Xiao boards: "Property 'upload.tool.serial' is undefined"
In both a new install of IDE 2.0 under Windows 10, 64-bit, and an upgraded install in MacOS 12.6 I'm consistently getting this error - "Property 'upload.tool.serial' is undefined" - when trying to upload to any of the following SEEED Xiao boards:
rp2040
nRF52840
nRF52840 sense
ESP32C3
Hi @BuddhaChrist. In order to gather more information that might help us to troubleshoot your problem, I'm going to ask you to post the full output from an upload attempt when in verbose mode.
:exclamation: NOTE: These instructions will not solve the problem. They are only intended to possibly gather some more information about the problem, which might provide a clue that leads to a solution.
Please do this:
  1. Select File > Preferences from the Arduino IDE menus.
  2. Check the checkbox next to "Show verbose output during: ☐ compilation".
  3. Check the checkbox next to "Show verbose output during: ☐ upload".
  4. Click the OK button.
  5. Attempt an upload, as you did before.
  6. After the upload fails, you'll see a button on the right side of the orange bar in the Arduino IDE: Copy error messages. Click that button.
    This copies the full output to the clipboard.
  7. Open a forum reply here by clicking the Reply button.
  8. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  9. Press Ctrl+V.
    This will paste the error output from the upload into the code block.
  10. Move the cursor outside of the code tags before you add any additional text to your reply.
  11. Click the Reply button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here:
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a forum reply here by clicking the Reply button.
  5. Click the "Upload" icon (image) on the post composer toolbar:
  6. Select the .txt file you saved.
  7. Click the Open button.
  8. Click the Reply button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
Sketch uses 726677 bytes (55%) of program storage space. Maximum is 1310720 bytes.
Global variables use 41808 bytes (12%) of dynamic memory, leaving 285872 bytes for local variables. Maximum is 327680 bytes.
Same problem as described above, this time on a M5PICO (ESP32)
The connection to the device seems to be OK becouse in the Monitor screen, I get the message from the device:
00A5A78C
ESP32 Chip model = ESP32-PICO-D4 Rev 1
This chip has 2 cores
Chip ID: 10856332
ESP32 Chip ID = 8CA7A525754C
Hi @jpe4619. Please follow the instructions I provided in my reply above.
@ptillisch Hope this helps to find the problem.
Did a complete restart of the PC, unfortunately the same error.
thanks for looking into this:
errror.txt (221.4 KB)
P.S. on IDE Arduino 1.18.19 it works without any problems, on same PC and same device.
I found there is an error in the configuration of the M5Stack boards platform. I'll provide instructions to fix it:
  1. Open the file at the following path using any text editor:
    C:\Users\janpe\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\2.0.4\boards.txt
    :exclamation: If looking for it with your file browser or command line, note that the folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
  2. Change line 1464 from this:
    stamp-pico.upload.tool=esptool_py
    To this:
    stamp-pico.upload.tool.serial=esptool_py
  3. Save the file.
  4. If the Arduino IDE is running, select File > Quit from the Arduino IDE menus.
  5. Start the Arduino IDE.
    ⓘ The restart is done to make the IDE recognize the change to the boards.txt file.
Now try uploading again. Hopefully the error will no longer occur.
The instructions above are specific to the "STAMP-PICO" board I saw you were uploading to in the error output you shared. If you are also using other boards then a similar change would need to be made to their upload.tool properties in boards.txt. I'm happy to provide specific instructions for those as well.
Please let me know if you have any questions or problems while following those instructions.
@ptillisch Thank you very much for your investigation and giving the solution,
works perfect.
Strange that it was no problem in "IDE Arduino 1.18.19", probably, that was more fault tolerant.
You are welcome. I'm glad it is working now.
@BuddhaChrist if you want me to provide instructions specifically for the fix on your system, just provide the output as I requested in my previous reply. Otherwise you can extrapolate the fix from the instructions I provided @jpe4619.
In this case, no. Arduino's developers have recently created a new flexible and powerful "pluggable discovery" system, which is only available in Arduino IDE 2.x. This system makes it easy for Arduino boards platform authors to use any arbitrary communication channel between the board and the IDE.
Boards platform configurations that use the old syntax are automatically translated to the new syntax by Arduino IDE 2.x:
https://arduino.github.io/arduino-cli/latest/platform-specification/#:~:text=g.%2C%20openocd).-,For%20backward%20compatibility%20with%20IDE%201.8.15%20and%20older%20the%20previous%20syntax%20is%20still%20supported,-%3A
but that is only done if you use the old syntax exclusively. The M5Stack developers used the new syntax in the platform.txt configuration file, but didn't do the same in the boards.txt configuration file. The new syntax in platform.txt disabled the backwards compatibility translation which normally would have converted the upload.tool property to an upload.tool.serial property.
