Hello I'm planning a big project. A 32x32 led grid for school. But I camed across a problem. Regular ws2812b led uses 60ma for a single led but I could not find power consumption of ws2812beco. Does anyone know the power consumption? Thanks for the help.
jhaine
September 19, 2023, 6:18am
2
Addressable RGB 60-LED Strip, 5V, 2m (WS2812B) - Pololu
Pololu - Addressable RGB 60-LED Strip, 5V, 2m (WS2812B) .
@jhaine , does your reply answer OP's question? I followed your link but did not see it; what am I missing?
b707
September 19, 2023, 6:59am
4
This man has done some comparisons for you:
Table from the video (timeline: 6:45)
(sorry for poor image quality):
jhaine
September 19, 2023, 8:32am
5
You have to scroll down to find this:
Each RGB LED draws approximately 50 mA when it is set to full brightness and powered at 5 V. This means that for every 30 LEDs you turn on, your LED strip could be drawing as much as 1.5 A. Be sure to select a power source that can handle your strip’s current requirements.
But the description seems to be for a WS2812B, not a WS2812B eco.
awneil
September 19, 2023, 9:39am
7
sterretje:
WS2812B eco
World-Semi - the manufacturers - do not admit to such a part number:
as founded in 2007, we work as the leading LED specialist in IC designer for Constant Current LED Driver IC, Chip Driver LED, we are recognized as the product development and delivery of LED lighting industry leader
awneil
September 19, 2023, 9:46am
8
This guy found a datasheet:
opened 12:49PM - 14 Sep 20 UTC
closed 03:41PM - 21 Oct 20 UTC
good tip
troubleshooting
Add to Docs
<!-- Thanks for suggesting an idea for this project. READ THIS FIRST:
Please … take a few minutes to complete the requested information below. Our ability to provide assistance is greatly hampered without it. The details requested potentially affect which options to pursue. The small amount of time you spend completing the template will also help the volunteers providing the assistance to you to reduce the time required to help you.
DO NOT DELETE ANY TEXT from this template! Otherwise the issue will be auto-closed.
**Have you looked for this feature in other issues and in the docs?**
Yes
**Is your feature request related to a problem? Please describe.**
Thank you for the great work you've done. I have a question regarding ledstrip.
I am a beginner but I was able to use a WS2812B ledstrip, as described in the documentation and it works great.
I also have WS2812B Eco and because it has WS2812B in its name, I was hoping it will work also. Maybe, I am missing something but it does not seem to be compatible. The leds turn on but there are all white, I cannot turn them off, change color,....
My configuration is simple, I am using a Wemos D1 and the led strip.
I was wondering if there anything that could be done to make it work ?
Thanks for your help
**Describe the solution you'd like**
I would like to be able to use my ws2812b Eco ledstrip with tasmota.
**Describe alternatives you've considered**
_A clear and concise description of any alternative solutions or features you've considered._
N/A
**Additional context**
_Add any other context or screenshots about the feature request here._
**(Please, remember to close the issue when the problem has been addressed)**
He calls it just "WS2812E" - not "WS2812B Eco" - and that number does appear on the World-Semi site.
tl;dr: it doesn't look like there's very much difference?
No it consumes 60ma when fully powered. It has 3 led diodes inside each consuming 20 ma on full brightness
system
Closed
March 19, 2024, 6:54am
11
