Wiring a linear actuator with external power source - 3 wires.
I need to connect a linear actuator with external powersource, so i can control it using the arduino UNO board.
I've attached a photo of the hardware i'm using.
The red wire gives a poweroutput of approx 12 V. When connected to the orange wire, the actuator extends, when connected to the green wire it retracts.
How do i set up this wiring, i've been trying a few different things, but it seems that because of the 3 wires i can't figure out how to do it right.
I got a couple of relays, transistors, resistances and diodes for this project so any wiring using this would be much appreciated.
Do you want the red Always connected to one or the other?
I want it so that i can control both directions without having to do any rewiring.
Or is Red always "hot" and you want to control when it is connected?
Always hot, want to control when connected. No effect if orange and green is connected.
Something in this ballpark?
I'm having trouble realizing, where i connect: The ohm-resistor, the red wire and the transistor emitter?
Your help is much appreciated!
power supply Gnd connects to Emitter and connects to Arduino Gnd.
red wire goes to relay Common. Common will connect to Normally Closed, and when the relay is energized, Common will connect to Normally open.
Resistor goes to transistor base. Without a part number, can't say where that is. Other side goes to an Arduino pin, say pin 3.
Why is there nothing connected to pin-3 of transistor ? If it is NPN then that's the emitter.
It should go to GND.
I still don't see a wire from pin-3 (emitter) to GND)
So this is how i got the wiring going now.
I can control it using
int pin = 3;
pinMode(pin, OUTPUT);
digitalWrite(pin, HIGH);
delay(2000 );
digitalWrite(pin, LOW);
Trouble is when i connect the green wire to normally closed the aktuator doesn't move in either direction. If i disconnect the green wire it will do as the code requests.
Is it possible to control which directions it goes with this setup, and how?
Are having trouble understanding this ?
Why are you talking about software when your hardware is missing a wire ?
What you pictured is not the same as what I diagrammed for you, and does not make the connections you initially described:
Red should not connect to the motor at all - only to the relay common.
The relay takes care of connecting Red to Orange, or Red to Green.
@Crossroads,
That's why you get the big bucks.... :smiley:
Note that you need two separate and independent relays, not just one. CrossRoads' diagram uses the left relay as an "enable" control and the right relay as a "direction" control.
Issues with your wiring are:
  • transistor emitter is not connected to ground
  • base resistor is not connected to arduino at all
  • relay coil high side needs to go to VCC/5V not D13
  • your red wire is not connected
  • the relay Common pin is not connected
  • only half the circuit is present
As a temporary measure with 1 relay, you could connect the red wire to the relay common. That way the actuator will ALWAYS be moving and this relay will control its direction. I don't know what will happen if you try to drive the actuator through its end-stops.
I have a handful of this exact model of relay. The way it's in the breadboard makes me think you've folded the common pin under and maybe you don't have the other wires plugged into the right columns.
Yep, I'll just take my Moderator pay & retire someplace comfortable 8)
In my dreams, anyway!
If you haven't realized by now i am quite a n00b in this wiring enterprize. :astonished:
CrossRoads i'm having a bit of trouble understanding your schematic.
I do have two relays and this is the wiring i've done from what (i think) i could understand from your drawing.
Is any of this the least correct? I'm having trouble understanding the NO/NC wiring on the first relay, the C on both and where the red wire goes..
Once again your help is much appreciated! :slight_smile:
Red wire goes to C on Left relay. Connect NO on left relay to C on right relay.
Pin 3 high then enables actuator to move.
Pin 5 determines the direction.
Thank you very much! It works now.
I have added the final wiring for future reference, if anybody should stumple upon same problem :slight_smile:
