..I'd like to expand on the example. http://www.arduino.cc/en/Tutorial/AccelerometerMemsic2125 I have the Memsic and working nicely as described.
What I want to get is an X + Y tilt value from that. Actually to tilt from 0 - 90 degrees on one axis and give an output of 1 - 1000 something like that, which would be actually for passing to a digitalWrite to control an LED by PWM.
I see some examples in BASIC here but I can't figure it out. http://www.parallax.com/dl/docs/prod/compshop/SICMemsicTut.pdf
I also found interesting to use this code using pulseIn.
Lire le retour de l'accelerometre avec la fonction pulseIn intégré
int xPin = 7; // x-axis input
int yPin = 6; // y-axis input
unsigned long xDuration;
unsigned long yDuration;
beginSerial(9600);
pinMode(xPin, INPUT);
pinMode(yPin, INPUT);
void loop(){
yDuration = pulseIn(yPin, HIGH);
xDuration = pulseIn(xPin, HIGH);
serialWrite('Y');
serialWrite('-');
printInteger(yDuration);
printByte(10);
serialWrite('X');
serialWrite('-');
printInteger(xDuration);
printByte(10);
It was from another forum post, yes in French!! - at least I could understand that - and works pretty good, cant seem to find the page now.
Any help greatly appreciated,
cheers,
Jim
