Mars29:
I am having trouble with the IDE. Some text displays OK but a lot of it is missing and/or garbled. Here is a screenshot:
OS is Debian GNU/Linux with the following packages
libjna-jni (4.1.0-1)
libjna-java (4.1.0-1)
librxtx-java (2.2pre2-13)
arduino (2:1.0.5+dfsg2-4)
Any ideas on what could be wrong?
Gosh that's strange. It looks like a corrupt font is being used for certain text.
How about this... in order:
shut down the IDE
go to your ~/.arduino directory
cp "preferences.txt" to "preferences.bak",
rm "preferences.txt"
restart the IDE
see if that helps. You may have a bad font definition in the preferences file.
Also, be sure your font cache is up to date and clean. At a command line, type this:
[b]fc cache -fv[/b]
Hope this helps... can't think of anything else at the moment.....
But I did notice that if I resize the window, occasionally the text will get redrawn correctly. And sometimes only about half of the text gets redrawn correctly. But if I scroll the text, it will get redrawn wrong again.
The Arduino IDE is the only application that has this problem.
and that fixed the problem. Thanks Krupski for pointing me in the font direction.
And I probably never would have made that connection if I was not just studying the Arduino Analog-to-digital converter and the whole aliasing issue associated with sampling frequency.
Mars29:
In the ~/.arduino/preferences.txt file I changed
editor.antialias=false
to
editor.antialias=true
Mars
Glad you got it working... and yes I meant fc-cache, not fc cache. Typo.
BTW, I run Kubuntu 14.04 LTS (64 bit). Ditched Windoze a long time ago.
