Hello, yesterday i connected my ESP32 development board to my pc and it connected,like normal. Then i erased the sketch and now it will not connect anymore.
Could anyone help me please.
I'm a noob to all of this but i want to learn for a small project i want to start for growing chilli peppers.
welcome to the arduino-forum.
I'm pretty sure that you agree and will follow the way how to solve your problem mimimum 200 minutes faster.
This requires to invest 20 minutes of your precious time to read how to speedup solving your problems.
Directly after registering you got presented informations how to speed up solving your problem.
You should really read it.
First of all sorry for my first post, this was mainly because I am frustrated because I can't get it to work. It is an ESP32 Development Board type C, CP2102 WiFi+Bluetooth Dual core ESP32-DevKitC 38 Pin.
What happens is that I connect it to my laptop yesterday, using a USB C cable and it is recognized in Arduino IDE, I try the first sketch to make an LED flash. This did not work and so I deleted the sketch. Now the board is no longer recognized.
What I have already tried is resetting the board using the button on the board, other cables, without the development board, all this without the desired result. Now I have connected an Arduino Uno to see if my USB ports still work. This shows that the ports are still good.
So my question is whether this can still be solved or whether the board is probably broken?
My ultimate goal is to use this to create an automated greenhouse on a small scale, to grow chilli peppers early in the year, to get a good start in the summer. They are mainly heat-loving plants, which need to remain fairly moist in the early stages of growth. With the necessary sensors this should be automatable. Such as humidity, temperature and soil moisture. Whether or not read out via a screen or telephone.
Hoping that I have provided you with enough information to help me further. As I said in my first post, I am a newbie in the field of programming, but I do have a background in electronics.
