Das versteht kein Mensch was Du willst. Ist aber im dem Fall egal.
@krischu dort wo du dein HMI Display gekauft hast war ein Verweis auf https://pan.jczn1688.com/
Mit Passwort um komplettes Packet mit Liberales, Beispielen usw. herunterladen.
Für meinen Display sieht der Sketch dann so aus
#include <lvgl.h>
#include <TFT_eSPI.h>
#include <demos/lv_demos.h>
/*更改屏幕分辨率*/
static const uint16_t screenWidth = 320;
static const uint16_t screenHeight = 240;
static lv_disp_draw_buf_t draw_buf;
static lv_color_t buf[ screenWidth * 10 ];
TFT_eSPI tft = TFT_eSPI(); /* TFT实例 */
#if LV_USE_LOG != 0
/* 串行调试 */
void my_print(const char * buf)
Serial.printf(buf);
Serial.flush();
#endif
//_______________________
void lv_example_btn(void)
/*要转换的属性*/
static lv_style_prop_t props[] = {
LV_STYLE_TRANSFORM_WIDTH, LV_STYLE_TRANSFORM_HEIGHT, LV_STYLE_TEXT_LETTER_SPACE};
/*Transition descriptor when going back to the default state.
*Add some delay to be sure the press transition is visible even if the press was very short*/
static lv_style_transition_dsc_t transition_dsc_def;
lv_style_transition_dsc_init(&transition_dsc_def, props, lv_anim_path_overshoot, 250, 100, NULL);
/*Transition descriptor when going to pressed state.
*No delay, go to presses state immediately*/
static lv_style_transition_dsc_t transition_dsc_pr;
lv_style_transition_dsc_init(&transition_dsc_pr, props, lv_anim_path_ease_in_out, 250, 0, NULL);
/*Add only the new transition to he default state*/
static lv_style_t style_def;
lv_style_init(&style_def);
lv_style_set_transition(&style_def, &transition_dsc_def);
/*Add the transition and some transformation to the presses state.*/
static lv_style_t style_pr;
lv_style_init(&style_pr);
lv_style_set_transform_width(&style_pr, 10);
lv_style_set_transform_height(&style_pr, -10);
lv_style_set_text_letter_space(&style_pr, 10);
lv_style_set_transition(&style_pr, &transition_dsc_pr);
lv_obj_t * btn1 = lv_btn_create(lv_scr_act());
lv_obj_align(btn1, LV_ALIGN_CENTER, 0, -80);
lv_obj_add_style(btn1, &style_pr, LV_STATE_PRESSED);
lv_obj_add_style(btn1, &style_def, 0);
lv_obj_t * label = lv_label_create(btn1);
lv_label_set_text(label, "btn1");
/*Init the style for the default state*/
static lv_style_t style;
lv_style_init(&style);
lv_style_set_radius(&style, 3);
lv_style_set_bg_opa(&style, LV_OPA_100);
lv_style_set_bg_color(&style, lv_palette_main(LV_PALETTE_BLUE));
lv_style_set_bg_grad_color(&style, lv_palette_darken(LV_PALETTE_BLUE, 2));
lv_style_set_bg_grad_dir(&style, LV_GRAD_DIR_VER);
lv_style_set_border_opa(&style, LV_OPA_40);
lv_style_set_border_width(&style, 2);
lv_style_set_border_color(&style, lv_palette_main(LV_PALETTE_GREY));
lv_style_set_shadow_width(&style, 8);
lv_style_set_shadow_color(&style, lv_palette_main(LV_PALETTE_GREY));
lv_style_set_shadow_ofs_y(&style, 8);
lv_style_set_outline_opa(&style, LV_OPA_COVER);
lv_style_set_outline_color(&style, lv_palette_main(LV_PALETTE_BLUE));
lv_style_set_text_color(&style, lv_color_white());
lv_style_set_pad_all(&style, 10);
/*Init the pressed style*/
static lv_style_t style_pr_2;
lv_style_init(&style_pr_2);
/*Ad a large outline when pressed*/
lv_style_set_outline_width(&style_pr_2, 30);
lv_style_set_outline_opa(&style_pr_2, LV_OPA_TRANSP);
lv_style_set_translate_y(&style_pr_2, 5);
lv_style_set_shadow_ofs_y(&style_pr_2, 3);
lv_style_set_bg_color(&style_pr_2, lv_palette_darken(LV_PALETTE_BLUE, 2));
lv_style_set_bg_grad_color(&style_pr_2, lv_palette_darken(LV_PALETTE_BLUE, 4));
/*Add a transition to the the outline*/
static lv_style_transition_dsc_t trans;
static lv_style_prop_t props2[] = {LV_STYLE_OUTLINE_WIDTH, LV_STYLE_OUTLINE_OPA};
