WS2812 LEDs Dont Work Correctly; BLDC Motor Driver Suggestions
Hi all!
I am trying to add LEDs to my scooter project I recently finished! Well I did already, and they all worked great, but now im having issues. I decided to add a strip of 5 LEDs right behind the display, and a strip of 5 on the tail. When I first coded it, both strips functioned correctly according to my code. I moved the scooter after programming, and the tail light shut off!
I have now tried re-coding it, replacing that strip, replacing the other strip, replacing the wire, etc. with no luck! What could be the problem!? This doesnt make any sense :thinking:.
Thanks in advance for any ideas!
My guess is either your flux capacitor is failing to reach the proper frequency, the dynamometer is picking up noise, or you need to show us your code and schematic so we can better help you.
Thanks for your response @2112 !
Ummm, my code is ~1200 lines long :grimacing:. I can share a schematic and my code though if that'll help. Also, all my code is non-blocking so it was a bit more complicated than just using "delay"s.
No, I am positive its the thimagig on the whatchamacallit, I saw the flux capacitor laying by the back porch. The OP just got a sample of what transients can do on vehicles. The power systems are very nasty. If he posts an annotated schematic showing what he did including all power sources that would help. Also the OP needs to post links to technical information on all of the hardware devices.
Thanks @gilshultz for the response!
It's always that :man_facepalming:
Sooo, information you want, information you shall have...
Here is my schematic:
And here is my current code:
#include "DFRobot_GDL.h"
#include <XPT2046_Touchscreen.h>
#include <SPI.h>
#include "DFRobot_GNSS.h"
#include "DFRobot_BMI160.h"
#include "DFRobot_AHT20.h"
#include "DFRobot_GR10_30.h"
#include <EEPROM.h>
#include "thingProperties.h"
#include "WiFi.h"
#include <WiFiMulti.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
//Testing
bool testing = false;
//WiFi
int wifitimerlength = 15000;//time in milliseconds before connection fails
int wifitimer = 0;
int wifismarttimer = 20;//time in seconds to wait for smartconfig
int wifistimer = 0;
//Motor Driver
#define brakepin 14 //D6
#define cruisepin 4 //D12 // actually enable pin, so able to push scooter manually when on
#define speedpin 13 //D7
#define rpmpin A4
// PWM properties for motor driver
const int freq = 5000;
const int speedChannel = 0;
const int resolution = 8;
//Display
#define TFT_DC  25 //D2
#define TFT_CS  14 //D6
#define TFT_RST 26 //D3
#define TFT_BL  12 //D13
#define TOUCH_CS 4 //D12
//Throttle
#define throttlepin A0 //throttle pin
int throttleoffvalue = 0;
int throttleonvalue = 4095;
int throttleval = 0;
//Touch coordinates for calibration
#define touchxmin 290
#define touchxmax 3750
#define touchymin 300
#define touchymax 3700
#define backcolor COLOR_RGB565_WHITE
#define erasecolor backcolor//COLOR_RGB565_LGRAY
#define backgroundcolor COLOR_RGB565_CYAN
//gnss / display
long readgnssinc = 1000;//time between GNSS readings
unsigned long lastreadgnss = 0;
long readdisplayinc = 1000;//time between display updates
unsigned long lastdisplay = 0;
sTim_t utc;
sTim_t date;
sLonLat_t latitude;
sLonLat_t longitude;
double altitude;
uint8_t satelites;
double knots;
double course;
//AHT20
float temperature = 0;
float humidity = 0;
//WS2812
#define LEDPIN 16//D11
#define NUMPIXELS 10
float lastcoursereading = 0;
float coursechangetime = 1000;
float lastcoursereadtime = 0;
float courseturnsignalinc = 10; //degrees of turning for turning signal to turn on
float coursechange = 0;
float lastspeedreading = 0;
float speedchangetime = 1000;
float lastspeedreadtime = 0;
float speedbrakeinc = -0.10;//decrease in speed before brake light turns on
int leftturn1 = 0;
int leftturn2 = 1;
int leftturn3 = 2;
int rightturn3 = 2;
int rightturn2 = 3;
int rightturn1 = 4;
int brake1 = 5;
int brake2 = 6;
int brake3 = 7;
int brake4 = 8;
int brake5 = 9;
unsigned long startmillis = 0;
int animationcountleft = 1;
int animationcountright = 1;
bool leftturnsignal = false;
bool rightturnsignal = false;
float speeddiferrence = 0;
bool headlight = false;
