Wiring a RedBear Blend Micro and Adafruit SD card breakout
I'm trying to get an Adafruit SD card breakout to work with a Redbear blend micro board. I'm unsure how to wire it.
I have it wired:
CS - SS
DI - 11
DO - 12
CLK - 13
GND - GND
3V - 3V
What do I need to change to get this working?
Thanks.
#include <SPI.h>
#include <SD.h>
File myFile;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
const int chipSelect = SS;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(SS, OUTPUT);
if (!SD.begin(chipSelect)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println("testing 1, 2, 3.");
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// re-open the file for reading:
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
// nothing happens after setup
I tried posting to the red bear forum four days ago and my posts are apparently still "awaiting moderation".
CS - SS
The Micro has an SS pin?
It does. http://redbearlab.com/blendmicro/
I needed to hook up the Adrafruit SD breakout board also and noted this topic was never closed. I was able to hook it up and make it work.
I connected the following (which appears to be what you have):
SD Board Blend Micro
DO MISO
DI MOSI
CLK CLK
CS SS
GND GND
3.3V 3.3V supply
In the code I modified the CS pin to "SS", and the example executed and I could read the file from my mac.
