Wireless microphone with bluetooth module
Hello, the first thing I want to say is that I am completely ignorant with that module since I have never used it.
I have this module for bluetooth: https://www.amazon.com/dp/B01G9KSAF6
An arduino Nano ... and this other microphone module: https://www.amazon.com/-/es/gp/product/B07PVHTZT3/
I have other sensors, what I want is to connect to my PC, send the data from the other sensors via serial or whatever ... and at the same time have a wireless microphone to be able to use it on the PC. Is it possible to do it with those materials?
Might be possible, but you would not like the audio quality. At any rate, you would have to write the PC program to process the digital audio from the Nano. Can you do that?
Paul
Why won't I like the quality of the audio? Is that module bad? I can change it. Or do you say it because it is sending information from other sensors and audio? Sweet it for me, please.
I still don't have the code. I bought everything except the audio module, I am asking before making a purchase.
The Bluetooth device you refer to is a plain-vanilla HC-05, at about three times the normal price, but entirely suitable for the above - without the whatever. It is not suitable for a wireless microphone, and I don't think the Nano is either.
Because the Arduino is really slow trying to convert and AC signal to a 16 bit digital number several hundred time a second. Needs to be done several 10's of thousands per seconds.
Paul
Can you think of an alternative?
I need to send data with bluetooth from my arduino to my computer. I can't buy a bluetooth microphone module because it will already be in one with the arduino.
What dou you recommend?
What do you think about this? Arduino Wiring & Test | Adafruit I2S MEMS Microphone Breakout | Adafruit Learning System
Are you no longer using a Nano?
Let's say I use an Arduino, Feather M0. What would I have to do to use it as a wireless 24/7? Because there it only shows how to record.
When you get that to work, then begin to add the new features.
I wanna do this: https://www.amazon.com/-/es/【Plug-Play-inalámbrico-entrevista-sincronización-automática/dp/B08XM817CB/
I don't know how but I want to do that arduino, bluetooth and that in addition to the audio it can send data.
Don't you know of a similar project? I'm looking for.
Time to grow up and learn
Thanks for your great advice, it certainly helped me. I will continue investigating. Greetings.
You may also visit the Blog related to : Best Budget Wireless Microphone