//Password
bool locked = false;//true
uint16_t gestures;
int passwordlength = 3;
#define EEPROM_SIZE passwordlength
int password[] = {GESTURE_UP,GESTURE_DOWN,GESTURE_LEFT};//Adjustable gesture password; can adjust password length (right now it is set to 3 in the "passwordlength" integer)
int passc = 0;//pass count
//battery
float batteryvolts = 0;
#define batterypin A2
int batteryreadings = 10;//number of readings to average, more for a smoother more reliable response
long readbatteryint = 20;//time in milliseconds between battery readings
unsigned long lastbatreading = 0;
long R1 = 15000;//15k ohms
long R2 = 1000;//1.1k ohms
int curbatread = 0;
int batsum = 0;
#define batteryamps 5
#define batteryvoltage 36 //voltage and amp hours of battery, or uncomment "batterywattage" below instead
//#define batterywattage 180
#define motorwattage 350
#define maxcruisespeed 15 //mph //20
bool lastebrakeon = false;
unsigned long lastebrakechange = 0;
bool ebrakeon = false;
bool lockbtnon = false;
bool lastcruiseon = false;
unsigned long lastcruisechange = 0;
bool cruiseon = false;
float cruisesetspeed = 0;
int previousotherx1 = 0;
int previousothery1 = 0;
int previousotherx2 = 0;
int previousothery2 = 0;
bool stole = false;
float speedlimit = 0.00;
bool lastturnstat = false;
XPT2046_Touchscreen ts(TOUCH_CS);
DFRobot_ILI9341_240x320_HW_SPI screen(/*dc=*/TFT_DC,/*cs=*/TFT_CS,/*rst=*/TFT_RST);
DFRobot_GNSS_I2C gnss(&Wire,GNSS_DEVICE_ADDR);
DFRobot_BMI160 bmi160;
const int8_t i2c_addr = 0x69;
DFRobot_AHT20 aht20;
DFRobot_GR10_30 gr10_30(/*addr = */GR10_30_DEVICE_ADDR, /*pWire = */&Wire);
Adafruit_NeoPixel pixels(NUMPIXELS, LEDPIN, NEO_GRB + NEO_KHZ800);
WiFiMulti wifiMulti;
//BMI160
struct dat{
  float x = 0;
  float y = 0;
  float z = 0;
dat accel;
struct data{
  float x = 0;
  float y = 0;
  float z = 0;
data gyro;
float baseyangle = 0;
  wifiMulti.addAP("Apple Network 85064d", "12344321");
  wifiMulti.addAP("ssid_from_AP_2", "your_password_for_AP_2");
  wifiMulti.addAP("ssid_from_AP_3", "your_password_for_AP_3");
  Serial.println("Connecting Wifi...");
  while (!(wifiMulti.run() == WL_CONNECTED)){
    wifitimer++;
    delay(1);
    if (wifitimer > wifitimerlength){
      goto ex;
  ex:
  if(wifiMulti.run() == WL_CONNECTED) {
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
  else {
    WiFi.mode(WIFI_AP_STA);
    WiFi.beginSmartConfig();
    Serial.println("Waiting for SmartConfig.");
    while (!WiFi.smartConfigDone()) {
      Serial.print(".");
      wifistimer++;
      if (wifistimer > wifismarttimer){
        goto exi;
    //Wait for WiFi to connect to AP
    Serial.println("Waiting for WiFi");
      Serial.print(".");
      wifitimer++;
      if (wifitimer > wifismarttimer*2){
        goto exi;
    Serial.println("WiFi Connected.");
    Serial.print("IP Address: ");
  exi:
  Serial.println("");
  Serial.println("SmartConfig done.");
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  digitalWrite(speedpin, LOW);
  pinMode(rpmpin, INPUT);
  EEPROM.begin(EEPROM_SIZE);
  for (int i=0;i<passwordlength;i++){//read password from EEPROM
    password[i] = EEPROM.read(i);
  pinMode(batterypin, INPUT);
  pinMode(throttlepin, INPUT);
  pinMode(brakepin, OUTPUT);
  pinMode(cruisepin, OUTPUT);
  pinMode(speedpin, OUTPUT);
  attachInterrupt(rpmpin, interruptRoutine, FALLING);
  ledcSetup(speedChannel, freq, resolution);
  ledcAttachPin(speedpin, speedChannel);
  if(!gnss.begin()){
    Serial.println("NO GPS device !");
  gnss.enablePower();
  gnss.setGnss(eGPS_BeiDou_GLONASS);
  gnss.setRgbOn();
  if (bmi160.softReset() != BMI160_OK){
    Serial.println("bmi160 reset false");
    //while(1);
  if (bmi160.I2cInit(i2c_addr) != BMI160_OK){
    Serial.println("bmi160 init false");
    //while(1);
  readAccelGyro();
  baseyangle = gyro.y;
  //baseyangle = 20;
  uint8_t status;
  if((status = aht20.begin()) != 0){
    Serial.print("AHT20 sensor initialization failed. error status : ");
    Serial.println(status);
  pixels.begin();
  pixels.clear();
  startGestureSensor();
  ts.begin();
  ts.setRotation(3);
  screen.begin();
  screen.setRotation(3);
  startDisplay();
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  OTAStart();
