Hello folks, I want to build a Windows UI for my Arduino project, that reads data and gives commands to Arduino using the serial port. I came across Megunolink, although I am not sure if it is capable of creating a Windows application for my project. Can you guys suggest what is the easiest way to achieve this?
you could implement the GUI using Visual Studo (C#, C++, VB ), NetBeans (java), Python, etc
all have libraries which support serial ports suitable for communication with an Arduino
what is your programming experience?
I have minimal experience, That is the reason I am checking options like Megunolink.
try a web search for arduino gui builder, e.g. make-a-pc-graphical-interface-for-arduino-any-easy-software
if you know C/C++ Visual Studio C# may be suitable
have a look at Visual Studio Comunity - there are plenty of tutorials on building GUIs and programming
Do you have to use a serial link or could you consider running a webserver on the Arduino (or an alternative such as an ESP32) and controlling it using a web browser on the PC ?
I will have to use a serial link
For a basic dashboard interface using NodeRed is possibly the quickest way of building something presentable.
All the GUI will see is a COM port - it neither knows nor cares what's connected on the other side of that COM port.
Therefore any Windows GUI tool/framework that can access a COM port can be used - the fact that you have an Arduino is irrelevant.
I found "Processing" quite nice. It comes with an Arduino library that allows to access Arduino pins and more from your Processing application.
@abisat So is the real question, "How to communicate from a Windows GUI to an Arduino via COM port?"
For that, you might look at Firmata:
There's also a FirmataExpress - adds some "higher level" facilities; higher speed:
and a derivative called Telemetrix - "A user-extensible replacement for Standard Firmata without the complexity of Firmata":
I was too slow in fixing my description of Processing. Processing is a Windows GUI application development package that comes with an Arduino communication library.
Megunolink is not free.
Are you looking for free software?
Blockquote
Yes, I am.
So which part is it that you're looking for:
- the GUI builder/toolkit/framework?
- the comms?
Or both?
I am looking for developing a Windows GUI application. Which will in turn use Serial communication as protocol.
- the comms?
Or both?
Both!
So, again, the fact that you have an Arduino is completely irrelevant to the GUI part.
Also, "Serial communication" is not a complete protocol - just the basic, physical transport.
You are going to have to define
- what commands/requests your Arduino will accept over the serial link;
- what replies/responses your Arduino will give over the serial link;
- the formats of all those messages.
- Implement handling all those messages in both the Arduino and the GUI.
Both!
As always, the easiest way is generally to break that down into separate steps.
I would suggest that you first define your protocol (commands/responses), and get that working, and then build the GUI.
Please read my fixed description of Processing in #9. It is just what you are looking for.
