Can't connect PS2 controller with Genuino 101
Hi there,
using the PS2X_lib.h to do the job without success.
Error: 'portInputRegister' was not declared in this scope.
Within PS2X_lib.cpp, portInputRegister is on line 207, appears to be the first time used within the code there:
#ifdef __AVR__
  _clk_mask = digitalPinToBitMask(clk);
  _clk_oreg = portOutputRegister(digitalPinToPort(clk));
  _cmd_mask = digitalPinToBitMask(cmd);
  _cmd_oreg = portOutputRegister(digitalPinToPort(cmd));
  _att_mask = digitalPinToBitMask(att);
  _att_oreg = portOutputRegister(digitalPinToPort(att));
  _dat_mask = digitalPinToBitMask(dat);
  _dat_ireg = portInputRegister(digitalPinToPort(dat));
#else
#ifdef ESP8266
  _clk_pin = clk;
  _cmd_pin = cmd;
  _att_pin = att;
  _dat_pin = dat;
#else
  uint32_t            lport;                   // Port number for this pin
  lport = digitalPinToPort(clk);
  _clk_lport_set = portOutputRegister(lport) + 2;
  _clk_lport_clr = portOutputRegister(lport) + 1;
  lport = digitalPinToPort(cmd);
  _cmd_lport_set = portOutputRegister(lport) + 2;
  _cmd_lport_clr = portOutputRegister(lport) + 1;
  lport = digitalPinToPort(att);
  _att_lport_set = portOutputRegister(lport) + 2;
  _att_lport_clr = portOutputRegister(lport) + 1;
  _dat_lport = portInputRegister(digitalPinToPort(dat));
#endif
So it looks that for the Genuino the third block after the last "else" is the one. But does that make sense? Any further configuration needed for the Genuino?
Sincerely.
Please provide details of that library; there seem to be a few floating around on the web and the one that I looked at is different from what you showed.
There is a very good chance that the library that you're using is not compatible with your Genuino 101 board.
right, there are several out there. Here's the link to the one in question:
Arduino-PS2X/PS2X_lib at master · madsci1016/Arduino-PS2X · GitHub
Other versions called directly avr/io.h, which lead to an error that says avr/io.h is not available (i guess Genuino is not AVR based). But this one had an if statement.
#ifdef __AVR__
  // AVR
  #include <avr/io.h>
+Edit to the first message:
portInputRegister(digitalPinToPort(dat)) appears in the .cpp file as well under AVR (so twice in code, not once), but the second, i.e. line 207 looks to be the one behind the error generation.
I hope it can be made compatible to Genuino somehow - newbie here :slight_smile:
Many thanks.
The following will work from a compiling perspective; I don't have the Arduino101 and I do not have a PS2 controller so can't test and therefore the rest is up to you.
I looked at the library and did notice that the EP8266 functions for the library use the standard pinMode() and digitalWrite() / digitalRead() functions instead of the lower level stuff that AVR and "other".
Next I looked at compile for the Arduino101 which uses a define for __ARDUINO_ARC__ just like the compile for the ESP8266 uses a define for ESP8266.
If you replace, in the .h and .cpp file of the library, every #ifdef ESP8266 by #if defined (ESP8266) || defined (__ARDUINO_ARC__), the compilation will result in behaviour like for the ESP8266.
