hey
i have a client side that sends udp struct via phiscal eth connection.
and i tried with both the :
#include <AsyncUDP.h>
and #include <WiFiUdp.h>
but i get an avearge of 10% packet loss.
i even introduced longer loop time of 5ms in order to try and reduce packetLoss but without success.
this is my code
#include <ETH.h>
#include <AsyncUDP.h> // Works with Ethernet as well
#include <Wire.h>
#include <Adafruit_ADS1X15.h>
// Target IP and Port
IPAddress target_IP(192, 168, 1, 52);
const uint16_t target_Port = 1002;
// ESP32 Ethernet Configuration
IPAddress local_IP(192, 168, 1, 50);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress primaryDNS(8, 8, 8, 8);
IPAddress secondaryDNS(8, 8, 4, 4);
#define ETH_PHY_TYPE ETH_PHY_LAN8720
#define ETH_ADDR 1
#define ETH_POWER_PIN 16
#define ETH_MDC_PIN 23
#define ETH_MDIO_PIN 18
#define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT
Adafruit_ADS1115 ads;
uint8_t mac[] = {0xDE, 0xAD, 0xBE, 0xEE, 0xFE, 0xEE};
// UDP Object (use AsyncUDP instead of WiFiUDP)
AsyncUDP udp;
int currentTime=0;
int perviousTime=0;
// Struct to send
struct msg {
uint16_t Pitch;
uint16_t Roll;
uint16_t Avg_Roll;
uint16_t Avg_Pitch;
uint16_t stamp;
#define WINDOW_SIZE 8 // Define the window size for averaging
int16_t pitchWindow[WINDOW_SIZE] = {0}; // Circular buffer to store last 8 values
uint8_t windowIndex = 0; // Current position in the buffer
int32_t sumPitch = 0;
Serial.println("Initializing Ethernet...");
ETH.begin(ETH_PHY_TYPE, ETH_ADDR, ETH_MDC_PIN, ETH_MDIO_PIN, ETH_POWER_PIN, ETH_CLK_MODE);
ETH.macAddress(mac);
delay(100);
ETH.begin();
ETH.config(local_IP, gateway, subnet, primaryDNS);
// Wait for a valid IP address
while (!ETH.localIP()) {
Serial.println("Waiting for Ethernet connection...");
Serial.print("Ethernet Connected. IP Address: ");
Serial.println(ETH.localIP());
// No need to call begin() for AsyncUDP
Wire.begin(15, 14); // SDA = IO15, SCL = IO14
if (!ads.begin()) {
Serial.println("Failed to initialize ADS1115!");
while (1);
ads.setGain(GAIN_TWOTHIRDS); // Set gain for 0-6.144V range
ads.setDataRate(RATE_ADS1115_860SPS); // Set highest data rate (860 SPS)
Serial.println("ADS1115 initialized.");
uint16_t SlidingWindow(int16_t rawValue)
// Update the running sum: remove the oldest value, add the new one
sumPitch -= pitchWindow[windowIndex]; // Remove the old value
pitchWindow[windowIndex] = rawValue; // Insert new value
sumPitch += rawValue; // Add new value to sum
// Move index forward in circular buffer
windowIndex = (windowIndex + 1) & (WINDOW_SIZE - 1); // Faster modulo for 8 since its a bitwise AND
// Compute average
return sumPitch >> 3;
static uint32_t previousMicros = 0;
uint32_t currentMicros = micros();
// Check if 4000 microseconds (4 ms) have passed
// if (currentMicros - previousMicros >= 5000) {
previousMicros = currentMicros;
// Fill struct with example data
static uint16_t stamp = 0;
int16_t rawValue = ads.readADC_SingleEnded(0); // Read from A0
//float voltage = rawValue * 6.144 / 32767.0;
uint16_t avgPitch = SlidingWindow(rawValue);
msg data;
data.Pitch = rawValue;
data.Roll = 0;
data.Avg_Roll = 0;
data.Avg_Pitch = avgPitch;
data.stamp = stamp++;
// Send UDP Packet
udp.writeTo((uint8_t*)&data, sizeof(data), target_IP, target_Port);
