The leds are to be used in all manner of weird and wonderful ways. Some will be just for added flash on some parts of sets (around DJ booths etc), others will be to add effects to stage structures (like if theres a giant fiberglass dragon head, using leds to produce a flame effect from its nose etc etc).
Theres an overall art director but also lots of artists, none of whom know anything about electronics but I want them to be able to come to me with a design and say "id like this kind of light or lighting effect in this part of it" etc
There are multiple set "themes" that will be transported all over the place, some indoors, some out. Stuff will be in storage for a a year or more and then brought back into circulation for a year etc.
I need standardization as much as possible. I want to use the same kind of leds in as much as possible so I can run around and hook/unhook power and controllers quickly and easily without having to worry about different types.
Also - I'm no electrician so Id like to keep away from high voltages as much as possible. Tho - I think the danger threshold is 30v? So 24 should be safe even at 12a ? If there's a chance I could hurt myself or someone else if I screw something up id rather leave it alone.
@paul_b I think you may have misread my post - I mentioned a 12a power supply for 4, 3a strips. Given what you said about overhead, 3 strips (9a total) would be ok?
PerryBebbington:
A suggestion, one I've not tried myself but I can't think why it would not work OK. Instead of supplying 5V over long, thick wires supply 12V or even 24V over thinner wires and put a 12V (or whatever) to 5V buck converter right next to the LED strips. You should be OK to use multiple converters along the length of the LEDs.
this is interesting. I had thought about something like this but didn't know if the voltage converters were a thing - I'll look into buck converters.
I have been focusing on 5v because I found WS2812B strips that were perfect for the various projects people wanted to do (size, functionality etc) they are nice and cheap which is very important and I thought 5v was a good area to be learning in since most hobbyist electronics stuff seems to be natively 5v.
Also - those 5v phone batteries are a very handy size for props where a mains connection just isnt viable. 12v batteries are huge and heavy and might be ok for some things but not others.
I may have just been paranoid out of ignorance but I had the impression that converting voltages from one to another was something I could easily get wrong and start frying things left and right
