Hello All,
I'm working with the MT-DB-U4 breakout board which uses the ATMega32U4 (16 MHz clock) with Arduino (CDC) bootloader installed. I was working on creating a simple Timer1 Library for use with the microcontroller when I noticed some strange behavior with Timer 1. I later isolated the problem to the code below:
DDRC |= (bit(7) | bit(6));
TCCR1B = (1 << WGM12) | (1 << CS11); // Configure timer 1 for CTC mode w. clk/8 prescaler
OCR1A = 10000; // Set timer value for 5ms interrupts
TIMSK1 |= (1 << OCIE1A); // Output Compare A Match Interrupt Enable
sei(); // enable interrupts
// Do Nothing
ISR(TIMER1_COMPA_vect)
PORTC ^= (bit(7) | bit(6));
This code is supposed to fire the interrupt every 5 ms (which results in a pin toggle frequency of 100 Hz). However, when I run the code and observe the output, the actual toggle frequency is 3.908 kHz. I also noticed that if I chance the value of OCR1A that the output frequency isn't affected. But if I change the prescalar value, the output changes accordingly. My Goal is to have the timer running in CTC mode so that I can have it periodically fire the interrupt. Can anyone spot anything wrong with this code?
Thanks!
Jason O