I guess they must have copied the change from the ESP32 boards platform, but only did it halfway:
https://github.com/espressif/arduino-esp32/pull/6506/files
Extrapolated, and it worked wonderfully. Thank you. Now, via messing around installing and reinstalling board definitions, I'm getting a FQBN error, but I'm working around it by re-selecting the board and port before every interaction.
You are welcome. Excellent work on applying the fix @BuddhaChrist! I'm glad it is working now.
If you aren't able to solve it, you are welcome to make a post with details here on the forum. We'll be sure to take a look and see if we can help you out.
Hello ptillisch
I am having the same issue using IDE 2.0.0 on MacOS 12.6. Verbrose below. I have also looked and can't find the M5Stack in Arduino15/packages.
Using board 'xiaonRF52840' from platform in folder: /Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2
Using core 'arduino' from platform in folder: /Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2
Detecting libraries used...
/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -g3 -nostdlib @/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/defines.txt @/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/cxxflags.txt -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_SEEED_XIAO_NRF52840 -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -I/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/cores/arduino -I/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840 -I/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/cores/arduino/api/deprecated -I/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/cores/arduino/api/deprecated-avr-comp -iprefix/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/cores/arduino @/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/includes.txt /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -g3 -nostdlib @/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/defines.txt @/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/cxxflags.txt -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -w -x c++ -E -CC -DARDUINO=10607 -DARDUINO_SEEED_XIAO_NRF52840 -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=1 -I/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/cores/arduino -I/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840 -I/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/cores/arduino/api/deprecated -I/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/cores/arduino/api/deprecated-avr-comp -iprefix/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/cores/arduino @/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/includes.txt /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/sketch/Blink.ino.cpp -o /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/preproc/ctags_target_for_gcc_minus_e.cpp
/Users/Scound-Bast/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -g3 -nostdlib @/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/defines.txt @/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/cxxflags.txt -DARDUINO_ARCH_NRF52840 -MMD -mcpu=cortex-m4 -mfloat-abi=softfp -mfpu=fpv4-sp-d16 -DARDUINO=10607 -DARDUINO_SEEED_XIAO_NRF52840 -DARDUINO_ARCH_MBED -DARDUINO_ARCH_MBED -DARDUINO_LIBRARY_DISCOVERY_PHASE=0 -I/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/cores/arduino -I/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840 -I/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/cores/arduino/api/deprecated -I/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/cores/arduino/api/deprecated-avr-comp -iprefix/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/cores/arduino @/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/includes.txt /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/sketch/Blink.ino.cpp -o /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using previously compiled file: /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/core/variant.cpp.o
Using precompiled core: /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-core-cache/core_Seeeduino_mbed_xiaonRF52840_b69ef02f385ae1b38fac5f3c8a5fd395.a
Linking everything together...
/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -E -P -x c /Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/linker_script.ld -o /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/linker_script.ld
/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -L/private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753 -Wl,--gc-sections -w -Wl,--as-needed @/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/ldflags.txt -T/private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/linker_script.ld -Wl,-Map,/private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/Blink.ino.map --specs=nosys.specs -o /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/Blink.ino.elf /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/sketch/Blink.ino.cpp.o /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/core/variant.cpp.o -Wl,--whole-archive /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/../arduino-core-cache/core_Seeeduino_mbed_xiaonRF52840_b69ef02f385ae1b38fac5f3c8a5fd395.a /Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/libs/libmbed.a /Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/libs/libcc_310_core.a /Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/libs/libcc_310_ext.a /Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/variants/SEEED_XIAO_NRF52840/libs/libcc_310_trng.a -Wl,--no-whole-archive -Wl,--start-group -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group
/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O binary /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/Blink.ino.elf /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/Blink.ino.bin
/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O ihex -R .eeprom /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/Blink.ino.elf /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/Blink.ino.hex
/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/tools/adafruit-nrfutil/macos/adafruit-nrfutil dfu genpkg --dev-type 0x0052 --application /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/Blink.ino.hex /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/Blink.ino.zip
Zip created at /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/Blink.ino.zip
/Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-size -A /private/var/folders/58/41hhmv0d1db1f3q9b23fjgnw0000gn/T/arduino-sketch-0AAC6188BD7DA08607ED96216CA9C753/Blink.ino.elf
Sketch uses 83480 bytes (10%) of program storage space. Maximum is 811008 bytes.
