Hello all,
I'm working on a project with a friend for wireless connection between TI calculators (original right?). I've got to figure out a way to connect the two calculators, which each have a send and receive (1 wire each). Upon some research I think the best way to go about it would be an arduino nano with a NRF24L01 RF transceiver. I've found some code to switch a light on and off with a button for two arduinos with NRF24LO1's, so would that work if I put the output of the arduino into the input of the calculator and vice versa?
Thanks for your help.
(code for switching LEDs)
#include <SPI.h>
#include <RH_NRF24.h>
// Singleton instance of the radio driver
RH_NRF24 nrf24;
int greenLed = 3;
int redLed = 4;
int button = 5;
pinMode(greenLed, OUTPUT);
pinMode(redLed, OUTPUT);
pinMode(button, INPUT);
while (!Serial)
; // wait for serial port to connect. Needed for Leonardo only
if (!nrf24.init())
Serial.println("init failed");
// Defaults after init are 2.402 GHz (channel 2), 2Mbps, 0dBm
if (!nrf24.setChannel(1))
Serial.println("setChannel failed");
if (!nrf24.setRF(RH_NRF24::DataRate2Mbps, RH_NRF24::TransmitPower0dBm))
Serial.println("setRF failed");
if (digitalRead(button)) {
//button is pressed, message should be sent, turn the green LED on
digitalWrite(greenLed, HIGH);
// Send a message
uint8_t data[] = "Aloha";
nrf24.send(data, sizeof(data));
nrf24.waitPacketSent();
digitalWrite(greenLed, LOW);
// Wait for a message
uint8_t buf[RH_NRF24_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
while (nrf24.waitAvailableTimeout(200) && nrf24.recv(buf, &len))
//something was received, turn the right LED on
digitalWrite(redLed, HIGH);
digitalWrite(redLed, LOW);