  if(wifiMulti.run() != WL_CONNECTED) {
    Serial.println("WiFi not connected!");
  ArduinoOTA.handle();
  ArduinoCloud.update();
  if ((millis() - lastreadgnss) > readgnssinc){
    readGNSS();
    lastreadgnss = millis();
  if (locked){
    lockedloop();
    if (satelites > 8){
      if (knots > 2){
        ifttt_counter++;
    return;
  if (ts.touched()){
    TS_Point p = ts.getPoint();
    handleTouch(abs(map(p.x,touchxmax,touchxmin,0,320)),abs(map(p.y,touchymax,touchymin,0,240)));
  readAccelGyro();
  readTempHum();
  readBattery();
  readThrottle();
  if (!rightturnsignal && !leftturnsignal){
    if (lastturnstat){
      startDisplay();
    if (((millis() - lastdisplay) > readdisplayinc) && (satelites != 0)){
      handleSlowDisplay();
      lastdisplay = millis();
    handleFastDisplay();
    handleDisplayButtons();
    float handleAngleLineValue = (baseyangle*100) - (gyro.y*100);
    handleAngleLine(handleAngleLineValue);
  else {
    if (rightturnsignal){
      screen.fillRoundRect(15,38,290,195,12,backgroundcolor);
      screen.setTextSize(14);
      screen.setCursor(100,75);
      screen.setTextColor(COLOR_RGB565_RED);
      screen.print(">");
    else if (leftturnsignal){
      screen.print("<");
  handleGestures();
  handleMotordriver();
  handleLeds();
  handleSpeedLimit();
void onLockChange()  {
  if (lock == true){
    screen.fillRoundRect(15,50,80,50,12,backgroundcolor);
    screen.setTextSize(2);
    screen.setCursor(20,70);
    screen.print("Locked");
    screen.fillRoundRect(225,50,80,50,12,backgroundcolor);
    screen.setCursor(235,70);
    screen.setTextColor(COLOR_RGB565_GREEN);
    screen.print("E ON");
    ebrakeon = true;
    locked = true;
  if (lock == false){
    ebrakeon = false;
    locked = false;
void onMaxspeedChange()  {
  speedlimit = maxspeed;
void handleSpeedLimit(){
  if (knots > speedlimit){
    throttleval = throttleval/2;
void handleTouch(int x,int y){
  Serial.print("Touch X = " + String(x));
  Serial.println(" | Touch Y = " + String(y));
  if (x >= 215 && x <= 320){
    if (y < 45){
      changepassword();
    else if (y >= 45 && y <= 104){
      if ((millis() - lastebrakechange) > 1000){//wait 1 second between reading button as pressed
        if (knots < 5){
          ebrakeon = !ebrakeon;
          lastebrakechange = millis();
    else if (y >= 105 && y <= 160){
      if ((millis() - lastcruisechange) > 1000){//wait 1 second between reading button as pressed
        cruiseon = !cruiseon;
        cruisesetspeed = knots;
        lastcruisechange = millis();
  else if (x >= 5 && x <= 105){
    if (y < 45){
      changepassword();
    else if (y >= 45 && y <= 105){
      if (!lockbtnon){
        lockbtnon = true;
      else {
        screen.setCursor(15,115);
        screen.print("Unlock with gestures!");//display unlock warning
        delay(3000);
        screen.fillRect(14, 114, 290, 20, erasecolor);//erase display unlock warning
void handleSlowDisplay(){
  //satelites
  screen.setCursor(287,15);
  screen.fillRect(286, 13, 26, 18, erasecolor);//backcolor
  if (satelites <= 5){
  else if (satelites > 5 && satelites <= 8){
    screen.setTextColor(COLOR_RGB565_ORANGE);
  else if (satelites > 8){
  screen.print(String(satelites));
  //Serial.println(satelites);
  //speed (knots)
  screen.setTextSize(4);
  if (knots >= 10){
    screen.setCursor(100,62);//118,62
    screen.fillRect(92, 58, 132, 37, erasecolor);//117, 57, 90, 30,
  else {
    screen.setCursor(110,62);//118,62
    screen.fillRect(100, 58, 105, 37, erasecolor);//117, 57, 90, 30,
  if (knots <= 1.00){
    screen.setTextColor(COLOR_RGB565_BLUE);
  else if (knots > 1.00 && knots <= 12.00){
  else if (knots > 12.00 && knots <= 19.00){
  else {
  screen.print(knots);
  //if (knots >= cruisesetspeed+4.00){//reset cruise if current speed goes above cruisesetspeed + 4
  //  cruiseon = false;
  //temperature
  screen.setCursor(12,215);
  screen.fillRect(11,214,55,17,erasecolor);
  screen.print(temperature,1);//temperature with only one decimal
  screen.drawCircle(64,209,2,COLOR_RGB565_GREEN);//degrees symbol
  //humidity
  screen.setCursor(270,215);
  screen.fillRect(269,214,40,17,erasecolor);