PS2_lib.cpp
#include "PS2X_lib.h"
#include <math.h>
#include <stdio.h>
#include <stdint.h>
#ifdef __AVR__
#include <avr/io.h>
#endif
#if ARDUINO > 22
  #include "Arduino.h"
#else
  #include "WProgram.h"
  #include "pins_arduino.h"
#endif
static byte enter_config[]={0x01,0x43,0x00,0x01,0x00};
static byte set_mode[]={0x01,0x44,0x00,0x01,0x03,0x00,0x00,0x00,0x00};
static byte set_bytes_large[]={0x01,0x4F,0x00,0xFF,0xFF,0x03,0x00,0x00,0x00};
static byte exit_config[]={0x01,0x43,0x00,0x00,0x5A,0x5A,0x5A,0x5A,0x5A};
static byte enable_rumble[]={0x01,0x4D,0x00,0x00,0x01};
static byte type_read[]={0x01,0x45,0x00,0x5A,0x5A,0x5A,0x5A,0x5A,0x5A};
boolean PS2X::NewButtonState() {
  return ((last_buttons ^ buttons) > 0);
boolean PS2X::NewButtonState(unsigned int button) {
  return (((last_buttons ^ buttons) & button) > 0);
boolean PS2X::ButtonPressed(unsigned int button) {
  return(NewButtonState(button) & Button(button));
boolean PS2X::ButtonReleased(unsigned int button) {
  return((NewButtonState(button)) & ((~last_buttons & button) > 0));
boolean PS2X::Button(uint16_t button) {
  return ((~buttons & button) > 0);
unsigned int PS2X::ButtonDataByte() {
   return (~buttons);
byte PS2X::Analog(byte button) {
   return PS2data[button];
unsigned char PS2X::_gamepad_shiftinout (char byte) {
   unsigned char tmp = 0;
   for(unsigned char i=0;i<8;i++) {
      if(CHK(byte,i)) CMD_SET();
      else CMD_CLR();
      CLK_CLR();
      delayMicroseconds(CTRL_CLK);
      //if(DAT_CHK()) SET(tmp,i);
      if(DAT_CHK()) bitSet(tmp,i);
      CLK_SET();
#if CTRL_CLK_HIGH
      delayMicroseconds(CTRL_CLK_HIGH);
#endif
   CMD_SET();
   delayMicroseconds(CTRL_BYTE_DELAY);
   return tmp;
void PS2X::read_gamepad() {
   read_gamepad(false, 0x00);
boolean PS2X::read_gamepad(boolean motor1, byte motor2) {
   double temp = millis() - last_read;
   if (temp > 1500) //waited to long
      reconfig_gamepad();
   if(temp < read_delay)  //waited too short
      delay(read_delay - temp);
   if(motor2 != 0x00)
      motor2 = map(motor2,0,255,0x40,0xFF); //noting below 40 will make it spin
   byte dword[9] = {0x01,0x42,0,motor1,motor2,0,0,0,0};
   byte dword2[12] = {0,0,0,0,0,0,0,0,0,0,0,0};
   // Try a few times to get valid data...
   for (byte RetryCnt = 0; RetryCnt < 5; RetryCnt++) {
      CMD_SET();
      CLK_SET();
      ATT_CLR(); // low enable joystick
      //Send the command to send button and joystick data;
      for (int i = 0; i<9; i++) {
         PS2data[i] = _gamepad_shiftinout(dword[i]);
      if(PS2data[1] == 0x79) {  //if controller is in full data return mode, get the rest of data
         for (int i = 0; i<12; i++) {
            PS2data[i+9] = _gamepad_shiftinout(dword2[i]);
      ATT_SET(); // HI disable joystick
      // Check to see if we received valid data or not.
	  // We should be in analog mode for our data to be valid (analog == 0x7_)
      if ((PS2data[1] & 0xf0) == 0x70)
      // If we got to here, we are not in analog mode, try to recover...
      reconfig_gamepad(); // try to get back into Analog mode.
      delay(read_delay);
   // If we get here and still not in analog mode (=0x7_), try increasing the read_delay...
   if ((PS2data[1] & 0xf0) != 0x70) {
      if (read_delay < 10)
         read_delay++;   // see if this helps out...