Global variables use 43904 bytes (18%) of dynamic memory, leaving 193664 bytes for local variables. Maximum is 237568 bytes.
Property 'upload.tool.' is undefined
Thanks
B
Hi @brainmaiden. The bug and general nature of the fix is the same, but the details are different because this time the bug is in the "Seeed nRF52 mbed-enabled Boards" platform instead of the M5Stack platform.
I'll provide instructions for the fix:
    /Users/Scound-Bast/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.7.2/boards.txt
  2. Add this line anywhere in the file:
    xiaonRF52840.upload.tool.default=nrfutil
  3. Save the file.
Thanks for your advice ptillisch
It turned out it was a boot loader issue, but I'm sure this didn't help either.
B
Thank you, @ptillisch! You saved me hours!
My boards.txt file already had:
"xiaonRF52840.upload.tool=nrfutil"
I changed just added the ".default" parameter to it and it worked.
You are welcome. I'm glad if I was able to be of assistance. Hopefully Seeed Studio will fix this bug soon. I went looking for a public repository for this specific platform so I could submit a pull request, but I could not find one so I guess it is private.
Using board 'fm-devkit' from platform in folder: C:\Users\Asus\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5
Using core 'esp32' from platform in folder: C:\Users\Asus\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5
cmd /c if exist "C:\\Users\\Asus\\AppData\\Local\\Temp\\.arduinoIDE-unsaved20221026-12680-1bnr176.9ih2\\sketch_nov26a\\partitions.csv" COPY /y "C:\\Users\\Asus\\AppData\\Local\\Temp\\.arduinoIDE-unsaved20221026-12680-1bnr176.9ih2\\sketch_nov26a\\partitions.csv" "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\partitions.csv"
cmd /c if not exist "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\partitions.csv" if exist "C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\fm-devkit\\partitions.csv" COPY "C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\fm-devkit\\partitions.csv" "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\partitions.csv"
cmd /c if not exist "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\partitions.csv" COPY "C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\tools\\partitions\\default.csv" "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\Asus\\AppData\\Local\\Temp\\.arduinoIDE-unsaved20221026-12680-1bnr176.9ih2\\sketch_nov26a\\bootloader.bin" ( COPY /y "C:\\Users\\Asus\\AppData\\Local\\Temp\\.arduinoIDE-unsaved20221026-12680-1bnr176.9ih2\\sketch_nov26a\\bootloader.bin" "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\sketch_nov26a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\fm-devkit\\bootloader.bin" ( COPY "C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\fm-devkit\\bootloader.bin" "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\sketch_nov26a.ino.bootloader.bin" ) ELSE ( "C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.2.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\sketch_nov26a.ino.bootloader.bin" "C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\tools\\sdk\\esp32\\bin\\bootloader_dio_80m.elf" ) )
esptool.py v4.2.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\Asus\\AppData\\Local\\Temp\\.arduinoIDE-unsaved20221026-12680-1bnr176.9ih2\\sketch_nov26a\\build_opt.h" COPY /y "C:\\Users\\Asus\\AppData\\Local\\Temp\\.arduinoIDE-unsaved20221026-12680-1bnr176.9ih2\\sketch_nov26a\\build_opt.h" "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\build_opt.h"
cmd /c if not exist "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\build_opt.h" type nul > "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\build_opt.h"
"C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/console" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/dio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_fm_devkit -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"fm_devkit\"" "-DARDUINO_VARIANT=\"fm-devkit\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84/build_opt.h" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\cores\\esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\fm-devkit" "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\sketch\\sketch_nov26a.ino.cpp" -o nul
"C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/console" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/dio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_fm_devkit -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"fm_devkit\"" "-DARDUINO_VARIANT=\"fm-devkit\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84/build_opt.h" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\cores\\esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\fm-devkit" "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\sketch\\sketch_nov26a.ino.cpp" -o "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/log/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/console" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/dio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -w -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_fm_devkit -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"fm_devkit\"" "-DARDUINO_VARIANT=\"fm-devkit\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84/build_opt.h" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\cores\\esp32" "-IC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\fm-devkit" "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\sketch\\sketch_nov26a.ino.cpp" -o "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\sketch\\sketch_nov26a.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\Asus\AppData\Local\Temp\arduino-core-cache\core_fde18a20a30507530d17aa159ef45c6e.a
Linking everything together...
