Hey every one,
Newbie here, I saw this vid on youtube How to make an AMAZING video ring-light for just $25 - YouTube where this guy created a DSLR ring light out of white high current LED's and I thought how cool it would be to do that with WS2812's
well since I am new, I had to look around and I found a sketch:
//FastLED_AnalogueInput.ino
Using a potentiometer to control colour, brightness and speed.
Wire up as per http://arduino.cc/en/Tutorial/AnalogInput.
You can connect the wiper, to any analogue input pin, and
adjust the settings below.
You will need three 10k potentiometers.
#include <FastLED.h>
#define LED_PIN 10 // which pin are LEDS connected to?
#define NUM_LEDS 8
#define COLOR_ORDER RGB
#define LED_TYPE WS2812 // i'm using WS2811s, FastLED supports lots of different types.
set your desired minimum and maxium brigtness settings here.
Valid values are 0 - 255
With 0 being fully dim, or not lit, and 255 being fully on.
Therefore half power, or 50%, would be 128
#define MAX_BRIGHTNESS 255 // Thats full on, watch the power!
#define MIN_BRIGHTNESS 64 // set to a minimum of 25%
const int brightnessInPin = A0; // The Analog input pin that the brightness control potentiometer is attached to.
const int speedInPin = A1; // Analog input pin that the speed control potentiometer is attached to.
const int colourInPin = A2; // The Analog input pin that the colour control potentiometer is attached to.
struct CRGB leds[NUM_LEDS];
delay(3000); // in case we do something stupid. We dont want to get locked out.
LEDS.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
FastLED.setBrightness(MAX_BRIGHTNESS);
// read the analog brightness value:
int brightValue = analogRead(brightnessInPin);
// map it to the range of the FastLED brightness:
int mappedValue = map(brightValue, 0, 1023, 0, 255);
At this point, brightness could be full off (mappedValue == 0)
or it could be fully on (mappedValue == 255).
if you are ruuning from a battery pack, or in a dark room, you
may not want full brightness.
Or if you are in daylight, you may not want the pixels to go out.
the following code, checks if mappedValue is above or below our defined
brightness settings above.
It works like this.
we get mappedValue: if mappedValue is between MIN_BRIGHTNESS and MAX_BRIGHTNESS.
we get MIN_BRIGHTNESS: if mappedValue is less than our defined MIN_BRIGHTNESS.
we get MAX_BRIGHTNESS: if mappedValue is greater than our defined MAX_BRIGHTNESS
so, it limits range of brightness values.
// outputValue = constrain(mappedValue, MIN_BRIGHTNESS, MAX_BRIGHTNESS);
// now we set the brightness of the strip
// FastLED.setBrightness(outputValue)
// read the analog speed value:
int speedValue = analogRead(speedInPin);
// map it to a value used in delay();
int delayValue = map(speedValue, 0, 1023, 10, 300);
int hueValue = analogRead(colourInPin);
int mappedHue = map(hueValue, 0, 1023, 0, 255);
// First slide the led in one direction
for(int i = 0; i < NUM_LEDS; i++) {
// Set the i'th led to the chosen colour
leds = CHSV(mappedHue, 255, 255);
- // Show the leds*
- FastLED.show();*
- // now that we've shown the leds, reset the i'th led to black*
_ leds = CRGB::Black;_
* // Wait a little bit before we loop around and do it again*
* delay(delayValue); *
* // Now go in the other direction. *
* for(int i = NUM_LEDS-1; i >= 0; i--) {
_ // Set the i'th led to the chosen colour*_
_ leds = CHSV(mappedHue, 255, 255);
* // Show the leds*
* FastLED.show();
leds = CRGB::Black;
}*_
The problem is:
1. I dont need the Speed control, I just want the color and MAYBE the brightness,
right now It is running and I have 10k pulldown resistors on the A0 & A1 Pins,
If anyone could help me I would be appreciated.
I plan to run 16-20 LED's it would be nice to have all stay on at once so I can change the color on the fly
