My friend and I are working on a project of detecting motor speed using Arduino UNO and Adafruit RGB LCD display.
The motor we have has a encoder which the pulses are 512/revolution. We wrote a script using pulseIn() function and get a good result.
// include the library code:
#include <Wire.h>
#include <Adafruit_RGBLCDShield.h>
#include <utility/Adafruit_MCP23017.h>
// define lcd instance
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
// These #defines make it easy to set the backlight color
#define RED 0x1
#define YELLOW 0x3
#define GREEN 0x2
#define TEAL 0x6
#define BLUE 0x4
#define VIOLET 0x5
#define WHITE 0x7
const int IntPin=7;
unsigned long onTime, offTime;
unsigned long Tdelt, Tnow, Tlast;
unsigned long rpm;
lcd.begin(16, 2);
lcd.setBacklight(TEAL);
Tlast = millis();
// loop here
void loop(){
Tnow = millis();
Tdelt = Tnow - Tlast;
if (Tdelt >= 1000) {
lcd.clear();
Tlast = Tnow;
onTime = pulseIn(7, HIGH);
offTime = pulseIn(7, LOW);
rpm=1000000.0/((onTime+offTime)*512)*60;
lcd.setCursor(0,1);
lcd.print("RPM =");
lcd.setCursor(6,1);
lcd.print(rpm);
uint8_t buttons = lcd.readButtons();
if (buttons) {
lcd.clear();
lcd.setCursor(0,0);
if (buttons & BUTTON_UP) {
lcd.print("UP ");
lcd.setBacklight(RED);
if (buttons & BUTTON_DOWN) {
lcd.print("DOWN ");
lcd.setBacklight(YELLOW);
if (buttons & BUTTON_LEFT) {
lcd.print("LEFT ");
lcd.setBacklight(GREEN);
if (buttons & BUTTON_RIGHT) {
lcd.print("RIGHT ");
if (buttons & BUTTON_SELECT) {
lcd.print("SELECT ");
lcd.setBacklight(VIOLET);
Then, we came across the idea of attachInterrupt which should give us a much precise result. We just modified the existing script which is showed below
#include <Wire.h>
#define RED 0x1
#define YELLOW 0x3
#define GREEN 0x2
#define TEAL 0x6
#define BLUE 0x4
#define VIOLET 0x5
#define WHITE 0x7
const int IntPin=7;
volatile unsigned long cnt=0;
unsigned long oldcnt, nowcnt;
unsigned long rpm;
lcd.begin(16, 2);
pinMode(IntPin, INPUT)
attachInterrupt(digitalPinToInterrupt(IntPin), irq1, CHANGE);
oldcnt = 0;
Tlast = millis();
// if detects interrupt, execute this function
void irq1(){
cnt++;
Serial.println("hahah");
// loop here
void loop(){
Tnow = millis();
lcd.clear();
nowcnt = cnt;
Tlast = Tnow;
rpm = round((nowcnt - oldcnt)*1000/Tdelt)/512 * 60; //takes counts and puts them in Hz (#/s). Encoder has 512 pulses per revolution
oldcnt = nowcnt;
lcd.setCursor(0,1);
lcd.print("RPM =");
lcd.setCursor(6,1);
lcd.print(rpm);
However, this doesn't really work. The number displayed in the LCD is just 0 the whole time. It seems to us that the irq1() has never been called. Unfortunately , we couldn't figure out what to fix this.
Could anyone help us out? Many thanks in advance!!
edit:
The pulse is a square wave
