Hi Guys,
I am confused on this.
We are trying to upload/flash C++ code on Arduino wifi Rev2 board and we are getting some problems. Problems like :
Processing uno_wifi_rev2 (platform: atmelmegaavr; board: uno_wifi_rev2; framework: arduino; lib_deps: knolleary/PubSubClient@^2.8)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelmegaavr/uno_wifi_rev2.html
PLATFORM: Atmel megaAVR (1.5.0) > Arduino Uno WiFi Rev2
HARDWARE: ATMEGA4809 16MHz, 6KB RAM, 47.50KB Flash
PACKAGES:
- framework-arduino-megaavr 1.8.7
- toolchain-atmelavr 1.70300.191015 (7.3.0)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 6 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <PubSubClient> 2.8.0 (/home/hemant/Remote_Operation_ESP32/.pio/libdeps/uno_wifi_rev2/PubSubClient)
Building in release mode
avr-g++ -o .pio/build/uno_wifi_rev2/src/cust_libs/led.cpp.o -c -std=gnu++11 -fno-exceptions -fno-threadsafe-statics -fpermissive -Wno-error=narrowing -Os -w -ffunction-sections -fdata-sections -flto -mmcu=atmega4809 -DPLATFORMIO=50205 -DARDUINO_AVR_UNO_WIFI_REV2 -DUNO_WIFI_REV2_328MODE -DMILLIS_USE_TIMERB3 -DF_CPU=16000000L -DARDUINO_ARCH_MEGAAVR -DARDUINO=10808 -DUSB_VID=0x03eb -DUSB_PID=0x2145 "-DUSB_PRODUCT=\"Arduino Uno WiFi Rev2\"" -DUSB_MANUFACTURER=\"Arduino\" -Iinclude -Isrc -I.pio/libdeps/uno_wifi_rev2/PubSubClient/src -I/home/hemant/.platformio/packages/framework-arduino-megaavr/cores/arduino/api/deprecated -I/home/hemant/.platformio/packages/framework-arduino-megaavr/cores/arduino -I/home/hemant/.platformio/packages/framework-arduino-megaavr/variants/uno2018 src/cust_libs/led.cpp
src/cust_libs/led.cpp:15:10: fatal error: iostream: No such file or directory
#include <iostream>
compilation terminated.
As you can see, compiler which is getting used for this process is avr-g++ which might not be supporting the library. Questions are:
Why does it not support?
How can we resolve this?
Thanks in advance. I would be happy to write more details if needed.
P.S. I havn't written detailed code since I thought error is self explanatory.
