I had the function convertData tried in differet ways.
For example:
void convertData(int r){};
void convertData(int[] r){}; // when I tried to send an arrays
void convert ((uint8_t *) r)
void convertData((uint8_t *)&str1)
Nothing works for me.
How do i declare the Variable in the receiveFunction? For me, it works better to send an Arrays with data. like so:
void send(){
int[] i = {int val1, int val2}; // as i understood 4 bytes so i write:
Wire.beginTransmission(ledChannel);
Wire.write(i, 4);
Wire.endTransmission();
Paul's correct; the argument to whatever function you use is set in stone and must be an int. Perhaps something like:
struct { // 2 16-bit integers, 4 bytes total MAKE GLOBAL
int val1 = 5;
int val2 = 10;
} str1;
// Setup(), loop(), etc...
void convertData(int bytesToRead){
int i = 0;
union myUnion {
int A;
int B;
char buffer[4];
} mine;
while(Wire.available())
mine.buffer[i++] = Wire.read();
str1.val1 = mine.A; // You may have to play around with these cuz of Endian problem
str1.val2 = mine.B;
I cannot test this, so it may be completely wrong...
I realize this is an old post, but I just stumbled on it, and it's taking care of exactly what I need.
Here's a really stupid question:
If your array only has 2 components (sendInts[0] and sendInts[1]), why does aCount have a value of 4? I'm creating an array of 200 to be transmitted (a bunch of DMX addresses). Each components would be an int between 0 and 256 - what would my aCount be in this case?
aCount is received bytes, and there are two per integer.
A byte has value of 0 to 255 inclusive, so I think you are talking about a byte array. Memory is precious on an Arduino, so don't use an int when a byte will do.
You will encounter another problem in that the Wire library for i2c communications is designed for short communications and there is a 32 byte buffer limitation. You will have to break your array into pieces.
