Hi friends!
I am writing to you because I need your help. I have a project and I am standing due to the wiring and computing of two electric motors for Arduino. It seems, that on internet, are very common in a lot of projects, but I have not been able to find any connection scheme. Also, is not easy for me how to computing the electric engines in the arduino IDE. I am new…
I could to running the engines. This is very easy. But I want to get the steps or the revolutions, rpm. I attached some images of my engine, and what I have done.
- Motor: Uxcell DC 6V 210RPM Encoder Gear Motor with Mounting Bracket 65mm Wheel Kit 1 Set for Smart Car Robot DIY.
- There are 6 wires.
- Use sensor Hall
- Between Arduino UNO and motors I am using the “H”-Bridge: L298N.
I did some conections that works:
Out 1 of L298N: Pin 1 motor GND
Out 2 of L298N: Pin 6 motor.
Other Pins....after waste a lot of hours...no idea...
Thank you very much!!
Link Motor: https://www.amazon.com/210RPM-Encoder-Motor-Mounting-Bracket/dp/B074XRW6XJ
// pins for the encoder inputs
#define RH_ENCODER_A 11
#define RH_ENCODER_B 10
#define LH_ENCODER_A 13
#define LH_ENCODER_B 12
// variables to store the number of encoder pulses
// for each motor
int leftCount = 0;
int rightCount;
int IN1 = 8; //motors
int IN2 = 7; //motors
int ENA = 6; //motors PWM
int IN3 = 5; //motors
int IN4 = 4; //motors
int ENB = 3; //motors PWM
pinMode(LH_ENCODER_A, INPUT);
pinMode(LH_ENCODER_B, INPUT);
pinMode(RH_ENCODER_A, INPUT);
pinMode(RH_ENCODER_B, INPUT);
// Motores
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(ENA, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(ENB, OUTPUT);
// initialize hardware interrupts
attachInterrupt(0, leftEncoderEvent, CHANGE);
attachInterrupt(1, rightEncoderEvent, CHANGE);
Serial.print("Right Count: ");
Serial.println(rightCount);
Serial.print("Left Count: ");
Serial.println(leftCount);
digitalWrite(IN1, HIGH);
digitalWrite(IN2, LOW);
analogWrite(ENA, -125);
digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH);
analogWrite(ENB, -125);
// encoder event for the interrupt call
void rightEncoderEvent() {
if (digitalRead(LH_ENCODER_A)== LOW){
if (digitalRead(LH_ENCODER_B)== HIGH){
rightCount--;
if (digitalRead(LH_ENCODER_A)== HIGH){
if (digitalRead(LH_ENCODER_B)== LOW){
rightCount--;
void leftEncoderEvent() {
if (digitalRead(LH_ENCODER_A) == HIGH) {
if (digitalRead(LH_ENCODER_B) == LOW) {
leftCount++;
leftCount--;
leftCount--;
leftCount++;
