Hello,
I connect WIZ550io on my Arduino Due as show attached picture.
Arduino Due programming with this code:
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
#if defined(WIZ550io_WITH_MACADDRESS) // Use assigned MAC address of WIZ550io
#else
byte mac[] = {0xxx, 0xxx, 0xxx, 0xxx, 0xxx, 0xxx};
#endif
IPAddress ip(192,168,1,150);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection and the server:
Ethernet.begin(ip);
#else
Ethernet.begin(mac, ip);
#endif
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
//dodaj čakanje vsaj 500ms zaradi drugega posta: http://wizwiki.net/forum/viewtopic.php?f=81&t=799
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("</html>");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
When Code running show me on Serial port this message:
server is at 0.251.251.251
IP is static from tomato firmware on lynksys wrt54gl router.
If I would like to Ping wiznet get this
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Grega>ping 192.168.1.150
Pinging 192.168.1.150 with 32 bytes of data:
Reply from 192.168.1.14: Destination host unreachable.
Ping statistics for 192.168.1.150:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
I don't know what I'm doing wrong.
Please help me.