lv_style_transition_dsc_init(&trans, props2, lv_anim_path_linear, 300, 0, NULL);
lv_style_set_transition(&style_pr_2, &trans);
lv_obj_t * btn2 = lv_btn_create(lv_scr_act());
lv_obj_remove_style_all(btn2); /*Remove the style coming from the theme*/
lv_obj_add_style(btn2, &style, 0);
lv_obj_add_style(btn2, &style_pr_2, LV_STATE_PRESSED);
lv_obj_set_size(btn2, LV_SIZE_CONTENT, LV_SIZE_CONTENT);
lv_obj_center(btn2);
lv_obj_t * label2 = lv_label_create(btn2);
lv_label_set_text(label2, "Button");
lv_obj_center(label2);
/* 显示器刷新 */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
tft.startWrite();
tft.setAddrWindow( area->x1, area->y1, w, h );
tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
tft.endWrite();
lv_disp_flush_ready( disp );
/*读取触摸板*/
void my_touchpad_read( lv_indev_drv_t * indev_driver, lv_indev_data_t * data )
uint16_t touchX, touchY;
bool touched = tft.getTouch( &touchX, &touchY, 600 );
if( !touched )
data->state = LV_INDEV_STATE_REL;
data->state = LV_INDEV_STATE_PR;
/*设置坐标*/
data->point.x = touchX;
data->point.y = touchY;
Serial.print( "Data x " );
Serial.println( touchX );
Serial.print( "Data y " );
Serial.println( touchY );
Serial.begin( 115200 ); /*初始化串口*/
String LVGL_Arduino = "Hello Arduino! ";
LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
Serial.println( LVGL_Arduino );
Serial.println( "I am LVGL_Arduino" );
lv_init();
#if LV_USE_LOG != 0
lv_log_register_print_cb( my_print ); /* 用于调试的注册打印功能 */
#endif
tft.begin(); /*初始化*/
tft.setRotation(1); /* 旋转 */
//校准模式。一是四角定位、二是直接输入模拟数值直接定位
//touch_calibrate();//屏幕校准
uint16_t calData[5] = { 145, 3788, 271, 3535, 1 };
tft.setTouch( calData );
lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * 10 );
/*初始化显示*/
static lv_disp_drv_t disp_drv;
lv_disp_drv_init( &disp_drv );
/*将以下行更改为显示分辨率*/
disp_drv.hor_res = screenWidth;
disp_drv.ver_res = screenHeight;
disp_drv.flush_cb = my_disp_flush;
disp_drv.draw_buf = &draw_buf;
lv_disp_drv_register( &disp_drv );
/*初始化(虚拟)输入设备驱动程序*/
static lv_indev_drv_t indev_drv;
lv_indev_drv_init( &indev_drv );
indev_drv.type = LV_INDEV_TYPE_POINTER;
indev_drv.read_cb = my_touchpad_read;
lv_indev_drv_register( &indev_drv );
#if 0
/* 创建简单标签 */
// lv_obj_t *label = lv_label_create( lv_scr_act() );
// lv_label_set_text( label, LVGL_Arduino.c_str() );
// lv_obj_align( label, LV_ALIGN_CENTER, 0, 0 );
lv_example_btn();
#else
/* 尝试lv_examples Arduino库中的一个示例
请确保按照上面所写的内容将其包括在内。
lv_example_btn_1();
// uncomment one of these demos
lv_demo_widgets(); // OK
// lv_demo_benchmark(); // OK
// lv_demo_keypad_encoder(); // works, but I haven't an encoder
// lv_demo_music(); // NOK
// lv_demo_printer();
// lv_demo_stress(); // seems to be OK
#endif
Serial.println( "Setup done" );
lv_timer_handler(); /* 让GUI完成它的工作 */
delay( 5 );
void touch_calibrate()//屏幕校准
uint16_t calData[5];
uint8_t calDataOK = 0;
//校准
tft.fillScreen(TFT_BLACK);
tft.setCursor(20, 0);
tft.setTextFont(2);
tft.setTextSize(1);
tft.setTextColor(TFT_WHITE, TFT_BLACK);
tft.println("按指示触摸角落");
tft.setTextFont(1);
tft.println();
tft.calibrateTouch(calData, TFT_MAGENTA, TFT_BLACK, 15);
Serial.println(); Serial.println();
Serial.println("//在setup()中使用此校准代码:");
Serial.print("uint16_t calData[5] = ");
Serial.print("{ ");
for (uint8_t i = 0; i < 5; i++)
Serial.print(calData[i]);
if (i < 4) Serial.print(", ");
Serial.println(" };");
Serial.print(" tft.setTouch(calData);");
tft.setTextColor(TFT_GREEN, TFT_BLACK);
tft.println("XZ OK!");
tft.println("Calibration code sent to Serial port.");
Wenn ich Nachmittag Zeit finde beschäftige mich mall mit dem ding.
Ich weis nicht ob unter Mac OS geht die Installation der Portable IDE 1.8.19.
wen Ja dann bestätige das.