  screen.print(humidity,0);//humidity with no decimals
  screen.print("%");//percentage symbol
  //battery
  screen.setCursor(140,215);
  screen.fillRect(139,214,65,17,erasecolor);
  float batpercent = map(batteryvolts*10,300,420,0,100); //map battery voltage to a percentage value of 0 - 100
  if (batpercent > 80.0){
  else if (batpercent <= 80.0 && batpercent > 50.0){
    screen.setTextColor(COLOR_RGB565_DGREEN);
  else if (batpercent <= 50.0 && batpercent > 25.0){
    screen.setTextColor(COLOR_RGB565_YELLOW);
  else if (batpercent <= 25.0 && batpercent > 12.0){
  else if (batpercent <= 12.0 && batpercent > 5.0){
  else {
    batterywarning();
  screen.print(batpercent,0);//battery percentage with no decimals
  //dist to empty; for 36V 5AH (180W) that would be (at 20mph) 8 miles or 0.4 hours
  float batwatts = 0;
  #ifdef batterywattage
    batwatts = batterywattage;
  #else
    batwatts = batteryvoltage * batteryamps;
  #endif
  float bathours = batwatts / motorwattage;
  float batmiles = maxcruisespeed * bathours;
  float batmilesleft = map(batteryvolts*10,300,420,0,batmiles*100);//map function cant map floating values
  batmilesleft = batmilesleft / 100;
  float bathoursleft = map(batteryvolts*10,300,420,0,bathours*100);//map function cant map floating values
  bathoursleft = bathoursleft / 100;
  float batminutesleft = map(bathoursleft*100,0,100,0,600);//map function cant map floating values
  batminutesleft = batminutesleft / 10;
  screen.setTextSize(3);
  screen.setCursor(75,187);
  screen.fillRect(74,186,198,24,erasecolor);
  screen.print(abs(batmilesleft),1);//miles with no decimals
  screen.print("m|");//miles symbol
  screen.print(abs(batminutesleft),1);//hours with two decimals
  screen.print("m");
  //Angle
  screen.setCursor(140,95);
  screen.fillRect(139,94,65,17,erasecolor);
  screen.print(gyro.y*100,1);//temperature with only one decimal
void handleFastDisplay(){
  //Angle
  screen.fillRect(139,94,75,17,erasecolor);
  screen.print((baseyangle*100)-(gyro.y*100),1);//angle with only one decimal
void handleDisplayButtons(){
  //e-brake button
  if (ebrakeon != lastebrakeon){
    if (!ebrakeon){
      screen.fillRoundRect(220,45,90,60,12,erasecolor);//erase
      screen.drawRoundRect(225,50,80,50,12,backgroundcolor);
      screen.print("E OFF");
    else {
    lastebrakeon = ebrakeon;
  if (!lockbtnon){
    screen.fillRoundRect(12,45,90,60,12,erasecolor);//erase
    screen.drawRoundRect(15,50,80,50,12,backgroundcolor);
    screen.setTextSize(1);
    screen.setCursor(25,70);
    screen.print("Unlocked");
  else if (lockbtnon || locked){
    ebrakeon = true;
    locked = true;
  if (cruiseon != lastcruiseon){
    if (!cruiseon){
      screen.fillRoundRect(220,105,90,60,12,erasecolor);//erase
      screen.drawRoundRect(225,110,80,50,12,backgroundcolor);
      screen.setCursor(235,130);
      screen.print("C OFF");
    else {
      screen.fillRoundRect(225,110,80,50,12,backgroundcolor);
      screen.print("C ON");
    lastcruiseon = cruiseon;
void handleAngleLine(float angle1){
  int x=160,y=140; //center point of the two lines
  screen.drawLine(x, y, previousotherx1, previousothery1, erasecolor);//line going right
  screen.drawLine(x+1, y+1, previousotherx1+1, previousothery1+1, erasecolor);//double thick line
  screen.drawLine(x, y, previousotherx2, previousothery2, erasecolor);//line going left
  screen.drawLine(x+1, y+1, previousotherx2+1, previousothery2+1, erasecolor);//double thick line
  #define DEG2RAD 0.0174532925
  float screenangle1 = 135; //value for right line to make it level
  float screenangle2 = 315; //value for left line to make it level; appears to be one line instead of two separate ones
  float angle2 = angle1;
  int w=100,h=100; //length of each line; one going right and one going left
  #define linecolor COLOR_RGB565_NAVY
  float cosa1 = cos((screenangle1+angle1) * DEG2RAD), sina1 = sin((screenangle1+angle1) * DEG2RAD);
  int otherx1 = x - ((w * cosa1 / 2) - (h * sina1 / 2));
  int othery1 = y - ((h * cosa1 / 2) + (w * sina1 / 2));
  screen.drawLine(x, y, otherx1, othery1, linecolor);//line going right
  screen.drawLine(x+1, y+1, otherx1+1, othery1+1, linecolor);//double thick line