#ifdef PS2X_COM_DEBUG
   Serial.print("OUT:IN ");
   for(int i=0; i<9; i++){
      Serial.print(dword[i], HEX);
      Serial.print(":");
      Serial.print(PS2data[i], HEX);
      Serial.print(" ");
      Serial.print(dword2[i], HEX);
      Serial.print(":");
      Serial.print(PS2data[i+9], HEX);
      Serial.print(" ");
   Serial.println("");
#endif
   last_buttons = buttons; //store the previous buttons states
#if defined(__AVR__)
   buttons = *(uint16_t*)(PS2data+3);   //store as one value for multiple functions
#else
   buttons =  (uint16_t)(PS2data[4] << 8) + PS2data[3];   //store as one value for multiple functions
#endif
   last_read = millis();
   return ((PS2data[1] & 0xf0) == 0x70);  // 1 = OK = analog mode - 0 = NOK
byte PS2X::config_gamepad(uint8_t clk, uint8_t cmd, uint8_t att, uint8_t dat) {
   return config_gamepad(clk, cmd, att, dat, false, false);
byte PS2X::config_gamepad(uint8_t clk, uint8_t cmd, uint8_t att, uint8_t dat, bool pressures, bool rumble) {
  byte temp[sizeof(type_read)];
#ifdef __AVR__
#else
  _clk_pin = clk;
  _cmd_pin = cmd;
  _att_pin = att;
  _dat_pin = dat;
#else
#endif
#endif
  pinMode(clk, OUTPUT); //configure ports
  pinMode(att, OUTPUT);
  pinMode(cmd, OUTPUT);
  pinMode(dat, INPUT_PULLUP); // enable pull-up
#else
  pinMode(dat, INPUT);
#endif
  digitalWrite(dat, HIGH); //enable pull-up
#endif
  CMD_SET(); // SET(*_cmd_oreg,_cmd_mask);
  CLK_SET();
  //new error checking. First, read gamepad a few times to see if it's talking
  read_gamepad();
  read_gamepad();
  //see if it talked - see if mode came back.
  //If still anything but 41, 73 or 79, then it's not talking
  if(PS2data[1] != 0x41 && PS2data[1] != 0x42 && PS2data[1] != 0x73 && PS2data[1] != 0x79){
#ifdef PS2X_DEBUG
    Serial.println("Controller mode not matched or no controller found");
    Serial.print("Expected 0x41, 0x42, 0x73 or 0x79, but got ");
    Serial.println(PS2data[1], HEX);
#endif
    return 1; //return error code 1
  //try setting mode, increasing delays if need be.
  read_delay = 1;
  for(int y = 0; y <= 10; y++) {
    sendCommandString(enter_config, sizeof(enter_config)); //start config run
    //read type
    CMD_SET();
    CLK_SET();
      temp[i] = _gamepad_shiftinout(type_read[i]);
    controller_type = temp[3];
    sendCommandString(set_mode, sizeof(set_mode));
    if(rumble){ sendCommandString(enable_rumble, sizeof(enable_rumble)); en_Rumble = true; }
    if(pressures){ sendCommandString(set_bytes_large, sizeof(set_bytes_large)); en_Pressures = true; }
    sendCommandString(exit_config, sizeof(exit_config));
    read_gamepad();
    if(pressures){
      if(PS2data[1] == 0x73)
        return 3;
    if(y == 10){
#ifdef PS2X_DEBUG
      Serial.println("Controller not accepting commands");
      Serial.print("mode still set at");
#endif
      return 2; //exit function with error
    read_delay += 1; //add 1ms to read_delay
  return 0; //no error if here
void PS2X::sendCommandString(byte string[], byte len) {
  byte temp[len];
  for (int y=0; y < len; y++)
    temp[y] = _gamepad_shiftinout(string[y]);
  ATT_SET(); //high disable joystick
  delay(read_delay); //wait a few
  Serial.println("OUT:IN Configure");
  for(int i=0; i<len; i++) {
    Serial.print(string[i], HEX);
    Serial.print(":");
    Serial.print(temp[i], HEX);
    Serial.print(" ");
  Serial.println("");
#else
#endif
byte PS2X::readType() {
  CMD_SET();
  CLK_SET();
  if(temp[3] == 0x03)
    return 1;
  else if(temp[3] == 0x01)
    return 2;
  return 0;
  Serial.print("Controller_type: ");
  Serial.println(controller_type, HEX);
  if(controller_type == 0x03)
    return 1;
