Hi, I currently have a laptop and end device with an ethernet cable between them, running on udp protocol. I would like to change the cable into a wireless connection.
In my setup I have an iBoard Ex and XBee 900HP. iBoard Ex comes with wiznet w5100. I am trying to convert the udp data from laptop into serial to parse into xbee, and on the other side xbee receives the data and changes it back to udp to go into the ethernet cable to the end device. The 2 xbees are already paired together. I would like it to work both ways, meaning end device can also transmit data to laptop.
From what I have read about udp, I need to open up a port to connect. But if I just want to get the data from the ethernet cable directly, is it possible without opening any ports?
Sorry new to wireless, please help. Thanks.
Sorry was using my phone just now so did not post my code. Below is the code that I am using. Would like to check whether I need to assign a port? Since I am not sure about the current protocol which port does it use since the 2 devices are connected via an ethernet cable.
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
byte mac[] = {__, __, __, __, __, __}; // MAC address of controller
unsigned int myPort = 43770; // local port to listen on
unsigned int yourPort = 43770; // remote port to send to
EthernetUDP udp; // an EthernetUDP instance to let us send and receive packets over UDP
void setup(){
Serial1.begin(115200);
Ethernet.begin (mac); // Start Ethernet connection DHCP
if (Ethernet.begin(mac) == 0){
Serial.println(“DHCP error”); // report failure to obtain network parameters
While(true){} // no point in carrying on, loop indefinitely
// show the local IP address
Serial.print (“Local IP: “);
Serial.println (Ethernet.localIP());
udp.begin (myPort); // Start UDP
IPAddress yourIp = udp.remoteIP();
udp.beginPacket(yourIp, yourPort);
void loop(){
getData(udp, myPort); // udp to xbee
sendData(udp, yourIp, yourPort); // xbee to udp
Ethernet.maintain(); // for renewal of DHCP leases
void getData (EthernetUDP thisUDP, unsigned int thisPort) {
// if UDP data available, parse out the header
int packetSize = thisUDP.parsePacket();
if (packetSize){
Serial.print (“Received packet of size “);
Serial.println (packetSize);
Serial.print (“From: “);
for (int i=0; i<4; i++){
Serial.print (yourIp[i], DEC);
if (i<3){
Serial.print(“ “);
Serial.print (“, port ”);
unsigned int yourPort = thisUDP.remotePort();
Serial.println (yourPort);
// send the payload out the serial port
while (thisUDP.available()){
// read the packet into packetBuffer
int udpByte = thisUDP.read();
Serial.write(udpByte); // send data to serial monitor
Serial1.write(udpByte); // send data to xbee
void sendData (EthernetUDP thisUDP, unsigned int destIp, unsigned int destPort) {
if (Serial1.available()) {
int serialByte = Serial1.read();
// if get 0x7E, send packet and begin new one
if (serialByte == 0x7E) {
thisUDP.endPacket();
thisUDP.beginPacket(destIp, destPort);
thisUDP.write(serialByte);
This is the processing sketch to test out the code.
Processing UDP example to send and receive string data from Arduino.
Press any key to send the “Hello Arduino” message.
import hypermedia.net.*; // import the UDP library
UDP udp; // define the UDP object
void setup(){
udp = new UDP (this, 43770); // create a new datagram connection on port 6000
// udp.log (true); // printout the connection activity
udp.listen (true); // and wait for incoming message
void draw(){
void keyPressed(){
int destPort = 43770;
String ip = “255.255.255.255”; // broadcast message
udp.send (“Hello World\n”, ip, destPort); // the message to send
void receive (byte[] data){
// print the incoming data bytes as ASCII characters
for (int i=0; i<data.length; i++) {
print (char (data[i]));
println();
Also I have a feeling I might not need to connect to the internet at all, since I only want to get the UDP data from the cable and parse it into XBee, on the other side get the data from XBee and parse it into the ethernet cable via UDP. The devices should be able to read the data going into the cables directly?