  float cosa2 = cos((screenangle2+angle2) * DEG2RAD), sina2 = sin((screenangle2+angle2) * DEG2RAD);
  int otherx2 = x - ((w * cosa2 / 2) - (h * sina2 / 2));
  int othery2 = y - ((h * cosa2 / 2) + (w * sina2 / 2));
  screen.drawLine(x, y, otherx2, othery2, linecolor);//line going left
  screen.drawLine(x+1, y+1, otherx2+1, othery2+1, linecolor);//double thick line
  previousotherx1 = otherx1;
  previousothery1 = othery1;
  previousotherx2 = otherx2;
  previousothery2 = othery2;
void batterywarning(){
void changepassword(){
  screen.fillScreen(backcolor);
  screen.fillScreen(COLOR_RGB565_DGRAY);
  screen.fillRoundRect(0, 0, 320, 240, 15, backgroundcolor);
  screen.fillRoundRect(5, 5, 310, 230, 15, backcolor);
  screen.setTextColor(backgroundcolor);
  screen.setCursor(30, 11);
  screen.print("Change PASS");
  screen.drawFastHLine(10, 35, 300, COLOR_RGB565_GREEN);
  screen.drawFastHLine(10, 36, 300, COLOR_RGB565_GREEN);
  screen.setCursor(40, 100);
  screen.print("Do three gestures to set new password...");
  password[0] = 0;
  password[1] = 0;
  password[2] = 0;
  int gesturepasscount = 0;
  redo:
  if(gr10_30.getDataReady()){
    gestures = gr10_30.getGesturesState();
    if(gestures&GESTURE_UP){
      Serial.println("Up");
      password[gesturepasscount] = GESTURE_UP;
    if(gestures&GESTURE_DOWN){
      Serial.println("Down");
      password[gesturepasscount] = GESTURE_DOWN;
    if(gestures&GESTURE_LEFT){
      Serial.println("Left");
      password[gesturepasscount] = GESTURE_LEFT;
    if(gestures&GESTURE_RIGHT){
      Serial.println("Right");
      password[gesturepasscount] = GESTURE_RIGHT;
    if(gestures&GESTURE_FORWARD){
      password[gesturepasscount] = GESTURE_FORWARD;
    if(gestures&GESTURE_BACKWARD){
      password[gesturepasscount] = GESTURE_BACKWARD;
    if(gestures&GESTURE_CLOCKWISE){
      password[gesturepasscount] = GESTURE_CLOCKWISE;
    if(gestures&GESTURE_COUNTERCLOCKWISE){
      password[gesturepasscount] = GESTURE_COUNTERCLOCKWISE;
    if(gestures&GESTURE_WAVE){
      password[gesturepasscount] = GESTURE_WAVE;
    if(gestures&GESTURE_HOVER){
      password[gesturepasscount] = GESTURE_HOVER;
    if(gestures&GESTURE_CLOCKWISE_C){
      password[gesturepasscount] = GESTURE_CLOCKWISE_C;
    if(gestures&GESTURE_COUNTERCLOCKWISE_C){
      password[gesturepasscount] = GESTURE_COUNTERCLOCKWISE_C;
    EEPROM.write(gesturepasscount,password[gesturepasscount]);
    EEPROM.commit();
    gesturepasscount++;
    Serial.println("gesturepasscount: " + String(gesturepasscount));
  if (gesturepasscount != passwordlength){
    goto redo;
  Serial.println("Finished!");
  startDisplay();
void readThrottle(){
  throttleval = map(analogRead(throttlepin),throttleoffvalue,throttleonvalue,0,4095);
  Serial.println("Throttle: " + String(throttleval));
void readBattery(){
  if ((millis() - lastbatreading) > readbatteryint){
    if (curbatread < batteryreadings){
      batsum = batsum + analogRead(batterypin);
      curbatread++;
    else{
      float batteryread = batsum/batteryreadings;
      float batpinvolt = (batteryread*3.3)/4095;//3.3V and 4095 is the max resolution of ESP32
      if (testing){
        batpinvolt = 2.2;
      batteryvolts = batpinvolt*16;//(1000/(15000+1000)); //(R2/(R1+R2));//VOUT = VIN*R2/R1+R2 ; classic equation for voltage dividers
      curbatread = 0;
    lastbatreading = millis();
void handleGestures(){
      cruiseon = true;
      cruiseon = false;
        pixels.clear();
        pixels.show();
      else {
        leftturnsignal = true;
        lastturnstat = true;
        pixels.clear();
        pixels.show();
      else {
        rightturnsignal = true;
      Serial.println("Forward");
      ebrakeon = true;
      Serial.println("Backward");
      ebrakeon = false;
      Serial.println("Clockwise");
      Serial.println("Contrarotate");
      Serial.println("Wave");
      Serial.println("Hover");
      Serial.println("Continuous clockwise");
      headlight = !headlight;
      Serial.println("Continuous counterclockwise");
      ebrakeon = true;
      locked = true;
void lockedloop(){
    Serial.print("Gesture: ");
    Serial.println(gestures);
    if (gestures&password[passc]){
      Serial.println("Correct!");
      Serial.println(password[passc]);
      passc++;
      Serial.println("PASSC: " + String(passc));
    else {
      Serial.println("Wrong");
      passc=0;
  if (passc >= passwordlength){
    Serial.println("Unlocked!");
    passc=0;
    locked = false;
    lock = false;
void readGNSS(){
  utc = gnss.getUTC();
  date = gnss.getDate();
  latitude = gnss.getLat();
  longitude = gnss.getLon();
  altitude = gnss.getAlt();
  satelites = gnss.getNumSatUsed();
  knots = gnss.getSog();
  course = gnss.getCog();
void readAccelGyro(){
  int i = 0;
  int rslt;
  int16_t accelGyro[6]={0};
  //get both accel and gyro data from bmi160
  //parameter accelGyro is the pointer to store the data
  rslt = bmi160.getAccelGyroData(accelGyro);
  if(rslt == 0){
    for(i=0;i<6;i++){
      if (i<3){
        //the first three are gyro data
        //Serial.print(accelGyro[i]*3.14/180.0);Serial.print("\t");
        if (i==0){accel.x = accelGyro[i]*3.14/180.0;}
        else if (i==1){accel.y = accelGyro[i]*3.14/180.0;}
        else if (i==2){accel.z = accelGyro[i]*3.14/180.0;}
      }else{
        //the following three data are accel data
        //Serial.print(accelGyro[i]/16384.0);Serial.print("\t");
        if (i==3){gyro.x = accelGyro[i]/16384.0;}
        else if (i==4){gyro.y = accelGyro[i]/16384.0;}
        else if (i==5){gyro.z = accelGyro[i]/16384.0;}
    //Serial.println();
  }else{
    Serial.println("err");
void readTempHum(){
  if(aht20.startMeasurementReady(/* crcEn = */true)){
    temperature = aht20.getTemperature_F();
    humidity = aht20.getHumidity_RH();
void handleMotordriver(){
  digitalWrite(cruisepin,cruiseon);
  digitalWrite(brakepin,ebrakeon);
  ledcWrite(speedChannel, map(throttleval,400,4095,0,255));//pwm signal for speed
void handleLeds(){
  if ((millis() - lastcoursereadtime) > coursechangetime){//handle turning signal
    coursechange = course - lastcoursereading;
    lastcoursereading = course;
    lastcoursereadtime = millis();
  if (leftturnsignal == true || rightturnsignal == true){
      //brakelight(3);
      leftblinker();
      //brakelight(3);
      rightblinker();
  else if (leftturnsignal == false && rightturnsignal == false){
    if (abs(coursechange) > courseturnsignalinc){
      if (coursechange < 0){
        //brakelight(3);
        leftblinker();
      else {
        //brakelight(3);
        rightblinker();
    else {
      if (speeddiferrence >= speedbrakeinc){
        //pixels.clear();
        //pixels.show();
        brakelight(2);
  if ((millis() - lastspeedreadtime) > speedchangetime){//handle brake light
    speeddiferrence = knots - lastspeedreading;
    if (speeddiferrence < speedbrakeinc){
        pixels.setPixelColor(5, pixels.Color(255,0,0));
        pixels.setPixelColor(6, pixels.Color(255,0,0));
        pixels.show();
        pixels.setPixelColor(9, pixels.Color(255,0,0));
        pixels.setPixelColor(8, pixels.Color(255,0,0));
        pixels.show();
      else {
        brakelight(1);
    //else {
    //  brakelight(1);
    lastspeedreading = knots;
    lastspeedreadtime = millis();
  if (headlight){
    headlights(true);
  else {
    headlights(false);
void leftblinker(){
  int turningsignalcolor = pixels.Color(0, 20, 255);
  if (animationcountleft == 1){
    if ((millis() - startmillis) < 250){
      pixels.setPixelColor(7, turningsignalcolor);
      pixels.show();
    else {
      animationcountleft++;
      startmillis = millis();
  else if (animationcountleft == 2){
      pixels.setPixelColor(7, pixels.Color(0, 0, 0));
      pixels.setPixelColor(6, turningsignalcolor);
      pixels.show();
    else {
  if (animationcountleft == 3){
    if ((millis() - startmillis) < 750){
      pixels.setPixelColor(6, pixels.Color(0, 0, 0));
      pixels.setPixelColor(5, turningsignalcolor);
      pixels.show();
    else {
  if (animationcountleft == 4){
    if ((millis() - startmillis) < 400){
      pixels.setPixelColor(5, pixels.Color(0, 0, 0));
      pixels.show();
    else {
void rightblinker(){
  if (animationcountright == 1){
      pixels.show();
    else {
      animationcountright++;
  else if (animationcountright == 2){