"C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" "-Wl,--Map=C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84/sketch_nov26a.ino.map" "-LC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/lib" "-LC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/ld" "-LC:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/dio_qspi" -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld -mlongcalls -Wno-frame-address -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -u ld_include_hli_vectors_bt -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 -Wl,--start-group "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84\\sketch\\sketch_nov26a.ino.cpp.o" "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-core-cache\\core_fde18a20a30507530d17aa159ef45c6e.a" -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lrmaker_common -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lgpio_button -lqrcode -lws2812_led -lesp-dsp -lesp-sr -lesp32-camera -lesp_littlefs -lfb_gfx -lasio -lcbor -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -lrmaker_common -lmqtt -ljson_parser -ljson_generator -lesp_schedule -lqrcode -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -lesp-sr -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -ljson -lspiffs -ldl_lib -lc_speech_features -lwakeword_model -lmultinet2_ch -lesp_tts_chinese -lvoice_set_xiaole -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lc -Wl,--end-group -Wl,-EL -o "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84/sketch_nov26a.ino.elf"
"C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.2.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84/sketch_nov26a.ino.bin" "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84/sketch_nov26a.ino.elf"
esptool.py v4.2.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
"C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/gen_esp32part.exe" -q "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84/partitions.csv" "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84/sketch_nov26a.ino.partitions.bin"
"C:\\Users\\Asus\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-size" -A "C:\\Users\\Asus\\AppData\\Local\\Temp\\arduino-sketch-65753BFBA585489137545B739C055A84/sketch_nov26a.ino.elf"
Sketch uses 248149 bytes (18%) of program storage space. Maximum is 1310720 bytes.
Global variables use 16568 bytes (5%) of dynamic memory, leaving 311112 bytes for local variables. Maximum is 327680 bytes.
Property 'upload.tool.' is undefined
Hi @priwep. Which board do you have selected from the Tools > Board menu in Arduino IDE?
ESP32 FM DevKit
OK, great.
I'll provide instructions for the fix:
  1. Open the file at the following path using any text editor:
    C:\Users\Asus\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\boards.txt
    :exclamation: If looking for it with your file browser or command line, note that the C:\Users\Asus\AppData\ folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
  2. Add the following lines anywhere in the file:
    fm-devkit.upload.tool.default=esptool_py
    fm-devkit.upload.tool.network=esp_ota
  3. Save the file.
  4. If the Arduino IDE is running, select File > Quit from the Arduino IDE menus.
  5. Start the Arduino IDE.
    ⓘ The restart is done to make the IDE recognize the change to the boards.txt file.
Now try uploading again. Hopefully the error will no longer occur.
Please let me know if you have any questions or problems while following those instructions.
By the way, since the ESP32 boards platform source code is actually available for everyone in the community to make contributions, I was able to submit a pull request to fix this bug in the platform:
Even though it will be necessary for the users to manually apply the fix for now, hopefully this means the problem will be resolved in the future releases of the platform.
Using board 'dstike' from platform in folder: /Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5
Using core 'arduino' from platform in folder: /Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5
Detecting libraries used...
/Users/bunchterra/Library/Arduino15/packages/wifiduck/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATMEGA32U4 -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8036 "-DUSB_MANUFACTURER=\"Arduino\"" "-DUSB_PRODUCT=\"Leonardo\"" -DENABLE_I2C -DNEOPIXEL -DNEOPIXEL_NUM=1 -DLED_PIN=7 -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/cores/arduino -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/variants/dstike /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/atmega_duck.ino.cpp -o /dev/null
Alternatives for HID.h: [HID@1.0]
ResolveLibrary(HID.h)
  -> candidates: [HID@1.0]
/Users/bunchterra/Library/Arduino15/packages/wifiduck/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATMEGA32U4 -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8036 "-DUSB_MANUFACTURER=\"Arduino\"" "-DUSB_PRODUCT=\"Leonardo\"" -DENABLE_I2C -DNEOPIXEL -DNEOPIXEL_NUM=1 -DLED_PIN=7 -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/cores/arduino -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/variants/dstike -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/HID/src /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/atmega_duck.ino.cpp -o /dev/null
Using cached library dependencies for file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/Adafruit_DotStar.cpp
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
Using cached library dependencies for file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/NeoPixel.cpp
Using cached library dependencies for file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/com.cpp
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
Using cached library dependencies for file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/duckparser.cpp
Using cached library dependencies for file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/keyboard.cpp
Using cached library dependencies for file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/led.cpp
Using cached library dependencies for file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/parser.c
Using cached library dependencies for file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/serial_bridge.cpp
Using cached library dependencies for file: /Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/HID/src/HID.cpp
Using cached library dependencies for file: /Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/SPI/src/SPI.cpp
Using cached library dependencies for file: /Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/Wire/src/Wire.cpp
Using cached library dependencies for file: /Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/Wire/src/utility/twi.c
Generating function prototypes...
