Hello everyone.
I have been working on making a custom controller using Arduino and the XInput library. The problem I am running into at the moment is receiving data sent through my bluetooth module in a meaningful format.
#include <XInput.h>
const int Pin_ButtonA = 0;
Serial3.begin(9600);
pinMode(Pin_ButtonA, INPUT_PULLUP);
XInput.setAutoSend(false);
XInput.begin();
boolean buttonA = !digitalRead(Pin_ButtonA);
XInput.setButton(BUTTON_A, buttonA);
char Output = XInput.send();
Serial3.write(Output);
This is the simple code I have so far to read a button press and then send it over Serial 3.
Any information that you have would be greatly appreciated.
Edit: I have tried a couple things since making this post. I realized the project I want to make will be powered independently from a computer. Now the output of the micro controller are reverse question marks. Here is a picture of the new output:
Each question mark represents when I press down on the button and when I release the button, so I pressed and released the button three times in the above picture.
