i get false readings,it could be on the first if you turn it fast,the point is that is happening,there is not a standard spot it happens
You get missing counts when you turn it fast. Not extra counts.
Because of how the encoder works, and how you are reading it with the interrupt, the count value is immune to switch bounce. It may bounce up and down by one count, but it can't add or miss counts.
If you are missing counts on fast rotation I would expect that the response rate of the internal mechanical switches is not fast enough. If its not fast enough to respond to the changing wind direction you see, then you will need to use a faster non contacting optical or magnetic encoder.
One possibility to get higher response speed from the encoder is to read it for 24 counts per revolution instead of 48. Change the interrupt trigger from CHANGE to RISING or FALLING which ever seems better. There may be a difference between opening and closing the switch. You will still get 15 degrees of resolution.
I just did a quick look at the original code.
One can't determine direction that way.
Any change of A or B input can be a change in direction.
You can't just look at input B.
Also, the biggest problem, as mentioned, the
serial takes too much time. The inputs need to be on interrupt.
Dwight
Interesting, thanks. Your vane is quite long, from tip to tail, compared to my vane. How does it perform outside? Is it steady, or does it swing around a lot?
Can you explain it more,what should i change on my code,and where
It perfoms very well,its swinging easily cause of the long wing,and its steadt cause of the weight,the shaft is from a stainless welding electrode,and the front little cone thing is heavy enough
for anynoe of you want a reliable forever wind vayne this is the best construction of all,but you must have a 3d printer xD Best wind vane by far
When i did that a full rotation is counting 24 so its the half of my 48 reading that i had before,but the problem still going on...it is missing counts
In my opinion you need an optical or magnetic encoder to reliably rotate the encoder at high speed. You might also investigate an "absolute" instead of "incremental" encoder for your application.
kaloudis94:
