Extract sine wave
Good evening to everyone,
I am struggling with this issue: I followed all the found posts related to sine waves reading with Arduino Nano.
The signal is taken from a signal generator HP 33120A and has a frequency of 1kHz.
I tried to remove the delay as I read, but anyway you can see the code below, even though it is very very simple:
  // initialize serial communication at 9600 baud rate:
// the loop routine runs over and over again forever:
  // read the input on analog pin 0:
  float sensorValue = analogRead(A0);
  // print out the value you read:
  Serial.println(sensorValue);
  //delayMicroseconds(100);
What I get from python is attached here.
Can anyone help me?
Thank you in advance!
In your reading, did you notice that a "sine wave" is AC? Meaning that half of wave is positive and the other half is negative? That is what "sine" means.
You must be very careful to not connect an AC signal to the Arduino pin unless it is properly processed by external circuitry.
What you're seeing is aliasing. There's no way you can get ~4-byte samples at 2kHz over a 9600 baud serial link.
You should significantly increase the baud rate, and you might want to configure the ADC in free-running mode, or trigger it from a timer, so you get a more accurate sampling rate.
The delay is completely insignificant, compared to the time it takes (1 millisecond) to print a single character at 9600 Baud.
Collect data, then print.
 int data[200]; //room for 200 values
  for (int i=0; i<200; i++) data[i] = analogRead(A0);
  // print out the values:
  for (int i=0; i<200; i++)  Serial.println(data[i]);
The default data collection rate on the Arduino Uno is about 10,000 samples per second, so 200 samples is a small fraction of one cycle of a 1 kHz signal. You can reintroduce the delay to lower the sample rate (minimum sample rate is twice the highest frequency in the signal).
if you are sampling a 1KHz sine wave at 10000samples/second it should look something like (running on an ESP32)
blue trace is the original sine wave (about 750Hz which was offset to give a positive voltage) and the yellow trace is the resultant samples output by a DAC
Yeah!!! The signal has Vpp = 1V and Voffset = 500mV
thank you very much!!
Not true I’m afraid , it relates to the mathematical definition , it does go positive and negative , but that is not what “sine” in this context means , it is short for sinusoidal, different from sign
student_897,
Did you try your original code with frequencies other than 1kHz?
It works correctly with frequencies around 1Hz or less.
1Hz
Original code, with 1Hz input.
250mHz
Original code, with 250mHz input.
using ESP32 output to serial plotter
// ESP32 DAQ
// ESP32 timer interrupts 10000times/second to read ADC and output to DAC
// from ESP32 Sine Wave Example https://deepbluembedded.com/esp32-dac-audio-arduino-examples/
// sample ADC and output to DAC
/* original from
* LAB Name: ESP32 Sine Wave Generation Example
* Author: Khaled Magdy
* DeepBlueMbedded 2023
* For More Info Visit: www.DeepBlueMbedded.com
#include <driver/dac.h>
#include <driver/adc.h>
// Timer0 Configuration Pointer (Handle)
hw_timer_t *Timer0_Cfg = NULL;
// array to save 100 ADC values
#define SAMPLES 1000
volatile int counter = 0, adcsIndex=0;;
volatile unsigned int adcs[SAMPLES]={0};
// The Timer0 ISR Function (Executes Every Timer0 Interrupt Interval)
void IRAM_ATTR Timer0_ISR() {
  // read ADC output to DAC
  unsigned int adc=analogRead(35)>>4;   // adc/16 - 12bits to 8bits
  dac_output_voltage(DAC_CHANNEL_1, adc);
  // save 100 ADC values to array
  if(adcsIndex<SAMPLES) adcs[adcsIndex++]=adc;
  counter++;
  Serial.println("\nESP32 DAC sine wave");
  // Configure Timer0 Interrupt 10000/second
  Timer0_Cfg = timerBegin(0, 800, true);
  timerAttachInterrupt(Timer0_Cfg, &Timer0_ISR, true);
  timerAlarmWrite(Timer0_Cfg, 10, true);
  timerAlarmEnable(Timer0_Cfg);
  // Enable DAC1 Channel's Output
  dac_output_enable(DAC_CHANNEL_1);
  analogSetWidth(12);    // ADC 12bit resolution
  analogSetClockDiv(1);  // fastest converion time
  static long timer = millis();
  if (millis() - timer > 1000) {
    Serial.println(counter);
    counter = 0;
    timer = millis();
  // plot the ADC values in the array
  if(adcsIndex==SAMPLES) {
    for(int i=0;i<SAMPLES;i++)
    Serial.println(adcs[i]);
    //while(1);
1KHz scope - yellow signal input blue DAC output
serial plotter
100Hz scope
100Hz plot
