PLEASE I NEED HELP. So I wanted to make underlight for my house stairway but after wiring all the WS2812b,Just one led turns (green led in the photo)not all of them. after a couple of tests,(unplugging most of WS2812B) leaving only 5 stairs (49leds per stairs) I made them work,but If I plug all of them,they dont work.I Have a resistor on the Data line and the wirings are good.But this problems keeps going on all of the codes that I test them.....
Is it one particular strip that won't forward the signal?
If you have no other issues, this can mean a damaged LED at the end of one strip or the beginning of the next strip.
This can also happen in the middle of a strip. One LED fails, and breaks the chain.
The solution is to repair the broken LED or just disconnect it from the signal chain and hop from the dOut of the LED before the broken LED to the dIn of the LED after the broken LED.
After you are convinced that is actually the problem.
I have (Data out) Signal from the working band
And in the Next band (posibile to be broken),It gets the signal but when I check the connection in the other end of the possible broken strip,Data out doesn't have signal ,But the 5V is present
Okay everyone,It finally worked,but with one problem.One strip doesn't work cause the data in cable doesn't continue the circuit.After all of this,what can I say is to check your wiring! And don't lose your sanity!.I will try to test the broken data cable with a 9V battery to see if is a led strip or the cable.If anyone have any tips how to test the cable.Tell me and I will try it.Thanks for the the aid given.Love you all <3.