  else if(controller_type == 0x01 && PS2data[1] == 0x42)
	return 4;
  else if(controller_type == 0x01 && PS2data[1] != 0x42)
    return 2;
  else if(controller_type == 0x0C)
    return 3;  //2.4G Wireless Dual Shock PS2 Game Controller
  return 0;
void PS2X::enableRumble() {
  en_Rumble = true;
bool PS2X::enablePressures() {
  read_gamepad();
  read_gamepad();
  if(PS2data[1] != 0x79)
    return false;
    return true;
void PS2X::reconfig_gamepad(){
  if (en_Rumble)
  if (en_Pressures)
#ifdef __AVR__
inline void  PS2X::CLK_SET(void) {
  register uint8_t old_sreg = SREG;
  cli();
  *_clk_oreg |= _clk_mask;
  SREG = old_sreg;
inline void  PS2X::CLK_CLR(void) {
  cli();
  *_clk_oreg &= ~_clk_mask;
  SREG = old_sreg;
inline void  PS2X::CMD_SET(void) {
  cli();
  *_cmd_oreg |= _cmd_mask; // SET(*_cmd_oreg,_cmd_mask);
  SREG = old_sreg;
inline void  PS2X::CMD_CLR(void) {
  cli();
  *_cmd_oreg &= ~_cmd_mask; // SET(*_cmd_oreg,_cmd_mask);
  SREG = old_sreg;
inline void  PS2X::ATT_SET(void) {
  cli();
  *_att_oreg |= _att_mask ;
  SREG = old_sreg;
inline void PS2X::ATT_CLR(void) {
  cli();
  *_att_oreg &= ~_att_mask;
  SREG = old_sreg;
inline bool PS2X::DAT_CHK(void) {
  return (*_dat_ireg & _dat_mask) ? true : false;
#else
// Let's just use digitalWrite() on ESP8266.
  digitalWrite(_clk_pin, HIGH);
  digitalWrite(_clk_pin, LOW);
  digitalWrite(_cmd_pin, HIGH);
  digitalWrite(_cmd_pin, LOW);
  digitalWrite(_att_pin, HIGH);
  digitalWrite(_att_pin, LOW);
  return digitalRead(_dat_pin) ? true : false;
#else
// On pic32, use the set/clr registers to make them atomic...
  *_clk_lport_set |= _clk_mask;
  *_clk_lport_clr |= _clk_mask;
  *_cmd_lport_set |= _cmd_mask;
  *_cmd_lport_clr |= _cmd_mask;
  *_att_lport_set |= _att_mask;
  *_att_lport_clr |= _att_mask;
  return (*_dat_lport & _dat_mask) ? true : false;
#endif
#endif
PS2_lib.h
*  Super amazing PS2 controller Arduino Library v1.8
*		details and example sketch:
*			http://www.billporter.info/?p=240
*    Original code by Shutter on Arduino Forums
*    Revamped, made into lib by and supporting continued development:
*              Bill Porter
*              www.billporter.info
*	 Contributers:
*		Eric Wetzel (thewetzel@gmail.com)
*		Kurt Eckhardt
*  Lib version history
*    0.1 made into library, added analog stick support.
*    0.2 fixed config_gamepad miss-spelling
*        added new functions:
*          NewButtonState();
*          NewButtonState(unsigned int);
*          ButtonPressed(unsigned int);
*          ButtonReleased(unsigned int);
*        removed 'PS' from beginning of ever function
*    1.0 found and fixed bug that wasn't configuring controller
*        added ability to define pins
*        added time checking to reconfigure controller if not polled enough
*        Analog sticks and pressures all through 'ps2x.Analog()' function
*        added:
*          enableRumble();
*          enablePressures();
*    1.1
*        added some debug stuff for end user. Reports if no controller found
*        added auto-increasing sentence delay to see if it helps compatibility.
*    1.2
*        found bad math by Shutter for original clock. Was running at 50kHz, not the required 500kHz.
*        fixed some of the debug reporting.
*	1.3
*	    Changed clock back to 50kHz. CuriousInventor says it's suppose to be 500kHz, but doesn't seem to work for everybody.
*	1.4
*		Removed redundant functions.
*		Fixed mode check to include two other possible modes the controller could be in.
*       Added debug code enabled by compiler directives. See below to enable debug mode.
*		Added button definitions for shapes as well as colors.
