How do you write a code for a 5 volt fan using Arduino? I need the fan to rotate a certain speed according to what my temperature sensor (LM35) reads. If you have any suggestions I would really appreciate it if you could share them with me.
Thank You
How do you write a code ... using Arduino?
Using any text editor. The harder part is getting the hardware to work with the Arduino. A 5V fan likely draws more current than an Arduino pin can supply. So, you need an alternate power source, and a transistor to turn the power source on and off.
What speed?
Your temperature sensor does not read anything. You have to read the temperature sensor.
I suggest you get started writing some code.
