hai sir am developing a system. in that system the arduino worked as ras-berry.
like we will connect 1. monitor 2. USB hub 3. etc.. all peripherals...
is there any possibilities please help me sir
Why not just use a Raspberry Pi?
IN RESEARCH ORIENTED I DEVELOPED A SYSTEM THAT IS DEVELOPED BY ARDUINO... SO FOR THAT REASON AM NOT USING RAS-BERRI BECAUSE IT'S A SIMPLE CPU.. SO I DEVELPOED A SYSTEM USING ARDUINO ONLY....
KINDLY HELP ME SIR
Help you with what exactly?
am interfacing usb hub with arduino then it works
keyboard then it also works
mouse it also works
pen-drive it also works
so my aim is connecting monitor to arduino... and creating a special os to that arduino...
like to a simple system as rasberri...finally i concluded design a system/computer with arduino
The Atmega8u2 - that's on the usb side of the board you shot a photo of in the other thread - does out of the box usb2serial only. So what yere you talking about?
@ video: you cannot generate anything useful for a monitor. please consult the specs of your monitor (VGA? HDNMI?) for that. You can use a display with controller+memory.
zwieblum:
Stuck Caps Lock, apparently. ![]()