/Users/bunchterra/Library/Arduino15/packages/wifiduck/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATMEGA32U4 -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8036 "-DUSB_MANUFACTURER=\"Arduino\"" "-DUSB_PRODUCT=\"Leonardo\"" -DENABLE_I2C -DNEOPIXEL -DNEOPIXEL_NUM=1 -DLED_PIN=7 -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/cores/arduino -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/variants/dstike -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/HID/src -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/SPI/src -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/Wire/src /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/atmega_duck.ino.cpp -o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/preproc/ctags_target_for_gcc_minus_e.cpp
/Users/bunchterra/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
Using previously compiled file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/parser.c.o
Using previously compiled file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/Adafruit_DotStar.cpp.o
Using previously compiled file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/com.cpp.o
Using previously compiled file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/serial_bridge.cpp.o
Using previously compiled file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/NeoPixel.cpp.o
Using previously compiled file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/duckparser.cpp.o
Using previously compiled file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/keyboard.cpp.o
/Users/bunchterra/Library/Arduino15/packages/wifiduck/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATMEGA32U4 -DARDUINO_ARCH_AVR -DUSB_VID=0x2341 -DUSB_PID=0x8036 "-DUSB_MANUFACTURER=\"Arduino\"" "-DUSB_PRODUCT=\"Leonardo\"" -DENABLE_I2C -DNEOPIXEL -DNEOPIXEL_NUM=1 -DLED_PIN=7 -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/cores/arduino -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/variants/dstike -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/HID/src -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/SPI/src -I/Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/Wire/src /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/atmega_duck.ino.cpp -o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/atmega_duck.ino.cpp.o
Using previously compiled file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/led.cpp.o
Compiling library "HID"
Using previously compiled file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/libraries/HID/HID.cpp.o
Compiling library "SPI"
Using previously compiled file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/libraries/SPI/SPI.cpp.o
Compiling library "Wire"
Using previously compiled file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/libraries/Wire/Wire.cpp.o
Using previously compiled file: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/libraries/Wire/utility/twi.c.o
Compiling core...
Using precompiled core: /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-core-cache/core_wifiduck_avr_dstike_keyboardid_default,debug_disabled_ab19b41e6e651774891133ad3100b611.a
/Users/bunchterra/Library/Arduino15/packages/wifiduck/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega32u4 -o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/atmega_duck.ino.elf /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/Adafruit_DotStar.cpp.o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/NeoPixel.cpp.o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/atmega_duck.ino.cpp.o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/com.cpp.o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/duckparser.cpp.o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/keyboard.cpp.o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/led.cpp.o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/parser.c.o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/sketch/serial_bridge.cpp.o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/libraries/HID/HID.cpp.o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/libraries/SPI/SPI.cpp.o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/libraries/Wire/Wire.cpp.o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/libraries/Wire/utility/twi.c.o /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/../arduino-core-cache/core_wifiduck_avr_dstike_keyboardid_default,debug_disabled_ab19b41e6e651774891133ad3100b611.a -L/private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171 -lm
/Users/bunchterra/Library/Arduino15/packages/wifiduck/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/atmega_duck.ino.elf /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/atmega_duck.ino.eep
/Users/bunchterra/Library/Arduino15/packages/wifiduck/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy -O ihex -R .eeprom /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/atmega_duck.ino.elf /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/atmega_duck.ino.hex
Using library HID at version 1.0 in folder: /Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/HID
Using library SPI at version 1.0 in folder: /Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/SPI
Using library Wire at version 1.0 in folder: /Users/bunchterra/Library/Arduino15/packages/wifiduck/hardware/avr/1.8.5/libraries/Wire
/Users/bunchterra/Library/Arduino15/packages/wifiduck/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-size -A /private/var/folders/vz/b7_qdt1d513dgfsz3vt7tn0c0000gn/T/arduino-sketch-35298EEB90373684B7BE23D1CA206171/atmega_duck.ino.elf
Sketch uses 25224 bytes (87%) of program storage space. Maximum is 28672 bytes.
Global variables use 1559 bytes (60%) of dynamic memory, leaving 1001 bytes for local variables. Maximum is 2560 bytes.
Property 'upload.tool.serial' is undefined
