Xbee transfer temperature data
Hi guys, i am typically new to arduino and i am trying to complete my first project for my university using temperature, humidity sensors and xbee to transfer data from a standalone arduino uno to my "main" arduino Mega. I have managed to make my 2 xbees to communicate but i don't understand exactly how to pass data from my remote arduino uno to Mega. Below is the code that is already in arduino uno memory and next is the code that i should fix in order to send data correctly. I don't know exactly how to use a buffer to save data as char and then convert them to integer.
Arduino uno code
#include <dht11.h>
dht11 DHT11;
  DHT11.attach(13);
  int chk = DHT11.read();
  int sensorValue;
  Serial.print((float)DHT11.humidity);
  Serial.print(",");
  Serial.print((float)DHT11.temperature);
  Serial.print(",");
  Serial.print(DHT11.fahrenheit());
  sensorValue = analogRead(A0);       // read analog input pin 0
    Serial.print(",");
  Serial.print(sensorValue, DEC);  // prints the value read
  Serial.println("\n");
which produces the following result:
40.00,24.00,75.20,110
which is in order: humidity (%), temp (c), temp (F), analog value of a smoke detector.
Below is the problematic code that i use to transfer my data to Arduino Mega using buffer.
Arduino Mega code
  // initialize both serial ports:
  Serial.begin(9600);    // Arduino Mega Serial
  Serial3.begin(9600);  // Arduino Uno Serial
  int temp;
  char buffer[32];
  byte pos; // position in read buffer
  char buffer[32];
  // send data only when you receive data:
  if (Serial3.available() > 0)
    // read the incoming byte:
    char inByte = Serial3.read();
    // add to our read buffer
    buffer[pos] = inByte;
    pos++;
    // check for delimiter
    if (inByte = ',')
      buffer[pos-1] = 0;
      int temp = atoi(buffer);
      Serial.println(temp);
    delay(100);
Just need a short example of how to store them and convert them properly in order to be in as mentioned above. Thank you very much
Why do you feel the need to cast the value to a float? It won't increase the accuracy of the value.
Ditto for the temperature.
The default base is 10. If you want to use the default base, it isn't necessary to specify it.
  int temp;
  char buffer[32];
Local variables created just before the function ends are not useful.
You are sending the data as floats. Why are you reading them as ints?
What is wrong with the code that you have? Apparently, you have some issues, or you wouldn't be posting.