      pixels.setPixelColor(8, turningsignalcolor);
      pixels.show();
    else {
  if (animationcountright == 3){
      pixels.setPixelColor(8, pixels.Color(0, 0, 0));
      pixels.setPixelColor(9, turningsignalcolor);
      pixels.show();
    else {
  if (animationcountright == 4){
      pixels.setPixelColor(9, pixels.Color(0, 0, 0));
      pixels.show();
    else {
void brakelight(int brakelighton){
  if (brakelighton == 1){
    pixels.setPixelColor(brake1, pixels.Color(255, 0, 0));//brake light on
    pixels.setPixelColor(brake2, pixels.Color(255, 0, 0));//brake light on
    pixels.setPixelColor(brake3, pixels.Color(255, 0, 0));//brake light on
    pixels.setPixelColor(brake4, pixels.Color(255, 0, 0));//brake light on
    pixels.setPixelColor(brake5, pixels.Color(255, 0, 0));//brake light on
    pixels.show();
  else if (brakelighton == 2){
    pixels.setPixelColor(brake1, pixels.Color(60, 0, 0));//dim brake light
    pixels.setPixelColor(brake2, pixels.Color(60, 0, 0));//dim brake light
    pixels.setPixelColor(brake3, pixels.Color(60, 0, 0));//dim brake light
    pixels.setPixelColor(brake4, pixels.Color(60, 0, 0));//dim brake light
    pixels.setPixelColor(brake5, pixels.Color(60, 0, 0));//dim brake light
    pixels.show();
  else {
    pixels.setPixelColor(brake1, pixels.Color(0, 0, 0));//no brake light
    pixels.setPixelColor(brake2, pixels.Color(0, 0, 0));//no brake light
    pixels.setPixelColor(brake3, pixels.Color(0, 0, 0));//no brake light
    pixels.setPixelColor(brake4, pixels.Color(0, 0, 0));//no brake light
    pixels.setPixelColor(brake5, pixels.Color(0, 0, 0));//no brake light
    pixels.show();
void headlights(bool on){
  if (on){
    pixels.setPixelColor(0, pixels.Color(255, 255, 255));//brake light on
    pixels.setPixelColor(1, pixels.Color(255, 255, 255));//brake light on
    pixels.setPixelColor(2, pixels.Color(255, 255, 255));//brake light on
    pixels.setPixelColor(3, pixels.Color(255, 255, 255));//brake light on
    pixels.setPixelColor(4, pixels.Color(255, 255, 255));//brake light on
    pixels.show();
  else {
    pixels.setPixelColor(0, pixels.Color(0, 0, 0));//dim brake light
    pixels.setPixelColor(1, pixels.Color(0, 0, 0));//dim brake light
    pixels.setPixelColor(2, pixels.Color(0, 255, 0));//dim brake light
    pixels.setPixelColor(3, pixels.Color(0, 0, 0));//dim brake light
    pixels.setPixelColor(4, pixels.Color(0, 0, 0));//dim brake light
    pixels.show();
void startDisplay(){
  screen.setTextWrap(false);
  //title
  screen.print("DIY E-Scooter");
  //speed label
  screen.setCursor(125,40);
  screen.print("Speed");
  //dist and time to empty labels
  screen.setCursor(91,170);
  screen.print("Dist   Time");
  //boost button
  //lock button
  //cruise button
void OTAStart(){
  // Port defaults to 8266
  // ArduinoOTA.setPort(8266);
  // Hostname defaults to esp8266-[ChipID]
   ArduinoOTA.setHostname("EscooterESP");
  // No authentication by default
   ArduinoOTA.setPassword("maker");//(const char
  ArduinoOTA.onStart([]() {
    Serial.println("Start");
  ArduinoOTA.onEnd([]() {
    Serial.println("\nEnd");
  ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
    Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
  ArduinoOTA.onError([](ota_error_t error) {
    Serial.printf("Error[%u]: ", error);
    if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
    else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
    else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
    else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
    else if (error == OTA_END_ERROR) Serial.println("End Failed");
  ArduinoOTA.begin();
  Serial.println("Ready");
  Serial.print("IP address: ");
void startGestureSensor(){
  if(gr10_30.begin() != 0){
    Serial.println(" Sensor initialize failed!!");
  /** Set the gesture to be enabled
 *  GESTURE_UP
 *  GESTURE_DOWN
 *  GESTURE_LEFT
 *  GESTURE_RIGHT
 *  GESTURE_FORWARD
 *  GESTURE_BACKWARD
 *  GESTURE_CLOCKWISE
 *  GESTURE_COUNTERCLOCKWISE
 *  GESTURE_WAVE              It is not suggested to enable rotation gesture (CW/CCW) and wave gesture at the same time.
 *  GESTURE_HOVER             Disable other gestures when hover gesture enables.