*	1.41
*		Some simple bug fixes
*		Added Keywords.txt file
*	1.5
*		Added proper Guitar Hero compatibility
*		Fixed issue with DEBUG mode, had to send serial at once instead of in bits
*	1.6
*		Changed config_gamepad() call to include rumble and pressures options
*			This was to fix controllers that will only go into config mode once
*			Old methods should still work for backwards compatibility
*    1.7
*		Integrated Kurt's fixes for the interrupts messing with servo signals
*		Reorganized directory so examples show up in Arduino IDE menu
*    1.8
*		Added Arduino 1.0 compatibility.
*    1.9
*       Kurt - Added detection and recovery from dropping from analog mode, plus
*       integrated Chipkit (pic32mx...) support
*This program is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License for more details.
<http://www.gnu.org/licenses/>
// $$$$$$$$$$$$ DEBUG ENABLE SECTION $$$$$$$$$$$$$$$$
// to debug ps2 controller, uncomment these two lines to print out debug to uart
//#define PS2X_DEBUG
//#define PS2X_COM_DEBUG
#ifndef PS2X_lib_h
  #define PS2X_lib_h
#if ARDUINO > 22
#else
#endif
#include <math.h>
#include <stdio.h>
#include <stdint.h>
#ifdef __AVR__
  // AVR
  #include <avr/io.h>
  #define CTRL_CLK        4
  #define CTRL_BYTE_DELAY 3
#else
  #define CTRL_CLK        5
  #define CTRL_CLK_HIGH   5
  #define CTRL_BYTE_DELAY 18
#else
  // Pic32...
  #include <pins_arduino.h>
  #define CTRL_CLK        5
  #define CTRL_BYTE_DELAY 4
#endif
#endif
//These are our button constants
#define PSB_SELECT      0x0001
#define PSB_L3          0x0002
#define PSB_R3          0x0004
#define PSB_START       0x0008
#define PSB_PAD_UP      0x0010
#define PSB_PAD_RIGHT   0x0020
#define PSB_PAD_DOWN    0x0040
#define PSB_PAD_LEFT    0x0080
#define PSB_L2          0x0100
#define PSB_R2          0x0200
#define PSB_L1          0x0400
#define PSB_R1          0x0800
#define PSB_GREEN       0x1000
#define PSB_RED         0x2000
#define PSB_BLUE        0x4000
#define PSB_PINK        0x8000
#define PSB_TRIANGLE    0x1000
#define PSB_CIRCLE      0x2000
#define PSB_CROSS       0x4000
#define PSB_SQUARE      0x8000
//Guitar  button constants
#define UP_STRUM		0x0010
#define DOWN_STRUM		0x0040
#define LEFT_STRUM		0x0080
#define RIGHT_STRUM		0x0020
#define STAR_POWER		0x0100
#define GREEN_FRET		0x0200
#define YELLOW_FRET		0x1000
#define RED_FRET		0x2000
#define BLUE_FRET		0x4000
#define ORANGE_FRET		0x8000
#define WHAMMY_BAR		8
//These are stick values
#define PSS_RX 5
#define PSS_RY 6
#define PSS_LX 7
#define PSS_LY 8
//These are analog buttons
#define PSAB_PAD_RIGHT    9
#define PSAB_PAD_UP      11
#define PSAB_PAD_DOWN    12
#define PSAB_PAD_LEFT    10
#define PSAB_L2          19
#define PSAB_R2          20
#define PSAB_L1          17
#define PSAB_R1          18
#define PSAB_GREEN       13
#define PSAB_RED         14
#define PSAB_BLUE        15
#define PSAB_PINK        16
#define PSAB_TRIANGLE    13
#define PSAB_CIRCLE      14
#define PSAB_CROSS       15
#define PSAB_SQUARE      16
#define SET(x,y) (x|=(1<<y))
#define CLR(x,y) (x&=(~(1<<y)))
#define CHK(x,y) (x & (1<<y))
#define TOG(x,y) (x^=(1<<y))
class PS2X {
  public:
    boolean Button(uint16_t);                //will be TRUE if button is being pressed
    unsigned int ButtonDataByte();
    boolean NewButtonState();
    boolean NewButtonState(unsigned int);    //will be TRUE if button was JUST pressed OR released
    boolean ButtonPressed(unsigned int);     //will be TRUE if button was JUST pressed
    boolean ButtonReleased(unsigned int);    //will be TRUE if button was JUST released
    void read_gamepad();
    boolean  read_gamepad(boolean, byte);
