I have an example code that I would like to try out using an Arduino Micro (as I'm new to using a display):
DogLcd Library - Hello World
Demonstrates the basic use of a DOGM text LCD display.
This sketch prints "Hello World!" to the LCD
and shows the time.
See the online-documention for wiring instuctions
We assume the following pins are connected:
* LCD SI pin to digital pin 2
* LCD CLK pin to digital pin 3
* LCD RS pin to digital pin 4
* LCD CSB pin to digital pin 5
* LCD RESET pin is not used
* LCD Backlight pin is not used
Library homepage : http://code.google.com/p/doglcd/
// include the library code:
#include <DogLcd.h>
// initialize the library with the numbers of the interface pins
DogLcd lcd(2, 3, 4, 5);
// set up the LCD type and the contrast setting for the display
lcd.begin(DOG_LCD_M162);
// Print a message to the LCD.
lcd.print("hello, world!");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
Do I have to use pins 2,3,4 & 5 or can I pick my own?
Could I attach any Arduino to this display (datasheet attached) for it to work with this code? Lastly, am I restricted to buying a display only if it has a library available or is there a procedure to make a custom library by myself? Thanks for your help!
DOG M Display.pdf (1.27 MB)
