So I'm trying to generate a signal through DAC1 and instantly read it with an analog pin, multiple times.
I can't get it to work at all and I don't know if I'm doing something wrong or is an issue with timings within the arduino, but it crashes whenever I press the button that activates this process.
Here is the code:
#include <Arduino_AdvancedAnalog.h>
#include <Arduino.h>
#define N_SAMPLES (4096)
#define SAMPLINGFREQ (96000)
const float freq[19] = {2500, 1500, 1000, 800, 600, 400, 200, 0, 100, 0, 80, 0, 600, 600, 600, 600, 600, 600, 600};
const float ampl[19] = {1, 1, 1, 1, 1, 1, 1, 0, 1, 0, 1, 0, 0.1780, 0.2373, 0.3164, 0.4219, 0.5625, 0.75, 1};
const float ncyc[19] = {1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 6, 6, 6, 6, 6, 6, 6};
const int pwin = round(SAMPLINGFREQ * 0.0269);
const int paq_len = 64;
bool boton = false;
int ctrl = 0;
AdvancedADC adc1(A0);
AdvancedADC adc2(A1);
AdvancedADCDual adc_dual(adc1, adc2);
AdvancedDAC dac0(A12);
AdvancedDAC dac1(A13);
bool lastButtonState = LOW;
float SIGNAL_EMIT0[N_SAMPLES];
float SIGNAL_EMIT1[N_SAMPLES];
unsigned int SIGNAL_REC1[N_SAMPLES];
unsigned int SIGNAL_REC2[N_SAMPLES];
Serial.begin(115200); delay(3000);
pinMode(5, INPUT_PULLUP);
dac0.begin(AN_RESOLUTION_12, SAMPLINGFREQ, paq_len, 32);
dac1.begin(AN_RESOLUTION_12, SAMPLINGFREQ, paq_len, 32);
adc_dual.begin(AN_RESOLUTION_16, SAMPLINGFREQ, paq_len, 32);
int buttonState = digitalRead(5);
int paquetes = N_SAMPLES / paq_len;
// Wave Gen
if (ctrl < 1) {
// Constant voltage
for (int i = 0; i < N_SAMPLES; i++) {
SIGNAL_EMIT0[i] = 127 * 16;
// Sine wave
SIGNAL_EMIT1[i] = 127 * 16;
Serial.println("arrays inicializados");
for (int j = 0; j < sizeof(freq) / sizeof(float); j++) { // loop configurations
if (freq[j] > 0) {
for (int i = 0; i < (int)round(ncyc[j] * (SAMPLINGFREQ / freq[j])); i++) {
SIGNAL_EMIT1[j * pwin + i] = ampl[j] * sin(2 * M_PI * (i * (float)freq[j] / (float)SAMPLINGFREQ)) * 127 * 16 + 127 * 16;
Serial.println("Wave generated");
ctrl++;
if (buttonState == LOW && lastButtonState == HIGH) {
boton = true;
Serial.println("Button pressed");
for (int r = 0; r < 2; r++) {
for (size_t i = 0; i < paquetes; i++) {
SampleBuffer buf1 = dac1.dequeue();
for (size_t k = 0; k < paq_len; k++) {
buf1[k] = SIGNAL_EMIT1[k + (i * paq_len)];
dac1.write(buf1);
SampleBuffer buf3 = adc1.read();
for (int n = 0; n < buf3.size(); n++) {
SIGNAL_REC1[n + (i * paq_len)] = buf3[n];
buf3.release();
for (int p = 0; p < N_SAMPLES; p++) {
Serial.println(SIGNAL_REC1[p]);
boton = false;
else if (!boton) {
voltaje_const();
lastButtonState = buttonState;
void voltaje_const() {
for (size_t j = 0; j < 64; j++) {
buf1[j] = SIGNAL_EMIT0[j];
dac1.write(buf1);
Thanks in advance!