 *  GESTURE_UNKNOWN
 *  GESTURE_CLOCKWISE_C
 *  GESTURE_COUNTERCLOCKWISE_C
  gr10_30.enGestures(GESTURE_UP|GESTURE_DOWN|GESTURE_LEFT|GESTURE_RIGHT|GESTURE_FORWARD|GESTURE_BACKWARD|GESTURE_CLOCKWISE|GESTURE_COUNTERCLOCKWISE|GESTURE_CLOCKWISE_C|GESTURE_COUNTERCLOCKWISE_C);
 * Set the detection window you want, only data collected in the range are valid
 * The largest window is 31, the configured number represents distance from the center to the top, bottom, left and right
 * For example, if the configured distance from top to bottom is 30, then the distance from center to top is 15, and distance from center to bottom is also 15
 * udSize Range of distance from top to bottom      0-31
 * lrSize Range of distance from left to right      0-31
  gr10_30.setUdlrWin(30, 30);//0-31,0-31
 * Set moving distance that can be recognized as a gesture
 * Distance range 5-25, must be less than distances of the detection window
  gr10_30.setLeftRange(10);
  gr10_30.setRightRange(10);
  gr10_30.setUpRange(10);
  gr10_30.setDownRange(10);
  gr10_30.setForwardRange(10);
  gr10_30.setBackwardRange(10);
 * Set distance of moving forward and backward that can be recognized as a gesture
 * Distance range 1-15
 * Set rotation angle that can trigger the gesture
 * count Default is 16 range 0-31
 * count Rotation angle is 22.5 * count
 * count = 16 22.5*count = 360  Rotate 360° to trigger the gesture
  gr10_30.setCwsAngle(/*count*/16);
  gr10_30.setCcwAngle(/*count*/16);
 * Set degrees of continuous rotation that can trigger the gesture
 * count Default is 4  range 0-31
 * count The degrees of continuous rotation is 22.5 * count
 * For example: count = 4 22.5*count = 90
 * Trigger the clockwise/counterclockwise rotation gesture first, if keep rotating, then the continuous rotation gesture will be triggered once every 90 degrees
  gr10_30.setCwsAngleCount(/*count*/8);
  gr10_30.setCcwAngleCount(/*count*/8);
void interruptRoutine(){
  Serial.println("Interrupt...");
void onIftttCounterChange()  {
  // Add your code here to act upon IftttCounter change
You can grade me on my code organization if you like :wink:.
All the other info pertaining to parts (their links) and all other things are in my tutorial here:
I hope this is enough info for some help on pin-pointing the problem!
Edit:
Also, I do have an oscilloscope and I did get these photos of the signal, one before the first strip and the other right after, but I'm not sure what i'm looking at :thinking:.
All the oscilloscope settings are identical for both.
Wowww
Im slow on jokes... @2112 and @gilshultz... you two were making fun of my lack of info :neutral_face:
Nice Schematic! I am looking at a way the motor transients can get into the MCU and its circuits. Can you post a link to the DC/DC converter. Also between R1 and R2 I would add a capacitor a few hundred nF. That is a way a transient can not get in and the capacitance will not hurt your measurement. I would also modify the touch sensor so it goes through a resistor before going to the micro to protect it from transients. I do not see any pull up resistors on the I2C bus lines, they should be around 3K3. Only one pair. They may have some in the modules you have connected, I do not know. Getting consistent scans with the I2C scanner will confirm it is all OK.
I am quite sure they do, although I can check again to make sure.
Thanks! What do you think of my code organization? It’s quite lengthy, so I was trying to be as neat as possible… and I just learned about non-blocking code! So this was my first real skills test on that lol.
That makes sense! FYI though, the motor is completely un-attached at the moment and has been since I started adding the LEDs; every motor driver I try keeps blowing :man_facepalming: (I’ve tried 7 so far :grimacing:). I have not tested the LEDs with the scooter itself actually driving.
Thanks again @gilshultz !
What motor driver and how is it attached to the system. Those can get expensive and should not be blowing. Add links for both. Sleep time for me so I will check tomorrow.
Well, i've used these so far:
2x https://www.amazon.com/gp/product/B08J7HNFDL (#1)
2x https://www.amazon.com/gp/product/B087M2378D (#2)
1x https://www.amazon.com/dp/B016O0B0MQ (#3)
1x https://www.amazon.com/gp/product/B08J7Y9QQ8 (#4)
So actually, that makes six dead, and going to order my seventh rn. The one I think I should order is:
or this one:
#1 worked the longest, but then just stopped; both of them
#2 worked the best! Way better speed and torque than #1, but it stopped working really quickly. The second one, I literally soldered everything up, and turned it on, and the motor spooled up way past full speed instantly; so fast, in fact, centrifugal force alone pulled the tire off of the wheel!
I don't remember exactly what happened with #3 and #4, but im pretty sure they worked for a little, and then just wouldn't work.
With all of these, when they stopped working, the wheel would not spin freely very well FYI, like it was being resisted.
Do you have any ideas on a better one to buy?
Edit:
The connections are very simple for me... they're pretty much stupid proof lol. I wire the 3 phases of the motor to the motor driver, along with the 5 hall wires (2 are power, 3 are phase). Then 36V to + and GND to -, speed input to the ESP32, and thats pretty much it. I haven't tried any other features like braking or enable (haha, maybe I did try "breaking").
Oh, I also forgot to mention I tried removing the first LED strip, and wiring the data signal directly to the second strip instead, and I got nothing still. I also tried using a different wire for the GND (instead of the shield of the 16/4 cable) just in case the signal was accidentally being grounded. No luck.
Anyone any ideas?
Ahha! I've got them working... finally!
Soooo... that voltage regulator I bought off of amazon is outputting 5.33V instead of the advertised 5.0V. I looked up the max voltage for the WS2812 LEDs, and it is 5.3V! So, the voltage regulator was just frying my strips :man_facepalming:.
Any ideas on how to lower the voltage by 0.33V? Diodes in series? Im pretty sure a LDO wouldn't work for such a small amount :thinking:.
