Yet another pressure sensor support request
Hello fellow engineers and geeks alike,
This should be a simple one, but I have been getting confused as I peruse all of the other pressure sensor examples.
This is an isolated ASCO pressure sensor (3000PSI, 1-5v)
The way I understand this is I should be able to supply 12vdc to the black and red, and then read the reference voltage across green and white, but his hasn't been the case.
The part I think I am missing is either a connected ground or a load / burden resistor or both.
I thought my understanding of isolated was the supply voltage grounds are not connected and the sensor diaphragm uses a silicon oil to pass the pressure hydraulicly. (Looks like this model doesn't but you get the idea)
I don't want to cook my multi hundred dollar sensor so I figured I should ask first, burn later.
Here is the pinout diagram:
I see green is listed as millivolt only, and I have the 1-5v option, so I assume I only need to connect my white cable to an analogue in but the (signal negative) part confused me.
I will be using a 12v PSU for the sensor (excite range is 10-28vdc) and a voltage converter to supply 5v for the ESP32.
Is it as easy as just connect the grounds of the PSU/sensor and the arduino or is a smoothing capacitor and or 10k Ohm resistor placed somewhere also needed?
Thank you for your guidance.
Please post a link to the sensor product page. It is not clear what you mean by "isolated".
For use with a 5V Arduino, what you most likely should buy is the "0.5 to 4.5V ratiometric" version of the sensor. The ESP32 is 3.3V only.
Sorry @jremington I thought I provided enough information.
Here is a link. I am using a series 40.
The model I have is a 1-5vdc as highlighted in yellow in the OP and not the ratiometric.
Thank you.
What is the full product code for the exact sensor you have?
The overview is not particularly helpful. Please post a link to the actual user manual or installation guide for the exact sensor you have.
As stated, this is the series 40, 3000 PSI, 1-5vdc not sure why you need to know cable and NPT size but here you go, I appreciate the help either way :sweat_smile::
if you look at this table, the sensor would have a model of something like:
40-A-03000-p-3-T-0-C0S
I just figured I would save the readers some time in deciphering it.
Yes, I read the overview, which covers many models. If you are unable to post the exact model configuration, you can expect only guesses.
  1. I'm rather certain that "isolation" refers to the working fluid, not the electrical output.
  2. There are four mV models. Those would be bridge sensors, and the green output lead applies only to those.
  3. Connect all the grounds.
  4. Do not apply voltage > 3.3V to any ESP32 input. I have no idea what you mean by a converter for use with ESP32.
I agree with your findings (although fluidless).
I just wanted to see if a resistor or capacitor was required.
I tried connecting just the grounds and expected an output of 1V at atmosphere but that wasn't the case, I will go double check my connections.
Thanks!
To use that sensor with an original issue ESP32 (which has a very poorly functioning, highly nonlinear ADC and is not at all recommended for serious measurement purposes), a resistive voltage divider is required.
I am using a ESP32-S3 Super mini with a 5v in pad on it.
May I ask why I can't use the 5v in on it to power the MCU?
You can use 5V to power the ESP32-S3, if the MCU module includes a 5V to 3.3V regulator, which is likely the case. A resistive voltage divider is required between the sensor and the analog input.
Why do you say "like"? You don't know exactly what model you have?
Thank you for that tip, I had used an arduino that accepted 5v in to an analogue port in the past and just assumed that this one would too. I just confirmed in the spec sheet a max of 3.6V. That saved me a cooked board!
Hi @b707, The model number ( 40A03000p3T0COS) but it is all contiguous, so I broke it down for others to easily understand, thanks for asking :slight_smile:
Why not to say an exact model number?
Judging by your questions, you don't have much experience and could easily be mistaken.
Have you decided how you will to connect it?
Your ideas for connecting a single wire don't seem right.
What you have is a pretty common sensor. Here is where I see a problem. Your sensor is 0 to 3,000 PSI and that corelates to a 1 to 5 volt output. That gives you a 4.0 volt span. So if we divide the 4.0 volt span by 3,000 PSI we get 1.333 mV per PSI. Pretty small number there. Trying to resolve it is a bit of a challenge. There are some pretty useful ways around this. Personally I would run with an ESP8266 or ESP32 and add an ***ADS1115 I2C IIC Analog-to-Digital ADC PGA Converter with Programmable Gain Amplifier High Precision ADC Converter Development Board for Arduino. There are plenty of examples and code samples online and Google is your friend. This gives you a 15 bit ADC capable of I2C communication. There are newer higher resolution ADS but 15 bit with PG (Programmable Gain) should be adequate.
This is how I would go about it. There are other ways to get it done. The ADS1256 gets you a 24 bit A/D. I have used the ADS1115 with an ESP8266. Something to note is when they say a 16 or 24 bit A/D typically a single bit is used for sign so in reality the A/D is really 15 or 23 bit. Anyway, it's something to consider.
Just My Take...
Ron
Hi everyone.
I just got everything working.
Just the one wire (white) connected to an analog in on a Arduino Uno clone did the trick aside from the 12v power in to the sensor and the combined grounds of the sensor and the 5v voltage adaptor for the arduino.
The spec sheet showing the white wire as a negative voltage out was confusing for me, and so I just needed a confidence boost from the community :slight_smile:
No additional resistor or capacitor needed thus far.
I am looking right now at a nice stable value of 0.9677 Volts.
I am going to see if this resolution will suffice for my needs.
Thank you @Ron_Blain for the gain amplifier idea. it has been a long time since I played with one of those in EE in University and forgot all about how it could be used to increase bit depth.
Now to calibrate!
Thanks again,
Cheers everyone!
Impossible.
You're mistaken.
Any current must be closed.
If you have only one wire working, it means the sensor's power supply and its sensing circuit share the same ground with the Arduino.
Otherwise, your result has nothing to do with reality.
Don't forget the gnd wire between Arduino and sensor.
Tom.... :smiley: :+1: :coffee: :australia:
Yes!
I tried to mark that as the solution from @jremington actually!
That was the magic ingredient, thanks @TomGeorge!
Glad you have it working. Keep in mind an Arduino Uno has a 10 bit ADC and when using its 5.0 volt reference for A/D we get 1023 bits so we actually have 5.0 / 1023 = 4.88 mV. The best you will resolve is your 4 / 3000 = 1.333 mV per PSI so about 3.7 PSI per step change. Now if that is adequate you will be fine. :slight_smile:
Ron
