Write Data on T5577 with Arduino Uno and RDM6300
Hello !
I'm trying to write data on programmable T5577 card by using an Arduino Uno and a RDM6300. My wiring is as follow :
I'm having a hard time to figure out how to set the T5577 to write mode ? And further than that, how to write into the card ? I've tried to monitor the status of the card with availableForWrite() but it always return '0'.
Any thought/suggestion would be very helpful !
:slight_smile:
you state you have already written and tested some code
post it using code tags </> indicating the problems you have
Hi Horace,
Here you go :
#include <AltSoftSerial.h>
AltSoftSerial T5577_Serial(8, 9); // RX : 8 - TX : 9
const int T5577_WRITE_COMMAND = 0xA0;  // Command to put the T5577 card into write mode
  T5577_Serial.begin(9600);
  Serial.println("Setup Completed !");
  char c;
  T5577_Serial.write(T5577_WRITE_COMMAND);
  if (T5577_Serial.availableForWrite()) {
    Serial.print("Available For Write !");
    //T5577_Serial.write("000000123456");
  if (T5577_Serial.available()) {
    c = T5577_Serial.read();
    Serial.print(c);
I've tried multiple values for "T5577_WRITE_COMMAND" but without success.
Also I've seen someone advise to use .flush() on another post, but not sure where to use it.
can you give details of the T7755 board you are using
the AltSoftSerial() code of post #1 is using pins 8 and 9 but your diagram shows connections to pins 8 and 6
The specs of the T5577 :
https://www.asiarfid.com/wp-content/uploads/2021/03/T5577-RFID-Card.pdf
For the pins allocation : I will update the pic, I've uploaded the wrong one, my bad.
