30;     // 'Web Forward
  // const byte SC2M_WEBBACK = 0x38;    // 'Web Back
  // const byte SC2M_WEBEMAIL = 0x48;   // 'Web Email
  // '-> [Start] Double Byte Make-Key Scan Codes - Miscellaneous keys [9] - Note: Leading *0xE0* has been stripped out
  // 'const byte SC2M_APPS = 0x2F;      // 'Apps
  // 'const byte SC2M_MYPC = 0x40;      // 'MyComputer
  // 'const byte SC2M_POWER = 0x37;     // 'Acpi Power
  // 'const byte SC2M_SLEEP = 0x3F;     // 'Acpi Sleep
  // 'const byte SC2M_WAKE = 0x5E;      // 'ACPI Wake
  const byte SC2M_PAUSE = 0xE1;         // Only first byte is used
  // const byte SC2M_PAUSE = 0xE1, 0x14, 0x77, 0xE1, 0xF0, 0x14, 0xF0, 0x77;                    // 'Pause Pressed
  // 'const byte SC2M_PRINTSCREEN = 0xE0, 0x12, 0xE0, 0x7C 0xE0, 0xF0, 0x7C, 0xE0, 0xF0, 0x12;   // 'Print Screen
  // '-> [Start] Double Byte Make-Key Scan Codes - Function keys [12] - Note: Leading *0xE0* has been stripped out
  const byte SC1M_F1 = 0x05;            // 'F1
  const byte SC1M_F2 = 0x06;            // 'F2
  const byte SC1M_F3 = 0x04;            // 'F3
  const byte SC1M_F4 = 0x0C;            // 'F4
  const byte SC1M_F5 = 0x03;            // 'F5
  const byte SC1M_F6 = 0x0B;            // 'F6
  const byte SC1M_F7 = 0x83;            // 'F7
  const byte SC1M_F8 = 0x0A;            // 'F8
  const byte SC1M_F9 = 0x01;            // 'F9
  const byte SC1M_F10 = 0x09;           // 'F10
  const byte SC1M_F11 = 0x78;           // 'F11
  const byte SC1M_F12 = 0x07;           // 'F12
  // '=> [FINSIH] JD SCANCODE MAKE-KEY SCANCODES
  #endif
Thanks
Hopefully one of our members will assist with testing as you requested; but what if it does not work? What then?
I think this is the first time anyone wrote code but did not have an Arduino; maybe my memory fails me, but I can remember students writing code which would be tested at school because they were not permitted to take stuff home.
Maybe this Arduino simulator would assist you better:
https://wokwi.com/
You should really keep all your questions about this project in one thread. Here's the other one:
https://forum.arduino.cc/t/noobie-question-regarding-hardware-hardware-compatibility/938888/14
Hi mrburnette,
Thank you, I wasn't aware there's a simulator, that's super, thank you for the help.
Hi aarg,
I placed the question here because its a different topic (programming not hardware) , but I still think its a good idea to keep all the project stuff together, so I'll add a link to this topic from the old one. Thanks.
