Hello guys, i have a GPS system which logs the required data to serial port, how should i edit the code for it to log it to an SD card in the same format. The code so far is:
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
This sample code demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
ss.begin(GPSBaud);
///Serial.println(F("FullExample.ino"));
//Serial.println(F("An extensive example of many interesting TinyGPS++ features"));
//Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
//Serial.println(F("by Mikal Hart"));
Serial.println(F("Latitude Longitude Date Time Date"));
Serial.println(F("(deg) (deg) (UTC+0) Age"));
Serial.println(F("---------------------------------------------------------------------------------------------------------------------------------------"));
static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
//printInt(gps.satellites.value(), gps.satellites.isValid(), 5);
//printInt(gps.hdop.value(), gps.hdop.isValid(), 5);
printFloat(gps.location.lat(), gps.location.isValid(), 11, 6);
printFloat(gps.location.lng(), gps.location.isValid(), 12, 6);
//printInt(gps.location.age(), gps.location.isValid(), 5);
printDateTime(gps.date, gps.time);
//printFloat(gps.altitude.meters(), gps.altitude.isValid(), 7, 2);
//printFloat(gps.course.deg(), gps.course.isValid(), 7, 2);
//printFloat(gps.speed.kmph(), gps.speed.isValid(), 6, 2);
//printStr(gps.course.isValid() ? TinyGPSPlus::cardinal(gps.course.value()) : "*** ", 6);
unsigned long distanceKmToLondon =
(unsigned long)TinyGPSPlus::distanceBetween(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON) / 1000;
//printInt(distanceKmToLondon, gps.location.isValid(), 9);
double courseToLondon =
TinyGPSPlus::courseTo(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON);
//printFloat(courseToLondon, gps.location.isValid(), 7, 2);
const char *cardinalToLondon = TinyGPSPlus::cardinal(courseToLondon);
// printStr(gps.location.isValid() ? cardinalToLondon : "*** ", 6);
//printInt(gps.charsProcessed(), true, 6);
//printInt(gps.sentencesWithFix(), true, 10);
//printInt(gps.failedChecksum(), true, 9);
smartDelay(1000);
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS data received: check wiring"));
// This custom version of delay() ensures that the gps object
// is being "fed".
static void smartDelay(unsigned long ms)
unsigned long start = millis();
do
while (ss.available())
gps.encode(ss.read());
} while (millis() - start < ms);
static void printFloat(float val, bool valid, int len, int prec)
if (!valid)
while (len-- > 1)
Serial.print('*');
Serial.print(' ');
Serial.print(val, prec);
int vi = abs((int)val);
int flen = prec + (val < 0.0 ? 2 : 1); // . and -
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i=flen; i<len; ++i)
Serial.print(' ');
smartDelay(0);
static void printInt(unsigned long val, bool valid, int len)
char sz[32] = "*****************";
if (valid)
sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz[i] = ' ';
if (len > 0)
sz[len-1] = ' ';
Serial.print(sz);
smartDelay(0);
static void printDateTime(TinyGPSDate &d, TinyGPSTime &t)
if (!d.isValid())
Serial.print(F("********** "));
char sz[32];
sprintf(sz, "%02d/%02d/%02d ", d.month(), d.day(), d.year());
Serial.print(sz);
if (!t.isValid())
Serial.print(F("******** "));
char sz[32];
sprintf(sz, "%02d:%02d:%02d ", t.hour(), t.minute(), t.second());
Serial.print(sz);
printInt(d.age(), d.isValid(), 5);
smartDelay(0);
static void printStr(const char *str, int len)
int slen = strlen(str);
for (int i=0; i<len; ++i)
Serial.print(i<slen ? str[i] : ' ');
smartDelay(0);
