Hey guys, I've built a robotic arm controlled by 5 servo motors, 40 gram servos controlled wirelessly through xbee s1 modules. I control the servos with flex sensors attached on a glove. Now, the robot also has force sensors on it, which when sufficient force is applied, drives a vibration motor on the control glove. The problem is that it never works at the same time. Either the force sensor and vibration motor work and the motors dont, or the flex sensors and the motors work. Only rarely can I get them both to work side by side. Most of the times, I notice that when I power on the circuit, the motors go from 0 degree position to 90 degree position, and stay there, regardless of which sensor value I change. Please help me out. Here's the code for the glove and the robot, as well as the circuit diagrams attached.
//Glove code
int val1, val2, val3, val4, val5;
int inbyte, sens1, sens2, sens3, sens4, sens5, outbyte;
int mot1, mot2, mot3, mot4, mot5;
int vib1=3, vib2=5, vib3=6, vib4=9, vib5=10; // variables to hold the pin number of the connecting sensors in arduino
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
pinMode(A4, INPUT);
pinMode(vib1,OUTPUT);
pinMode(vib2,OUTPUT);
pinMode(vib3,OUTPUT);
pinMode(vib4,OUTPUT);
pinMode(vib5,OUTPUT);
val1 = analogRead(A0); /*
val2 = analogRead(A1); *
val3 = analogRead(A2); *These lines use the analogRead() function to read analog values from the pins A0 to A4 and store them in variables val1-val5
val4 = analogRead(A3); *
val5 = analogRead(A4); */
Serial.println(2000); /*
delay(1); *
Serial.println(val1); * Here, the sensor values stored in val1-val5 from previous lines are sent via the Serial.println() function to the robotic hand to drive its motors.
delay(1); * The initial 2000 and 2001 at the end are used as identifiers for the data so that the sensor values can be sent as a packet without being lost.
Serial.println(val2); * A delay of 1 ms is given so that the receiver end has time to receive all the data without any desynchronization.
delay(1); * After the data packet is sent, the serial port is cleared using Serial.flush()
Serial.println(val3); *
delay(1); *
Serial.println(val4); *
delay(1); *
Serial.println(val5); *
delay(1); *
Serial.println(2001); *
delay(1); *
Serial.flush(); */
inbyte = Serial.parseInt(); /*
sens1 = Serial.parseInt(); *After transmitting the flex sensor values to the robot, these lines are used to receive and store the incoming sensor values from
sens2 = Serial.parseInt(); * the robotic hand. Here, the force values from the sensors on the robot are received here. The variable inbyte and outbyte are used to
sens3 = Serial.parseInt(); * receive the identifiers for this data packet. In this case, the robot sensor values packet is marked by a '4000' in the start and '4001'
sens4 = Serial.parseInt(); * at the end. The function Serial.parseInt() outputs the first integer value received in the Serial port.
sens5 = Serial.parseInt(); *
outbyte = Serial.parseInt(); */
if(inbyte == 4000 && outbyte == 4001) /*
{ * Here, the received sensor values are checked for integrety by using the data identifiers 'inbyte' and 'outbyte' and the if statement
mot1 = map(sens1, 0, 920, 0, 255); * if the data received is from the force sensors in the robot hand, then these values are mapped to the variables mot1-mot5, which
mot2 = map(sens2, 0, 920, 0, 255); * are used to drive the vibration motors present in each fingertip of the glove for haptic feedback. The variables mot1-mot5 are
mot3 = map(sens3, 0, 920, 0, 255); * then used to drive the motors using the analogWrite() function and the vib1-vib5 variables which represent the pin numbers in arduino
mot4 = map(sens4, 0, 920, 0, 255); * of the respective vibration motor.
mot5 = map(sens5, 0, 920, 0, 255); *
analogWrite(vib1,mot1); *
analogWrite(vib2,mot2); *
analogWrite(vib3,mot3); *
analogWrite(vib4,mot4); *
analogWrite(vib5,mot5); */
//Robot arm code
int inbyte, outbyte; //variables for marking the start and end of sensor values
int flex1,flex2,flex3,flex4,flex5; // variables for holding the flex sensor values received from the glove
int sens1,sens2,sens3,sens4,sens5; // variables for storing the force sensor values present in the robot
#include <Servo.h>
Servo finger1, finger2, finger3, finger4, finger5;
int servoPin1 = 3; /*
int servoPin2 = 5; * Assign the various PWM pins on arduino to the variables
int servoPin3 = 6; * servoPin1 - servoPin5. These will be used to attach the servo objects to their
int servoPin4 = 9; * respective pins
int servoPin5 = 10; */
finger1.attach(servoPin1);
finger2.attach(servoPin2);
finger3.attach(servoPin3);
finger4.attach(servoPin4);
finger5.attach(servoPin5);
// set each servo pin to output and also declare each of the analog pins as input pins
pinMode(servoPin1, OUTPUT);
pinMode(servoPin2, OUTPUT);
pinMode(servoPin3, OUTPUT);
pinMode(servoPin4, OUTPUT);
pinMode(servoPin5, OUTPUT);
pinMode(A0,INPUT);
pinMode(A1,INPUT);
pinMode(A2,INPUT);
pinMode(A3,INPUT);
pinMode(A4,INPUT);
flex1 = Serial.parseInt(); * In this part of the program, the flex sensor values from the glove needed to
flex2 = Serial.parseInt(); * know the amount by which the motors should move is received from the serial port.
flex3 = Serial.parseInt(); * To prevent data loss and desynchronization between glove and robot data, we mark the
flex4 = Serial.parseInt(); * data packet with 'identifiers'. In this case, the variables 'inbyte' and 'outbyte'
flex5 = Serial.parseInt(); * store those values. The Serial.parseInt() is used to assign the value of the first integer value incoming from the serial port to each variable
if(inbyte == 2000 && outbyte == 2001) // only proceeds if the identifier values are correct, which signifies that the right set of sensor values has been received from the glove
/* Defines "pos" variables as being proportional to the flex inputs.
* The ~350 to ~550 value range seemed adequate for my sensors, but will change
* depending upon the resistance used, the quality of each sensor, etc
int pos1 = map(flex1, 365, 544, 0, 180);
pos1 = constrain(pos1, 0, 180);
int pos2 = map(flex2, 335, 521, 0, 180);
pos2 = constrain(pos2, 0, 180);
int pos3 = map(flex3, 285, 521, 0, 180);
pos3 = constrain(pos3, 0, 180);
int pos4 = map(flex4, 335, 555, 0, 180);
pos4 = constrain(pos4, 0, 180);
int pos5 = map(flex5, 290, 525, 0, 180);
pos5 = constrain(pos5, 0, 180);
//Tell servos to move by the amount specified in the "pos" variables
finger1.write(pos1);
finger2.write(pos2);
finger3.write(pos3);
finger4.write(pos4);
finger5.write(pos5);
delay(1);
Serial.flush(); //clear serial port for next operation
//Now, measure and store the force sensor values in the variables sens1-sens5
sens1 = analogRead(A0);
sens2 = analogRead(A1);
sens3 = analogRead(A2);
sens4 = analogRead(A3);
sens5 = analogRead(A4);
// send the sensor values stored previuosly using Serial.println() along with the identifier values '4000' and '4001' to the glove
Serial.println(4000);
delay(1);
Serial.println(sens1);
delay(1);
Serial.println(sens2);
delay(1);
Serial.println(sens3);
delay(1);
Serial.println(sens4);
delay(1);
Serial.println(sens5);
delay(1);
Serial.println(4001);
delay(1);
Serial.flush();