    byte readType();
    byte config_gamepad(uint8_t, uint8_t, uint8_t, uint8_t);
    byte config_gamepad(uint8_t, uint8_t, uint8_t, uint8_t, bool, bool);
    void enableRumble();
    bool enablePressures();
    byte Analog(byte);
    void reconfig_gamepad();
  private:
    inline void CLK_SET(void);
    inline void CLK_CLR(void);
    inline void CMD_SET(void);
    inline void CMD_CLR(void);
    inline void ATT_SET(void);
    inline void ATT_CLR(void);
    inline bool DAT_CHK(void);
    unsigned char _gamepad_shiftinout (char);
    unsigned char PS2data[21];
    void sendCommandString(byte*, byte);
    unsigned char i;
    unsigned int last_buttons;
    unsigned int buttons;
    #ifdef __AVR__
      uint8_t maskToBitNum(uint8_t);
      uint8_t _clk_mask;
      volatile uint8_t *_clk_oreg;
      uint8_t _cmd_mask;
      volatile uint8_t *_cmd_oreg;
      uint8_t _att_mask;
      volatile uint8_t *_att_oreg;
      uint8_t _dat_mask;
      volatile uint8_t *_dat_ireg;
    #else
      int _clk_pin;
      int _cmd_pin;
      int _att_pin;
      int _dat_pin;
    #else
      uint16_t _clk_mask;
      volatile uint32_t *_clk_lport_set;
      volatile uint32_t *_clk_lport_clr;
      uint16_t _cmd_mask;
      volatile uint32_t *_cmd_lport_set;
      volatile uint32_t *_cmd_lport_clr;
      uint16_t _att_mask;
      volatile uint32_t *_att_lport_set;
      volatile uint32_t *_att_lport_clr;
      uint16_t _dat_mask;
      volatile uint32_t *_dat_lport;
    #endif
    #endif
    unsigned long last_read;
    byte read_delay;
    byte controller_type;
    boolean en_Rumble;
    boolean en_Pressures;
#endif
Be aware that if you modify the library, any updates of that library will wipe the changes.
Therefore I copied the two files into my sketch directory and modifed the include; note the change from < and > to the double quotes
#include "PS2X_lib.h"  //for v1.6
Yup, I can confirm it works from a complile as well as flash perspective. Thanks.
Next, the void setup() didn't return any error inside the serial monitor.
The workaround was to add
while (!Serial) {}
after opening the serial monitor, as described here:
Serial.print in void setup - Using Arduino / IDE 1.x - Arduino Forum
So it seems the Arduino101 does not have that "special reset circuit" contrary to the typical Arduinos.
Anyway, now the error is:
No controller found, check wiring, see readme.txt to enable debug.
I think the wiring is correct. So it is either the PS2 controller damaged, or some other topic related to the Arduino/Genuino 101 platform, be it compatiblity from a SW perspective, or HW perspective (it seems the 101 supports 3.3 V)...
The only two comments that I can make are
  • The below in the .h file involves timing; you can check in the .cpp how they are used.
  #define CTRL_CLK        5
  • There are debug options in the .h file
Is there a way to find out - for the 101 - whether the values 5, 5 and 18 are correct respectively for CTRL_CLK, CTRL_CLK_HIGH and CTRL_BYTE_DELAY? Or otherwise what the suitable entries shall be?
I really don't know. I think tou will have to analyse the original signals between xbox and controller using a oscilloscope or logic analyser. And next implement that timing in the 101.
Update:
i received a new controller with its receiver led "blinking" as expected based on other sources on the net.
And now it works.
So the proposal
namely
"If you replace, in the .h and .cpp file of the library, every #ifdef ESP8266 by #if defined (ESP8266) || defined (__ARDUINO_ARC__) , the compilation will result in behaviour like for the ESP8266."
was worth it!
Many thanks.
